The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 161 - AVS Forum | Home Theater Discussions And Reviews
 167Likes
post #4801 of 4809 Old 08-05-2017, 03:31 AM
jdsmoothie's Avatar
Quoted: 14626 Post(s)
Liked: 6962
Originally Posted by sparkyryan View Post
I am not using a sound card, I am using hdmi cable for both sound and video.Strangly the sound is correct when I run the speaker test in windows speaker config.
Then check your HTPC sound settings as the AVR can only play what it receives. If the HTPC is the only source with the issue ... the HTPC is the problem.
jdsmoothie is online now
post #4802 of 4809 Old 08-05-2017, 06:41 AM
Tom Riddle's Avatar
Quoted: 513 Post(s)
Liked: 428
That's impossible - in order for audio to work with a computer, it must be using a sound card. Mine is built into my motherboard and is Realtek. Your sound card is most likely not able to decode the multichannel audio, so that's why it is playing in stereo.
If I wanted to use my PC in my HT setup, I would need to invest in a sound card that could process Dolby TrueHD and DTS-HD MA. Right now it is only capable of stereo, or simulated surround.
Klipsch RF-7 II's, RC-64II, RS-62 II's, RS-52 II's
PSA V3600I
Marantz SR7008 with TK421 Modification
Emotiva XPA-5
Sony XBR-75x940c with Ideal-Lume Panelight
Oppo UDP-203
Tom Riddle is offline
post #4803 of 4809 Old 08-19-2017, 11:14 AM
vinny68's Avatar
No screen on my sr5008
My screen on my sr5008 goes blank after a few seconds its on. I've powered it down and waited a few minutes turned it on and still does the same thing?
vinny68 is offline
post #4804 of 4809 Old 08-20-2017, 03:44 AM
jdsmoothie's Avatar
Liked: 6962
If you have the PURE DIRECT surround mode selected, this is by design.
post #4805 of 4809 Old 08-20-2017, 04:56 AM
vinny68's Avatar
thanks jdsmoothie
vinny68 is offline
post #4806 of 4809 Old 08-20-2017, 05:07 AM
altpensacola's Avatar
Quoted: 52 Post(s)
Liked: 32
It is also a setting For the display in any mode, you can set it to do this or be on all the time. Just press the display button on the front and hold it a second.
Music, more music.
altpensacola is offline
post #4807 of 4809 Old 08-20-2017, 02:46 PM
ronin22's Avatar
Quoted: 48 Post(s)
Hi all
I'm having an issue with my 7008. I'm playing two channel music from my iPad to the 7008 via airplay and was listening for about 10 minutes when I heard a loud thump and pop come through the speakers, then the 7008 shut down and the red light on the front is blinking. It's done this twice in the last month and a half but before that no problems for the last three years. I have it plugged into a power strip with a lot of other items as it's always been and my speakers (powered sub section) are plugged into different outlets.
Any idea of what it can be or where I can start testing? Thanks a lot
ronin22 is offline
post #4808 of 4809 Old 08-20-2017, 03:49 PM
jdsmoothie's Avatar
Liked: 6962
Originally Posted by ronin22 View Post
Hi all
Start by taking the power strip out of the loop and plugging the AVR straight to the wall outlet. Also depending on the frequency of the flashing red light will determine the possible issue:
Fast blinking (ie. 2x/sec) - loose speaker wire from one post touching another; volume of 4-ohm speakers too loud; amp failure
Slow blinking (ie. 1x/2sec) - poor ventilation around the unit
post #4809 of 4809 Old 08-20-2017, 04:10 PM
ronin22's Avatar
Quoted: 48 Post(s)
Thanks JD - I think the light was blinking more like once a second and it's just weird to me because it's only happened twice.
I'll start checking out the items you mentioned though
ronin22 is offline
Marantz Sr5008 , Marantz Sr6008 , Marantz Sr7008
