The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 124 - AVS Forum | Home Theater Discussions And Reviews
 153Likes
Old 04-05-2015, 08:28 PM
Liked: 0
Hi Gents, I am new here, and I just bought a set of audio equipment, and I need your advice how to set things.
My inventory is this:
  • Polk Audio 275-Watt Tower Speaker (TSi500)
  • Polk Audio Bookshelf Speaker (TSi200)
  • Polk Audio Center Channel Speaker (CS20)
  • Polk Audio PSW125 12-Inch Powered Subwoofer
  • Marantz 9.2 Channel A/V Network Receiver (SR7008)
Any advice for setting them up, gauge wires, bi-crossing, any experience with the receiver and the speakers, any cautions are welcomed.
Thank you!!
bitolamkd is offline
Old 04-06-2015, 01:50 AM
steveting99's Avatar
Quoted: 1798 Post(s)
Liked: 615
Thank you!!
Hi bitolamkd,
Welcome to AVS!
Post number 3,367 shows the basic 5.1 layout that you want to your speakers to be set up as, the same diagram is available in your Marantz SR7008 owner's manual.
What you want to do is setup the front sound stage consistiing of the front left, center and front right so that it forms an equilateral triangle to your Main Listening Position (MLP). This will give you the best stereo imaging for music playback as well as a smooth panning for films. Aim for the angles shown in the pictures. Your front Polkies are very efficient (91dB/W/m) so not alot of power is needed to drive them to reference levels of 105dB peak.
The LFE channel is another matter. The Polk sub (PSW125) has a 12" driver and it's -3dB point is rated for 34Hz. This can be an issue for movies where 20Hz and below information is available in the soundtrack and your PSW125 may struggle reproducing it.
How big is your room? Front to back, side to side and floor to ceiling dimensions please. A rough sketch of your room, speaker layout and MLP would be useful. The idea is to place the front left and front right speakers to give the best stereo imaging. The sub needs to be placed where there is the best bass response. The best bass response is dependent on where the MLP is and where the sub is going to be. Do a sub crawl test shown in Axiom Audio's youtube video and linked in jdsmoothie's 2014 Denon receiver thread to determine some good locations where the sub can be placed.
If you haven't done so, have read of the Audyssey FAQ done by AVS member Keith Barnes. It contains a wealth of useful information in getting the room correction setup properly. It is highly recommended to grab the boom stand mic and adapter when doing the Audyssey auto calibration.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
Old 04-06-2015, 06:01 PM
gce
gce's Avatar
Quoted: 45 Post(s)
Thank you!!
If you want TON's more info on you Polk setup go here. http://forum.polkaudio.com/ but don't bring your wallet!
gce is offline
Old 04-06-2015, 08:28 PM
Liked: 0
Thank you for your replies, I will post room layout and listening area measurements.
Bit
Liked: 0
Thank you
Old 04-06-2015, 08:29 PM
Liked: 0
I'll check that out!
Old 04-06-2015, 09:47 PM
Liked: 0
Here is the room layout:
Thank you for the advices guys!!
Old 04-07-2015, 08:17 AM
Tweaked05's Avatar
Quoted: 42 Post(s)
Liked: 26
Could be HDMI handshake issues or possibly just a loose HDMI cable seating.
I think I have resolved the issue. I have a cable that was just a hair too short going from my receiver to the TV in the wall, so the connection was a bit tight. I added an HDMI extender cable and watched netflix all evening on my Xbox One without a single blank out. I hope that resolved the issue. It was getting so annoying.
Tweaked05 is offline
Old 04-07-2015, 08:50 AM
TurboTropic's Avatar
Quoted: 38 Post(s)
Liked: 24
Towers either side of the screen. Bookshelfs on the walls, 2-3 ft above seated head height, a little behind the rear of the couch and towed in a little if possible. Subwoofer wherever you like but it's best to do the "subwoofer crawl" to find the best spot. Assuming the screen is not acoustically transparent, centre speaker should go below and angled up a little.
If you could move the couch away from the wall it would be better in my opinion.
Optoma HD131xe on 106" Accuscreens 16:9 pull-down screen
Marantz SR7008 AVR / XBox One / Sony BDP-5200 / Mac Mini / Synology 212j NAS / Pioneer BDP-320 (used as CD player) / Kodi box
ELAC B5 fronts / ELAC UC5 centre / Polk Monitor30 Series II heights / Monoprice in-wall 5-1/4 Inch surrounds / SVS SB12-NSD sub
TurboTropic is offline
Old 04-07-2015, 08:59 AM
jdsmoothie's Avatar
Quoted: 12279 Post(s)
Liked: 5598
Glad to hear it was resolved. Thanks for reporting back with your resolution.
jdsmoothie is offline
Old 04-07-2015, 01:18 PM
mthomas47's Avatar
Quoted: 2525 Post(s)
Liked: 3141
Originally Posted by sebdub View Post
Guys I'd really appreciate if somebody with a premium Spotify account could confirm the app is working on their Marantz SR (ideally 6008, but I guess it's the same software everywhere).
It stopped working for me somewhere around the most recent firmware update, so I'm trying to find out if other people are experiencing the same problem.
I hadn't checked the thread in a while, so I hope this information is still useful to you, but Spotify is working fine on my 7008.
mthomas47 is online now
Old 04-07-2015, 10:49 PM
Liked: 615
Hi bitolamkd,
TurboTropic has given some good suggestions. I would just add the following.
If possible, keep the vertical separation of the tweeters on the center channel with the front left and front right within 2'.
Your room is odd shape and difficult to determine the room volume with the limited dimensions shown. Are you able to estimate what the room volume is? If the total volume is more than 4,500 cu. ft. it is considered a large room. Again your Polk Audio PSW125 may struggle. You would need large drivers and multiple subs to pressurize the room. The main benefit of multiple subs is minimizing the peaks and nulls within the bass frequency response (before Audyssey room correction filters are applied) so that the overall response is smoother. There is no effective way in dealing with room nulls using a single sub.
Old 04-09-2015, 07:12 AM
tim leonhardt's Avatar
has anyone gotten Flickr to work?
tim leonhardt is offline
Old 04-10-2015, 05:51 AM
Quoted: 38 Post(s)
Liked: 24
Liking the 7008 a lot so far - only had it a couple of days - and it's been pretty easy to set up. Looking forward to spending more time with it this weekend.
One question - does the second HDMI output need to be the same resolution as the main? E.g. 1080p projector on primary HDMI output, 720p TV on the 2nd.
Old 04-10-2015, 07:28 AM
jdsmoothie's Avatar
Liked: 5598
Depends on whether you are referring to the 2nd Main zone output or the Zone 2 HDMI output. If the former, yes, otherwise both outputs will be only 720p. If the latter, same as above if passing the same HDMI source to both zones, otherwise, no if passing a different HDMI source.
Old 04-10-2015, 07:33 AM
Quoted: 38 Post(s)
Liked: 24
Thanks JD. it's the former that I was thinking of.
Old 04-10-2015, 08:00 AM
zoepup's Avatar
Quoted: 125 Post(s)
Liked: 38
Hey everyone. Long time marantx owner here. I currently have an SR7200 and SR6003 in my collection. I am building a media/theater room that is about 21x26 ft. The support beam runs down the middle, thus making a fake division of 13x21 and 13x21. One side will be the media/theater; the other an entertainment/game area. Current speakers are Mirage 7si with LF-150 sub. I am looking at a range of new speakers to demo on site. The short list: GoldenEar Aon3, Wharfdale Jade 3, Paradigm Signature or Prestige. For towers I will demo Sonus Faber Venere 2.5, Martin Logan EML, Magnapan 1.7 and a Canton set. I am looking at HSU and SVS subs (thanks to this board). I might still keep the Mirage (replace sub). The TV will probably be a 4k LED (dam the end of the F8500 plasma). Not sure 4k is important to me at the moment.
How does the SR7008 handle low impedance speakers? I also have a Halfer DM220 Amp that I could probably use but that seems like a waste. Anyone driving any of the above speakers with the Sr7008? What limitations will I have with 4k video?
I see a4less has the sr7008 at a great price.
MY Build in Progress >>> My Home Theater Build
Living Room: Samsung PN60F8500, KEF 3005 5.1, Marantz SR6003
HT: Marantz SR6010 AVR, 2-PSA XS30se subs, Samsung 65" JS8500 4k, Sonus Faber Venere 2.5, Venere Center and Walls, Sony 77es CD changer, Sony BDP-BX2 Blue Ray
In storage: Mirage M7si, Mirage LF-150, Marantz SR7200
zoepup is offline
Old 04-13-2015, 07:08 PM
mjoc13's Avatar
Hi all,
Reading countless pages and am considering the sr7008 at the current clearance price.
I know this will be subjective, but is this still an ARV worth considering with the tech of today - with knowing HDMI 2.0 and HDCP 2.2, atmos/dts:x, etc?
Thanks and any input into my conundrum is appreciated!
cheers
mjoc13 is offline
Old 04-13-2015, 07:20 PM
jedi1982's Avatar
Quoted: 55 Post(s)
Liked: 29
the SR7008 has been a great receiver for me (aside from my 1st was a lemon). regarding your points about the potential "future proofing" with newer tech coming out, honestly I'd say unless you plan on getting 16 speakers in the near future to fully take advantage of Atmos, get the 7008
jedi1982 is offline
Old 04-13-2015, 08:57 PM
Liked: 0
SR5008 HDCP errors
I bought an SR5008 several months ago and have been using it with no problems until this evening.
I mostly use 2 devices connected to my receiver. an Apple TV and a PS3. When I try the Apple TV, I can navigate menus and so forth, but if I try to play back any video content, I get an error stating:
"This content requires HDCP for playback. HDCP isn't supported by your HDMI connection."
If I switch over the the PS3, there's just a black screen. Since the Marantz background isn't displayed, I assume that the signal is there.
Both players work if I connect them directly to my TV and I have rotated all the HDMI cables around.
All of this worked yesterday.
The troubleshooting I have done leads me to believe that the issue is with the receiver.
Am I missing anything?
Any suggestions or known workarounds?
Tardcore is offline
Old 04-14-2015, 03:43 AM
jdsmoothie's Avatar
Liked: 5598
Sometimes, the power on sequence can avoid HDMI handshake issues. Try powering on the TV first, wait a few seconds, AVR, wait a few seconds, and then finally the source device, allowing enough time between each power on for the previous device to fully power on. You may also want to try a HDCP reset as I list in the post below ....
The 'Official' 2014 Denon "S Series" / "X Series" AVR Model Owner's Thread & FAQ
Old 04-14-2015, 03:53 AM
jdsmoothie's Avatar
Liked: 5598
Originally Posted by mjoc13 View Post
Hi all,
cheers
If you plan on purchasing a 4k TV and HDMI 2.0/HDCP 2.2 Blu Ray player, the work around would be to purchase a dual HDMI BDP in order to pass the video to the TV and audio to the AVR. Otherwise if not planning on placing "height" speakers for Dolby Atmos or Auro 3D, the SR7008 uses the same version of Audyssey MultEQ XT32. AV Science still has one left which would also come with a free Denon HEOS Link ($349 MSRP) which can be used to stream audio to wireless Denon HEOS speakers placed in other rooms or to stream audio to another AVR using the speakers connected to the AVR. Call for more information and pricing if interested.
Old 04-14-2015, 07:50 AM
Liked: 0
Thank you for the tips. That sequence is basically how my system typically starts up today (via HDMI control), but I will disable HDMI control and give it another try in sequence before I move on to the HDCP reset.
Tardcore is offline
Old 04-14-2015, 05:20 PM
vodil's Avatar
Quoted: 86 Post(s)
Liked: 27
Question Hookup with new 4K Smart TV
I have an SR7008 (and Oppo 103d) and am planning to get a new UHD Smart TV so I can see 4k content from DirecTV, netflix, amazon etc. (I use a Harmony remote.)
How to hook it up?
Currently all devices go into the 7008 and the TV is just a display, but with the new Smart UHDs they have plenty of HDMI inputs and suggest putting all video sources into them and piping the audio out from the TV. The TV will be HDMI 2.0 whereas the 7008 is not quite.
vodil is offline
Old 04-14-2015, 05:24 PM
jdsmoothie's Avatar
Liked: 5598
The only video you need to pass to the TV directly would be a 4k/60Hz/HDCP 2.2, otherwise you can pass 4k/30Hz, 1080p and lower resolution directly to the AVR. However, in every case, audio should go directly to the AVR and not come from the TV which in many cases is limited to only 2CH stereo.
Old 04-16-2015, 06:37 AM
Quoted: 38 Post(s)
Liked: 24
Need to do a bit more investigation but maybe someone browsing here has a solution.
I hooked up height speakers the other day. Played music for the first time last night using PLiiz. The center channel was much louder than any other channel. Tried DSX and Neo:X too and although less pronounced the centre was still louder.
I need to rerun Audyssey when it gets quiet around here anyway but I checked speakers distances and levels and the centre hadn't changed in any way.
Thoughts? Or is this how the height processing is supposed to sound?
Old 04-16-2015, 07:39 AM
jdsmoothie's Avatar
Liked: 5598
Not sure what you're asking here? If you run Audyssey, all speakers are set to the same volume level at the main listening position (ie. mic #1 position). The Height speakers are for ambient audio and generally don't get much audio. If you want any speaker to be more pronounced, simply use Manual Setup - Test Tones and raise the speaker volume a few db.
Old 04-16-2015, 10:20 AM
jmh547's Avatar
Quoted: 111 Post(s)
Liked: 37
Hello all
I am pickingup a second hand 5008 tonight to replace my Dennon AVR-591. I am very excited this is my first venture into Marantz. Obviously I plan to listen to it before purchasing but I was just curruious if there is anything specific I should look for before money exchanges hands?
jmh547 is offline
Old 04-16-2015, 11:15 AM
jdsmoothie's Avatar
Liked: 5598
Have the seller reset the microprocessor and test it for you.
Old 04-16-2015, 12:33 PM
Liked: 0
Having issues with quality of Apple lossless files as compared to CDs. My setup is a SR7008 in AV room, SR7007 in kitchen for rest of house, Windows 7 laptop, iTunes, NAS server (Seagate), gigabyte switch for the home network, CAT6 cable everywhere, AirPlay from laptop, and my CDs ripped to ALAC (Apple lossless) with error correction and the highest resolution possible. Music is routed into network connection on back of both AVRs. Sound quality is not WAV quality (can hear less detail in cymbals, etc.). Is it the DAC in the Marantz that's the shortcoming? Would HDMI be better than then network connection? Specs for SR7008 say the DAC supports 192 kHz/24-bit but is that for ALAC as well as WAV and FLAC? Specs for SR7007 say that ALAC files are only supported at 96/24. Thanks!
TigerChicago is offline
Marantz Sr5008 , Marantz Sr7008 , Marantz Sr6008
