review of musysic 4500 amplifier (125$ new on ebay) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-16-2013, 12:16 PM - Thread Starter
davece's Avatar
sine i t was time to do my monthly cleaning of the dust out of my amps i figured id share some pics and reviews
i got this amp brand new off ebay this is how the ad reads
Specifications:
2U Professional Power Amplifier
ATR (Accelerated Transient Response) technology for ultimate punch and clarity
Momentary Peak Output 4500 Watts
2200 Watts @ 2 Ohms
1100 Watts @ 4 Ohms
550 Watts @ 8 Ohms
XLR, ¼” (6.5mm Jack) Balanced Inputs
Speakon and Banana binding post Outputs
Front-to-Rear Airflow and Dual Cooling Fans
Frequency response 10Hz – 50kHz at 1.5 dB
Total Harmonic Distortion: Less than 0.1%
Input sensitivity & Impedance: 0.77v
Signal to Noise (20 Hz - 20 kHz) > 90dB
Dimensions (WxDxH): 20.1” x 13.4" x 6.3”
Weight: 20lbs
AC 115V-230V Switchable.
for short while i used this amp to drive a pair of 4 ohm 12inch subs and it worked out great., i then powered a pair of micro wreckers in a 2 ohm stereo load and the amp still worked great at max power for 4-6 hours on end
i since have moved this amp to main duty since i bought some really heavy duty high powered amps to drive the 15 inch microwreckers i built
obviously those rating in the add are peak ratings and id say slightly inflated
rms figures should be closer to
250wpc @ 8 ohms
400 @ 4 ohms
700 ish at 2 ohms
when i ran the micro wrecker sin 2 ohm loads this amp would get them hot enough were u could smell the voice coils heating up and thos espeakers will take 500-550w rms
my only complaint on this amplifier is that u cannot bridge it or run in parallel
wish i had a rig for testing actual output for u guys though
they make 3 models of this amp this is the middle version, the larger one is bridgeable
and heres some pics of the internals
davece is offline
post #2 of 2 Old 08-19-2015, 08:59 AM
ericnhitterdal's Avatar
Quoted: 31 Post(s)
Liked: 27
Can you give any more details on the sound of the amp? IE Does it have a high noise floor, or does it hiss or anything?
I bought one on ebay (the 2000 watt) model for 35$ shipped, and i thought I'd use it for some ATMOS ceiling speakers, or to replace the amp for my kitchen/deck speakers and use that one for my atmos if this one is too "hissy".
ericnhitterdal is offline
