The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 158 - AVS Forum | Home Theater Discussions And Reviews
 154Likes
post #4711 of 4722 Old 02-27-2017, 07:55 AM
jdsmoothie's Avatar
Quoted: 12663 Post(s)
Liked: 5792
Originally Posted by Matrixman18 View Post
Since I have plugged xfinity x1 into the HDMI of my tv, I'm not able to get the sound of my tv through my Marantz 6008. Earlier, I used to get the movies on Nextflix played via Marantz to my speakers but now if I select the Tv/Audio option on Marantz, it doesn't play the sound through speakers. Is there any fix to this problem?
Are you trying to use HDMI(ARC) or an optical cable to pass the audio back to the AVR? If the former, ensure HDMI CEC/Control is enabled on both the TV and the AVR.
jdsmoothie is offline
post #4712 of 4722 Old 02-27-2017, 08:03 AM
Quoted: 131 Post(s)
Liked: 49
I'm using HDMI cable. Sorry but have to ask this...how can I enable the CEC/Control on Marantz and TV? Haven't done it before and hence the question.
Matrixman18 is offline
post #4713 of 4722 Old 02-27-2017, 08:22 AM
jdsmoothie's Avatar
Liked: 5792
TV: Samsung (Anynet+), LG (SimpLink), Sony (BraviaSync), Vizeo (CEC) - ON
Marantz: Video -- HDMI Setup - HDMI Control - ON
post #4714 of 4722 Old 02-27-2017, 08:55 AM
Quoted: 131 Post(s)
Liked: 49
Thanks. It's Sony TV. Will do the changes and see if it works.
post #4715 of 4722 Old 03-02-2017, 08:01 PM
rbf1138's Avatar
Quoted: 66 Post(s)
Anyone know what this horizontal line on the front display is? I could swear this wasn't always there. It's there whether it's on or off, as shown in the pictures.
rbf1138 is offline
post #4716 of 4722 Old 03-02-2017, 08:05 PM
Signals's Avatar
Quoted: 13 Post(s)
I think that lights up when ZONE2 is powered on.
Vizio M65-D0 Display
Marantz SR7008 AVR
Axiom M60, VP160, M3 Speakers
Oppo UDP-203 Disc Player
Signals is offline
post #4717 of 4722 Old 03-03-2017, 12:47 AM
jdsmoothie's Avatar
Liked: 5792
As noted on p. 15 in your Owner's manual ....
erhurd likes this.
post #4718 of 4722 Old 03-05-2017, 05:49 PM
ToddR's Avatar
Quoted: 99 Post(s)
Liked: 94
Sometimes I use my SR5008 on the Network input to play music from my computer's iTunes library via my home network. If I then turn on my television, Marantz-generated text overlays that appear when I press remote control buttons will often appear in a giant pink rectangle with the name of the selected input in English, but then surrounded by a bunch of stray Asian characters. If I briefly turn off the Marantz and back on, the text overlays work properly.
What would cause this, and can I correct it?
ToddR is offline
post #4719 of 4722 Old 03-05-2017, 10:28 PM
jdsmoothie's Avatar
Liked: 5792
Network reset
You can try first doing a "soft reset" (power off and unplug the power cable for 10 minutes) and if still no joy, a "network reset" by pressing/holding down the Preset CH+/Preset CH- buttons while powering on the unit.
post #4720 of 4722 Old 03-06-2017, 07:59 AM
ToddR's Avatar
Quoted: 99 Post(s)
Liked: 94
Thanks. I'll try that.
I also had to unplug power to get it to switch inputs properly over the weekend, but I only interrupted it for about 15 seconds, not ten minutes.
ToddR is offline
post #4721 of 4722 Old 03-23-2017, 02:50 PM
Zorba922's Avatar
Quoted: 2486 Post(s)
Liked: 1774
Marantz 5008 with SQUEAKING SOUND
A friend of mine was offered a Marantz 5008 that periodically makes a squeaking sound which can be remedied by tapping on it, according to the seller, who wants $100 for it which doesn't seem like a bad deal at all.
Anybody know if this this a common problem for this model line? Would it be easy to fix or have fixed? Or should he just look elsewhere? Other than the squeaking, the receiver works well and sounds good, he says.
My friend mainly wants to hook it up to his tablet for music streaming, and to a BD player for the occasional movie, so he doesn't need the extra features/formats of a current receiver.
~ Are you a "geek hobbyist" obsessed with squeezing out that last 5-10% improvement? The economy will thank you...especially the Chinese one. Or are you more of a get-set-and-forget "casual user" who simply wants to increase your enjoyment of movies, TV and gaming? Relax, HT isn't rocket science, nor does it have to cost an arm and a leg---especially if you ignore the aforementioned vocal minority. And remember to smile...it's just a silly hobby, after all. :)
Zorba922 is online now
post #4722 of 4722 Old Today, 06:40 PM
Tom Riddle's Avatar
Quoted: 476 Post(s)
Liked: 409
I would stay away from that deal.
Klipsch RF-7 II's, RC-64II, RS-62 II's, RS-52 II's
PSA V3600I
Marantz SR7008 with TK421 Modification
Emotiva XPA-5
Sony XBR-75x940c with Ideal-Lume Panelight
Oppo UDP-203
Tom Riddle is online now
Marantz Sr5008 , Marantz Sr7008 , Marantz Sr6008
