The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 129 - AVS | Home Theater Discussions And Reviews
post #3841 of 3857 Unread 05-14-2015, 09:23 AM
kwolfskill's Avatar
Liked: 1
Is it possible to use a physical keyboard with the SR5008?
Sorry if this has been discussed else where, I've looked and didn't find the answer.
I use the Spotify a lot on my SR5008 and it is a pain to enter a song or album title, or artist name, to search for in Spotify, using the virtual keyboard. I've yet to find a way to use a physical keyboard with my receiver, but was hoping someone else has. Not only would a physical keyboard be faster to type on, but it would save the life of the cursor keys on my remote, which I'm sure I'm using much more than normal by using the virtual keyboard all the time.
mBkS likes this.
kwolfskill is offline
post #3842 of 3857 Unread 05-14-2015, 02:27 PM
Liked: 0
DeRemote is pretty cool App as well
itsf8 is offline
post #3843 of 3857 Unread 05-15-2015, 09:56 AM
mthomas47's Avatar
Quoted: 194 Post(s)
Liked: 136
I haven't found a better way to do searches via the remote, but I agree that is a very cumbersome procedure. What I do is search, add/delete songs, create new playlists, etc. on my desktop. I believe you have to be a Spotify Premium member to access Spotify on your Marantz. If you are, you can add devices to your account, including a desktop, laptop, or smart phone. And any of those would make searching easier.
Mike
mthomas47 is offline
post #3844 of 3857 Unread 05-15-2015, 11:52 AM
kwolfskill's Avatar
Liked: 1
Mike
I do the same, but it is clumsy to have to save them using my Spotify account on my laptop, just so I can access them on my receiver. Would rather be able to do it all from my receiver.
Kevin
post #3845 of 3857 Unread 05-15-2015, 06:00 PM
steveting99's Avatar
Quoted: 803 Post(s)
Liked: 239
^ Try the iDevice mobile/tablet version of Spotify. The search and creating a playlist is easy to do. You can then stream your tunes to the receiver as the Marantz models have Airplay.
Edit: You don't even need to have premium subscription with Spotify with the iDevice to stream via Airplay to the Marantz.
Maranatz SR-7009, Oppo BPD-93, MTV 7000D, LG LW6500, aTV, WDTV Live, Harmony 650 remote, KEF E301+T101, MiniDSP(2x4), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8 (on order), HiMedia Q16 (on order).
Last edited by steveting99; 05-15-2015 at 06:29 PM. Reason: additional text for clarity.
steveting99 is offline
post #3846 of 3857 Unread 05-17-2015, 02:37 PM
mart541's Avatar
A couple weeks ago I noticed that when I turned on my 5008 my sub would put out this soft low rumble/hiss and after a couple minutes it would pop, like you might hear through speakers when you turn on the amp, then the sub would operate as normal. I don’t believe it’s a ground loop issue as I had one when I first hooked up my system but fixed it.
Today, I noticed that a similar rumble/hiss was coming from my mains so turned off my sub and did a factory reset on the 5008. When I turned off the sub there was a pop a bit louder than before. When I turned the 5008 back on and entered Audyssey setup it couldn’t find the sub. I connected the sub to my laptop and the setup software couldn’t connect, saying the sub was off or in standby, and I couldn’t get the status led to switch from red to green. Dead sub?
So I go back to the receiver and unplug all the inputs. Strange sound still coming from the mains. I unplugged literally every electrical item in my entire apartment except the receiver and the sound was the same. I pull out a stereo amp and switch to the preouts, through the amp. Sound remains. At this point I’m worried about somehow killing my speakers so have unplugged everything and am planning to send the sub and receiver in for repair.
Is this any type of known issue? Is it possible for the receiver to kill the sub or the other way around?
mart541 is offline
post #3847 of 3857 Unread 05-21-2015, 01:45 PM
Quoted: 122 Post(s)
Liked: 6
Hey guys, just a quick Q
Will increasing the "digital input" DB level in the "source level" part of my receiver distort the sound at a louder level. What exactly is this increasing that is different than just increasing the level of each speaker. Increasing the digital input by 3db seems to be a lot louder of an increase than increasing my master volume by 3db. Thanks!
Federo5 is offline
post #3848 of 3857 Unread 05-21-2015, 02:45 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 3970 Post(s)
Liked: 2248
Increasing the Source Level should be similar to raising the master volume.
Federo5 likes this.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #3849 of 3857 Unread 05-22-2015, 08:52 AM
mthomas47's Avatar
Quoted: 194 Post(s)
Liked: 136
JD,
Are you sure about that? This same question was asked on another thread. If you increase the individual level of each speaker by 3db, I believe that the sum of the increase is greater than would be experienced just by increasing the MV by 3db. I can't remember if there is a specific formula for this, but I'm pretty sure that multiple speakers do sum just as multiple subs do. So, starting with all of your speakers at 75db, for instance, and then raising the MV by 5db, would not give you the same measured volume at the MLP as setting all of your speakers at 80db. I could be completely wrong about this, but if I am I would like to know for sure.
Mike
post #3850 of 3857 Unread 05-22-2015, 09:17 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2248
Yup. I'm sure. Changing the Master Volume is the same as changing all speakers the same amount.
mthomas47 likes this.
post #3851 of 3857 Unread 05-22-2015, 09:54 AM
bhoyo68's Avatar
Liked: 0
Hi,
I was wondering if some one can help? I have a Pioneer dv47ai hooked up to a sr5008 through the 7.1 analog connections (sacd/dvd-a playback) and also a coaxial cable for cd playback.
My problem is when I go to listen to cd's through the digital out I get no sound?
Only sound through analog cables (2 channel) is there a setting in the receiver I have change to get sound through the digital out on the same source input?
Any help would be greatly appreciated.
Pat
bhoyo68 is offline
post #3852 of 3857 Unread 05-22-2015, 10:04 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2248
Yes, there is. When using the same source name for multiple inputs, you must change the INPUT MODE (p. 157 Owner's manual) setting accordingly.
post #3853 of 3857 Unread 05-22-2015, 10:11 AM
bhoyo68's Avatar
Liked: 0
Thank you so much.
Regards
Pat
bhoyo68 is offline
post #3854 of 3857 Unread 05-22-2015, 08:01 PM
bhoyo68's Avatar
Liked: 0
Hi jdsmoothie,
Thanks again for the help. I have another quick question:
Do I manually have to change the input mode every time between analog and digital?
(sacd/analog) (cd/digital)
Or if I set the input mode to Auto will it switch on its own depending on the media source?
Thanks Pat
bhoyo68 is offline
post #3855 of 3857 Unread Yesterday, 01:04 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2248
Originally Posted by bhoyo68 View Post
Hi jdsmoothie,
Thanks Pat
Manually switch each time so you may simply want to use a different source name for each input.
post #3856 of 3857 Unread Today, 12:26 AM
vanquished79's Avatar
So, my six months old SR7008 has no sound from today. When I turn it on it clicks only once, when it wоrking it clicks two or three times when starting. I tryed factory reset with no result. Any suggestions?
vanquished79 is online now
post #3857 of 3857 Unread Today, 02:51 AM
585-645-1006
jdsmoothie's Avatar
Liked: 2248
Unplug the power cord and all sources for 10 minutes. Plug only the power cord back in. Reset the microprocessor a few times in a row. Does the AM/FM Tuner play? If not, next step would be to call Marantz for repair under warranty.
Marantz Sr5008 , Marantz Sr7008 , Marantz Sr6008
