The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 156 - AVS Forum | Home Theater Discussions And Reviews
 148Likes
post #4651 of 4673 Old 11-29-2016, 11:28 AM
Tgterm's Avatar
Quoted: 161 Post(s)
Originally Posted by kevinf1990 View Post
Today I got the request to update my Marantz SR6008 receiver's firmware. It appears it was for the pandora login issue. I granted permission to update and I keep seeing the following messages:
EIMG: 03min
EIMG: 02min
EIMG: 01min
EIMG: 03min
EIMG: 02min
The receiver then shut down and restarted and said Update retry, after a while it would make a loud click and shut down then reboot. Any idea how this happened? I had a hardwire ethernet connection to the receiver so not sure how the update could be corrupted.
I attempted to reset the microprocessor by holding the M-DAX and ZONE2 SOURCE and then hold power button down. The screen kept flashing (all pixels) in sync with the other LEDs on the front fascia.
I don't know what to do now. I am hoping that the receiver is not beyond repair. Any help would be appreciated.
thanks
That's a bit scary. Please keep us posted on whether you are able to resolve this? I was planning to check on the update for my 7008 when I got home tonight...but...
Sent from my SM-G920V using Tapatalk
Tgterm is online now
post #4652 of 4673 Old 11-29-2016, 11:29 AM
Tgterm's Avatar
Quoted: 161 Post(s)
Do a Network Reset by pressing/holding down the Preset CH+/Preset CH- buttons while powering on the unit.
JD...any thoughts on what might have gone wrong here? Thanks.
post #4653 of 4673 Old 11-29-2016, 11:33 AM
jdsmoothie's Avatar
Quoted: 11138 Post(s)
Liked: 5142
Nope. Likely just a one-time glitch.
jdsmoothie is offline
post #4654 of 4673 Old 11-29-2016, 12:50 PM
tang7969's Avatar
Quoted: 234 Post(s)
Liked: 150
EIMG: 03min
EIMG: 02min
EIMG: 01min
EIMG: 03min
EIMG: 02min
thanks
Sorry to hear that you have problems with the update.This is exactly why I wait to do any updates. Is your problem now fixed?
SAMSUNG UN607150- OPPO BDP 103D- PSA 210T L/R -PHANTOM CENTER -ENERGY RC-10 SURROUNDS -PSA S3000i - MARANTZ SR7008 - APPLE TV -MONSTER POWER HTS2600MK -DIRECTV GENIE -HARMONY ELITE
BASEMENT SETUP- SAMSUNG UN466500- ENERGY 50'S L/R - DENON-AVR-3311CI- PS3 -APPLETV- MINI GENIE
tang7969 is online now
post #4655 of 4673 Old 11-29-2016, 01:05 PM
kevinf1990's Avatar
Quoted: 20 Post(s)
So doing this procedure should get me out of this loop? I am currently at work so I can't try this out yet.
kevinf1990 is offline
post #4656 of 4673 Old 11-29-2016, 07:19 PM
jnnt29's Avatar
Quoted: 108 Post(s)
Liked: 127
I was able to successfully updated my 7008 and Pandora works as it was supposed to. yay!
My set up
Marantz SR-7008, Emotiva XPA-3
Samsung UBD-K8500 Ultra 4K Blu Ray Player
Klipsch RB-81II, RC-52II, Boston Acoustics Micro 120s
Klipsch SW-310, RPW-10, Samsung UN65JS8500FXZA
http://www.avsforum.com/avs-vb/showthread.php?t=1227096
jnnt29 is offline
post #4657 of 4673 Old 11-30-2016, 04:34 AM
greenfx5's Avatar
And I also was finally able to update my SR7008 this morning. I'm glad to get back to using Pandora directly though the receiver, rather than using Airplay or the RS101.
greenfx5 is offline
post #4658 of 4673 Old 11-30-2016, 05:13 AM
Tgterm's Avatar
Quoted: 161 Post(s)
Sr7008 update successfully executed this AM, and now back to pre July functioning!
post #4659 of 4673 Old 11-30-2016, 09:38 AM
Hans Hilpert's Avatar
Having an issue connecting my PS4 Pro to my samsung JS8500 Thru my Marantz SR5008. The Marantz won't pass 4K. When I do a direct connect to my TV it produces 4K no issues. Is there a setting I need to set on the Marantz to have it pass 4K?
Hans Hilpert is offline
post #4660 of 4673 Old 11-30-2016, 10:33 AM
kevinf1990's Avatar
Quoted: 20 Post(s)
Doing the network reset procedure you mentioned fixed my receiver. so far.
I haven't had time to play around more but I have another question after buying a new KS8000 samsung tv. I have my cable box connected to HDMI 1 (CABL/SAT) on my SR6008 with passthrough enabled on that input so I can watch cable tv without the receiver being on. The KS8000 is connected to the ARC input on both sides (TV and receiver output).
If I wanted to use the TV's "smart" apps like the builtin youtube or netflix app, I switch the audio to receiver audio. When that happens, the TV commands the receiver to turn on but the odd part is that it also changes the receiver's input to "TV audio" automatically instead of using the HDMI 1 ARC path for audio. If I manually switch it back to HDMI 1 then audio plays fine. Is there any setting on the receiver to get the TV to switch the receiver to use HDMI ARC for audio instead of the TV Audio/optical input?
post #4661 of 4673 Old 11-30-2016, 10:36 AM
jdsmoothie's Avatar
Liked: 5142
The 2013 Marantz models (to include your SR5008) are not 4k/HDCP 2.2 capable, rather you will either need to pass the video directly to the TV and audio separately to the AVR or upgrade to a 2015 or 2016 model.
post #4662 of 4673 Old 11-30-2016, 10:40 AM
jdsmoothie's Avatar
Liked: 5142
HDMI(ARC) = Audio Return Channel = audio passes from the TV back to the AVR over the HDMI cable that is connecting the AVR to the TV and when doing so, the source on the AVR is "TV Audio" which is also used when connecting an optical cable from the TV to the AVR.
post #4663 of 4673 Old 11-30-2016, 11:05 AM
kevinf1990's Avatar
Quoted: 20 Post(s)
Sorry, forget what I said about HDMI 1. Now that I think about it, it has nothing to do with my issue. So my TV (HDMI 4 ARC) is connected to the receiver's (ARC Monitor output). On the TV, if I switch audio source from TV Speakers to HDMI audio, the receiver turns on and the receiver's input is automatically switched to TV audio, which is associated to an optical input on the receiver. Does that mean I would have to run another optical cable between the tv and receiver? How would I tell the receiver to associate "TV Audio" to the ARC path. I thought the whole point of using the ARC in/out ports is so that I can run everything in one cable.
post #4664 of 4673 Old 11-30-2016, 11:09 AM
jdsmoothie's Avatar
Liked: 5142
Again ... "TV Audio" is used for both the HDMI(ARC) feature and when using an optical cable from the TV--> AVR.
post #4665 of 4673 Old 11-30-2016, 11:21 AM
kevinf1990's Avatar
Quoted: 20 Post(s)
Ok I guess I will have to look at it again. Some how I remember when the input is switched to "TV Audio" there was no sound coming out of the built-in netflix app. So you are saying when the receiver displays "TV Audio", it will enable both the optical port and HDMI (ARC) for audio?
post #4666 of 4673 Old 11-30-2016, 12:14 PM
jdsmoothie's Avatar
Liked: 5142
Yes, it can accept audio either way; however, if the AVR is automatically switching to "TV Audio" as you indicated, then it's expecting the audio to come from the TV over the HDMI cable. Note however, that HDMI(ARC) doesn't always work in which case the work around is connect an optical cable from the TV and then you would manually select the "TV Audio" button on the remote when you wanted to listen to the NetFlix audio. Many owners actually prefer this configuration as it prevents the AVR from switching over to the "TV Audio" source every time it is powered on (an issue that has since been resolved on the newer models). Also, in many cases the TV is only able to pass PCM 2.0 audio over HDMI(ARC) while the optical cable is able to pass both PCM 2.0 and DD 5.1.
post #4667 of 4673 Old 11-30-2016, 01:48 PM
Is there a way to do 1.4 HDCP on the receiver or am I SOL? My wires are all buried in the wall. Don't want to go thru the hassel of burying another HDMI.
post #4668 of 4673 Old 11-30-2016, 02:54 PM
jdsmoothie's Avatar
Liked: 5142
Huh? The 2013 models in this thread are HDCP 2.1 so no reason to go backwards to 1.4.
You may also want to consider the HD Fury Integral which will allow an HDCP 2.2 signal to pass to your AVR without having to go to the TV.
https://www.hdfury.com/shop/splitter...60-444-600mhz/
post #4669 of 4673 Old 11-30-2016, 06:58 PM
Tgterm's Avatar
Quoted: 161 Post(s)
Short-live joy...anyone else experiencing this issue after the Pandora update? Thoughts?
post #4670 of 4673 Old 12-01-2016, 04:03 AM
jdsmoothie's Avatar
Liked: 5142
Try doing a soft reset of the AVR by powering off and unplugging the power cord for 10 minutes.
post #4671 of 4673 Old 12-01-2016, 05:21 AM
Tgterm's Avatar
Quoted: 161 Post(s)
That did the trick, JD. Thanks!
post #4672 of 4673 Old Yesterday, 08:07 PM
Tom Riddle's Avatar
Quoted: 449 Post(s)
Liked: 384
Thanks @jdsmoothie for all your support on this thread and for what is now a 3 year old product. Pretty amazing that the 7008 is still being sold - I've owned many receivers and most of the threads die as soon as the new model comes out. Cheers to all proud owners of what has been an amazing receiver for me and hopefully for you all.
jnnt29 and Tgterm like this.
Klipsch RF-7 II's, RC-64II, RS-62 II's, RS-52 II's
PSA V3600I
Marantz SR7008 with TK421 Modification
Emotiva XPA-5
Sony XBR-75x940c with Ideal-Lume Panelight
Samsung PN64F8500 (Master Bedroom)
Tom Riddle is offline
post #4673 of 4673 Old Today, 07:32 PM
rodneyiii's Avatar
Quoted: 17 Post(s)
Originally Posted by Ewingr View Post
Thanks for letting me know it will be fixed in another month. It's been broken since July...pretty poor support. I expected more from Marantz
I still would like to know if there is a bluetooth adapter that I can use in this unit.
The Marantz manual shows an RX101 Bluetooth and IR adapter on pg. 55. It plugs into the M-XPort on the back panel. You just have to find one since it appears it is not made anymore.
rodneyiii is online now
Marantz Sr5008 , Marantz Sr7008 , Marantz Sr6008
