The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 137 - AVS Forum | Home Theater Discussions And Reviews
post #4081 of 4086 Old 08-23-2015, 01:36 PM
jdsmoothie's Avatar
Quoted: 5132 Post(s)
Liked: 2624
Originally Posted by red5goahead View Post
Thanks ok but is it working for example on a five channels output or only for two channels, the front ones? So the question is can I benefit from it when playing a dts or Dolby digital audio through all speakers?
As the DTS/DD processing would require passing through the DAC ... most likely yes, however, whether you would notice an improvement upgrading to the SR7009 is not certain.
2015 Denon AVR thread ----> http://www.avsforum.com/forum/90-rec...dcp-2-2-a.html
Think your AVR is defective? Check the Owner's manual and do a factory reset 4-5 times if necessary.
jdsmoothie is online now
post #4082 of 4086 Unread Yesterday, 09:06 PM
Ed Zeppeli's Avatar
Well it looks like my second SR7008 has toasted itself. I've had this one since May.
Odd symptoms though; a few days ago it started not recognizing Dolby Digital sources intermittently and would just default to stereo. Today it went into shutdown. I unplugged it for about ten minutes, plugged it back in and get no audio.
I did a factory reset, ran through a few settings and am getting zero output from the speakers. No audio from multiple sources and no test tones.
Anything else I should try before sending it in?
Warren
Ed Zeppeli is online now
post #4083 of 4086 Unread Today, 02:28 AM
jdsmoothie's Avatar
Liked: 2624
You could try doing 4-5 factory resets in a row, otherwise, if still no joy, repair time.
post #4084 of 4086 Unread Today, 09:32 AM
Ed Zeppeli's Avatar
Back in action! Thanks
post #4085 of 4086 Unread Today, 10:35 AM
jdsmoothie's Avatar
Liked: 2624
Wohoo!! And folks wonder why I have the suggestion in my sig.
post #4086 of 4086 Unread Today, 11:00 AM
nesto719's Avatar
Would anyone recommend using a external dac with the 7008??
SAY HELLO TO MY LITTLE FRIEND.
nesto719 is online now
Marantz Sr5008 , Marantz Sr7008 , Marantz Sr6008
