The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 131 - AVS | Home Theater Discussions And Reviews
post #3901 of 3904 Old Yesterday, 07:57 AM
mjoc13's Avatar
As always, thanks everyone for the feedback, much appreciated.
I did use a tripod from my camera for the calibration, it's possible i exited out of the procedure prematurely, but i don't recall any prompt to reposition the mic.
That's a great point about the position of the center, as it's on a shelf a couple feet below ear level.
Once i have some more time without the kids running around, I'll redo everything and report back.
thanks again!
mjoc13 is online now
post #3902 of 3904 Unread Today, 07:58 AM
mjoc13's Avatar
Hi Everyone,
I reran audyssey with all 8 postions (not sure what i did last time).
looking at the results i have some questions.
1) just calibration i had to adjust the sub to the correct db, although i do not have a volume, i adjusted the gain and xover freq until it was in the green - it did seem very low. The cali put it at 22.8 ft away from MLP, although it's beside my left front at 11.4ft from MLP. Does that seem correct?
2) defected fronts as large, should i keep them there?
3) the x-overs for front at full band, center is 80, surround is 120. Does that seem accurate?
My speakers are a house brand - 8ohm
Sub is a klipsch synergy 12
As always, input is appreciated.
Cheers!
post #3903 of 3904 Unread Today, 08:41 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 4104 Post(s)
Liked: 2273
1. After running Audyssey, most prefer to use the Manual Setup - Test Tones - Subwoofer and raise the level up about +5db. The sub "distance" is generally longer than the actual distance as it accounts for filters used in the sub.
2. Use Manual Setup to reset speakers set to LARGE to SMALL/80Hz which provides more headroom for the AVR and lets the sub handle what it does best.
3. Yup, although certainly doesn't hurt to run Audyssey a few more times over a period of weeks using slightly different mic positions to see if you prefer one Audyssey run over another.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is online now
post #3904 of 3904 Unread Today, 08:45 AM
mjoc13's Avatar
thanks JD, as always
Marantz Sr5008 , Marantz Sr7008 , Marantz Sr6008
