The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 100 - AVS Forum
post #2971 of 2977 Old Yesterday, 10:44 AM
Liked: 0
There's no problem using the external amp to power the FL/C/FR speakers but you do NOT want to connect the matching speaker posts on the AVR to the same speakers as well as doing so could cause damage.
Should I try out bi amp, I will use the external amp for the FL/C/FR and use pre-out with SR7008, and use SR7008 for the rear channels. And in Amp Assign, use 5.1ch(Bi-Amp) mode.
Is above correct?
Thank you very much JD!
Jim1290 is offline
post #2972 of 2977 Old Yesterday, 10:58 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 1018 Post(s)
Liked: 1505
That is correct. No problem if you set [AMP ASSIGN = 5.1/Bi-amp + Zone 2] and you use the Surr Back speaker posts to connect to the 2nd set of speaker posts on the FL/FR speakers (be sure to remove bar connecting both sets of speaker posts first though), although not likely to be beneficial.
"JD" –
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
; shop.avscience.com ; 585-645-1006, AVScience - Authorized dealer AVRs, Speakers, etc.
Mon - Fri: 10am – 10pm EST (Sat/Sun too if you leave message)
Call for pricing on Denon, Marantz, Yamaha, Def Tech, Atlantic Tech, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is offline
post #2973 of 2977 Old Yesterday, 11:15 AM
Liked: 0
I thought I just use channel 1 for HF and channel 2 for LF for the FL on the external amp, and use pre-out on the SR7008, and so on for the FR and C. The external amp is Classe CAV-150.
I will then use SR7008's Surround post for the two rear channels. Please correct me!
Jim1290 is offline
post #2974 of 2977 Old Yesterday, 12:06 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1505
So then, you want to use the external amp for all but your "side" surrounds (what you call rears) which you would use the SURROUND speaker posts on the AVR. Correct.
"JD" –
post #2975 of 2977 Old Today, 12:00 AM
Liked: 0
Thank you JD!
The CAV-150 can be bridged from 6 channels to 3 channels, so I thought to use the bridged 3 for the FL/C/FR, and use pre-out on SR7008, and put the surround on SR7008.
However, I don't know how to connect ML SL3 to the amp in bridged mode...
Perhaps it's better to leave everything as it is, and add more speakers in the near future.
I appreciate your time. Have a good weekend.
Jim1290 is offline
post #2976 of 2977 Old Today, 12:04 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1505
Adding more power isn't going to provide any benefit if the speakers don't need to use the extra power (ie. loud movie reference volume). Keeping your current configuration is likely your best option.
"JD" –
post #2977 of 2977 Old Today, 12:10 AM
Liked: 0
You working hard JD! It's 9 in the morning here in Europe.
I shall listen to your advise, and stop reading the bloody bi-amp thing.
Thank you JD, as always!
Jim1290 is offline
Marantz Sr5008 , Marantz Sr7008 , Marantz Sr6008
Gear in this thread - Sr5008 by PriceGrabber.com
