Denon 1713 5.1 only works with a DVD movie - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-17-2013, 02:10 PM - Thread Starter
BlueBear03's Avatar
I just purchased a Denon 1713 and other than dvd movies all sources play just the two front speakers.. HD TV music channels and CD's. I have try useing HDMI cables as well as optical cables and nothing changes. Is it normal that the display on the receiver goes blank after a few minutes and I have to shut it off and hit the power button to get a display again? From reading post on here I have gone into the setting and change them to auto.I did use Audyssey to set up the system.
BlueBear03 is offline
post #2 of 9 Old 07-17-2013, 02:20 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi BlueBear03, possible you enabled Pure Direct mode.
JChin is offline
post #3 of 9 Old 07-17-2013, 02:39 PM - Thread Starter
BlueBear03's Avatar
How do you change modes. I don't see anything about that on a web search or on the receiver or remote
post #4 of 9 Old 07-17-2013, 02:55 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Should have a "Pure" button on the remote.
JChin is offline
post #5 of 9 Old 07-17-2013, 03:35 PM - Thread Starter
BlueBear03's Avatar
Thank You, It has 5.1 in either game or movie now and 2.1 for music or pure. Is there a way to get the display to either stay on or light up without changing something?
post #6 of 9 Old 07-17-2013, 06:29 PM
jdsmoothie's Avatar
Quoted: 12087 Post(s)
Liked: 5502
The front panel display should only go dark when you're using the PURE DIRECT surround mode (which isn't recommended).
jdsmoothie is offline
post #7 of 9 Old 07-17-2013, 06:45 PM - Thread Starter
BlueBear03's Avatar
It goes black in any mode after a few seconds. It worked correctly when I first put the system together last week. Is there a sleep mode?
post #8 of 9 Old 07-17-2013, 06:51 PM
jdsmoothie's Avatar
Liked: 5502
That should only happen with PURE mode enabled, otherwise the front panel should be either ON or OFF ... anything in between is likely a defect issue ...
post #9 of 9 Old 07-18-2013, 01:25 PM - Thread Starter
BlueBear03's Avatar
jdsmoothie:
I guess I will have to print out the instructions and learn all the buttons. I hit dimmer once and all is well now. I appreciate everyone’s help.
Thanks Chris
