The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 109 - AVS Forum
post #3241 of 3266 Old 12-22-2014, 05:36 AM
joshking440's Avatar
JD I did do that. It allows me to get the unit back operational but back to the factory settings.
I do a quick set up test the network and try to update again with no luck. It does the exact same thing described above.
Is there another way to administer the update? As in download it to a laptop and install through a usb flash drive. I believe this would be my second update. I did one when I first got the unit early last year.
Thanks for the help
joshking440 is offline
post #3242 of 3266 Old 12-22-2014, 05:50 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 2312 Post(s)
Liked: 1833
No way to load update other than via network for USA models. Try setting the IGMP proxy setting on the router to OFF, otherwise try a different router.
"JD" – jd@avscience.com ; Direct line 585-645-1006, AVScience - Authorized dealer for AVRs, Speakers, etc.
Daily 8am – 8pm EST
Call for pricing - Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Atlantic Tech, Oppo
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #3243 of 3266 Old 12-23-2014, 10:28 AM
TobyR's Avatar
Than it's a no brainer, the SR7008 (vs 5009) is a much better choice even at $200 more.
Would this remain the case?
I can get them both within $150 dif. Replacing an SR5005 and am torn. I need almost none of the features of the 7008 but am considering it on essentially the Audyssey XT32 alone over a 5009. The 5009 wireless is superfluous for my needs.
65%/35% music/HT via 2.1/5.1 config in a 12x13x9 space.
Will be driving either Martin Logan 35XT/50XT; SVS Ultra Bookshelf/Center; or MA Silver 1/Centre all with SVS 1000 sub.
Toby
You can't take the sky from me …
TobyR is offline
post #3244 of 3266 Old 12-23-2014, 10:35 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1833
It's a personal call of course, but if the additional cost is in your budget, then the SR7008.
Daily 8am – 8pm EST
post #3245 of 3266 Old 12-23-2014, 12:06 PM
Liked: 0
I have a problem wire the Remote to the sr7008. It will not react when i try and change input channel etc. It shows a small line in the top right corner in the display on the remote. I have not had this problem before. Any ideas?
Ragepoo is offline
post #3246 of 3266 Old 12-23-2014, 12:48 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1833
Yup. It means you have Zone 2 turned ON and selected on the remote. Turn Zone 2 OFF.
Daily 8am – 8pm EST
post #3247 of 3266 Old 12-23-2014, 01:54 PM
Liked: 0
My son is in trouble now :blush: thx
Ragepoo is offline
post #3248 of 3266 Old 12-23-2014, 01:59 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1833
Take it as a learning moment for you both.
Daily 8am – 8pm EST
post #3249 of 3266 Old 12-23-2014, 11:39 PM
steveting99's Avatar
Quoted: 411 Post(s)
Liked: 138
TobyR,
Have a read of Keith Barnes article on the difference between Audyssey XT and XT32 here: "Official" Audyssey thread (FAQ in post #51779). FYI, that write-up was enough to convince me to step up to XT32 and not go with a inferior REQ.
Maranatz SR-7009(on order), Oppo BPD-93, MTV 7000D, LG LW6500, aTV, WDTV Live, Harmony 650 remote, KEF E301, MiniDSP(2x4), Rythmik F12G
steveting99 is offline
post #3250 of 3266 Old 12-24-2014, 04:13 AM
Quoted: 58 Post(s)
Liked: 4
Better audyseey = better sound, plus your resale value will be better with the 7008.that said I settled on the 7008 vs the 7009 because I don't value Dolby Atmos or care about wifi for the xtra money. I mean your already spending over 1k I assume anyways, whats another 150$ for a better product
Federo5 is offline
post #3251 of 3266 Old 12-24-2014, 04:20 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1833
In addition to Dolby Atmos and Auro 3D and built-in Wifi/Bluetooth, the SR7009 also features Smart Select buttons (aka Quick Select on Denon AVRs) which are custom settings for up to 4 sources in each zone. It also features custom 2CH stereo settings (LARGE/SMALL, volume, crossover, subwoofer (Y/N)) formerly only on the Denon AVRs as well.
Daily 8am – 8pm EST
post #3252 of 3266 Old 12-25-2014, 06:37 AM
Ok 3 routers later no luck.
Here is something I notice. If I cycle the power on the unit now and test the internet connect I get no router access. I unplug and plug in the Ethernet cable only and retest I'm back in business. But yet still as its authenticating the update after a minute or 2 it shuts the unit off and then tries to reinstate the update resulting in no connection 0e.
I'm now plugged directly into my comcast xfinity cable modem.
post #3253 of 3266 Old 12-25-2014, 02:17 PM
Astralmind's Avatar
Hi,
Just setup my new 7008, extremely pleased, obvious improvement over my Onkyo 805.
I'm a bit confused regarding the setup with my HTPC though, any help would be greatly appreciated.
I configured the setup in Windows 8.1 to 5.1 with small speakers all around (got Totem Rainmakers) as well as 24bits 192 kHz playback.
I can get bitstream no problem for DD DTS HD + etc.. However, I just played back some regular mp3 (stereo) and the display constantly shows up as PCM multichannel 5.1 and in fact, my surrounds were working (loud at that!) and so was the center. Pressing the sound mode button didn't do anything, no cycling through
Astralmind is offline
post #3254 of 3266 Old 12-25-2014, 02:21 PM
585-645-1006
jdsmoothie's Avatar
Liked: 1833
If the display reads MULT CH IN, then your HTPC is indeed passing a 5.1 PCM signal.
Daily 8am – 8pm EST
post #3255 of 3266 Old 12-25-2014, 08:52 PM
Astralmind's Avatar
hmm so in this case it's VLC creating the additionnal streams ? After all the original source was strictly stereo and when I listen to lets say, a youtube video, it does come out only in 2.1 (even though the receiver displays Multi Ch in).
I wonder why it does that.
post #3256 of 3266 Old 12-26-2014, 07:30 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1833
Some TV stations do something similar .... broadcast a stereo 2.0 signal over a DD 5.1 audio track.
Daily 8am – 8pm EST
post #3257 of 3266 Old 12-26-2014, 04:08 PM
TobyR's Avatar
Originally Posted by steveting99 View Post
TobyR,
Outstanding referral. Thanks! It does appear significantly divergent.
Toby
TobyR is offline
post #3258 of 3266 Old Yesterday, 12:26 AM
Quoted: 58 Post(s)
Liked: 4
Meh, that's just semantics, I only use it in one room with 3 speakers up front , not the 9 up front for Auro. I could of got the 7009 and intended on it, didn't care about the money. The only thing I don;t like is the remote is cheap. First one the scroll up button got stuck within a week, now this one squeaks sometimes. I would also appreciate a little colour/quick buttons. I had a 5006 Marantz a few years ago and actually preferred that remote much more. Is it possible to purchase another models remote for the 7008. I don;t like this one that much
Federo5 is offline
post #3259 of 3266 Old Yesterday, 12:30 AM
Quoted: 58 Post(s)
Liked: 4
The CBC in Canada does this. I noticed during hockey games, the center speaker is silent but they are saying it's dolby digital during hockey night in Canada.
Federo5 is offline
post #3260 of 3266 Old Yesterday, 06:44 AM
rodneyiii's Avatar
Press/hold the MOVIE+MUSIC buttons while powering on the AVR.
Only do this if you are prepared to lose ALL of the settings in the AVR. It is not just a Network card reset but a complete system reset. Make sure you back up the system using the procedure in the manual before resetting the system.
rodneyiii is online now
post #3261 of 3266 Old Yesterday, 06:57 AM
Quoted: 58 Post(s)
Liked: 4
I have a question about bi-amping. For the two months I have had my receiver, when I originally set it up I spoke with Marantz themselves on the phone to make sure I had the proper set ups for bi-amping. i was told to hook up one set of wires from my fronts to the front left and right and the other two to SURROUND BACK to bi-amp which is along the same row. I was just looking through the manual now and bi-amp shows that instead the second set of wires should go on FRONT WIDE that are above the front height on the marantz 7008 under "assignable". Did they inform me incorrectly and should I switch this immediately?. I have a 5.1 set up with a svs subwoofer and all speakers set at 80hz and a lfe of 120 hz.
Update, I switched the front lefts to what the manual says for bi-amp connecting to the front wide and ran the level noise and it was very tinny and quiet so I guess the manual is for 7.1 biamp. Not sure, I'll leave as it was. Any ideas?
Federo5 is offline
post #3262 of 3266 Old Today, 06:43 AM
Tom Riddle's Avatar
Quoted: 96 Post(s)
Liked: 100
7008 owners, what Audyssey settings do you find most preferable for movies? I believe Audyssey Flat is for music, correct? Any feedback is appreciated.
Klipsch RF-62 II HT System
SVS Ultra
Marantz SR7008
Emotiva XPA-5
Samsung PN64F8500
Panasonic 65VT30 (Master Bedroom)
Tom Riddle is offline
post #3263 of 3266 Old Today, 07:19 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1833
With only a 5.1 setup, either connection is acceptable, rather just depends on which AMP ASSIGN setting you use:
7.1 (Bi-amp) = Front Wide posts used
5.1 (Bi-amp) + Zone 2 = Surround Back posts used
Daily 8am – 8pm EST
post #3264 of 3266 Old Today, 07:27 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1833
Although Audyssey Flat is technically designed more for music/smaller rooms, some have posted of preferring it for movies as well.
Daily 8am – 8pm EST
post #3265 of 3266 Old Today, 08:37 AM
William K's Avatar
I have a quick question about Marantz audio...With all of the reviews I've seen lately about the Marantz audio being better than the Denon because of better internal parts (HDAM) or whatever. Coming from a Denon X4000 listening to flac files on my pc via ethernet cable would I be able to hear any difference in sound quality between the 4000 and the 7008? I have been using my receiver for mainly audio as of late.
William K is online now
post #3266 of 3266 Old Today, 09:42 AM
585-645-1006
jdsmoothie's Avatar
Liked: 1833
Perhaps better with 2CH analog audio, otherwise pretty much the same would be expected.
Daily 8am – 8pm EST
Marantz Sr5008 , Marantz Sr7008 , Marantz Sr6008
