The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 160Likes
post #541 of 4752 Old 11-09-2013, 01:21 PM - Thread Starter
enricoclaudio's Avatar
Quoted: 1207 Post(s)
Liked: 1276
I use a NAS Synology DS712+ who has iTunes server and it works very well. I also have my iMac ON 24/7, no need to turn it OFF.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #542 of 4752 Old 11-10-2013, 11:49 AM
ken6217's Avatar
Quoted: 64 Post(s)
I ran Audessy twice on my 7008. Big difference over manual calibration.
The first time I ran it, it set the crossovers as follows: Center - 250hz, Mains- 40hz, Surrounds - 100hz.
The second time I ran it, it set the crossovers as follows: Center - 250hz, Mains- Full range, Surrounds - 100hz.
I really do not want the mains to run full range. I rather have it set at 40hz or 60hz. However it will not allow me to change the Mains if they are set to Full.
So my question is this, can I write down all of the levels and distances and then go to manual mode and enter all of those readings and then enter in the crossover that I want for the Mains?
In a related question to the above, does Audessy do anything else besides those levels, distance settings, and crossovers?
Will this work?
Ken
ken6217 is offline
post #543 of 4752 Old 11-10-2013, 01:31 PM
Tom Grooms's Avatar
Quoted: 125 Post(s)
Liked: 207
Set the mains to small, set crossover frequency and start shopping for a new center channel wink.gif
Hear me now, Listen to me later....
Tom Grooms is online now
post #544 of 4752 Old 11-10-2013, 03:46 PM
ken6217's Avatar
Quoted: 64 Post(s)
You didn't answer my question though. Am I to use the same readings as what I got using Audessy in terms of levels and distance nut in Manual Mode set the crossovers?
Btw, it is not the center channel. Maybe it is the rack that it is sitting in or the boundary setting I set on the back.
It is a very good center channel and goes down to 34hz. Revel C208.
http://www.revelspeakers.com/downloads/products/prod_227_634899181171030621_REVP4834_Perf3_C208_C205_OM_EN.pdf
Ken
ken6217 is offline
post #545 of 4752 Old 11-10-2013, 03:57 PM
Tom Grooms's Avatar
Quoted: 125 Post(s)
Liked: 207
You're not changing levels and distance, only size (small) and adding a crossover. Leave everything else alone. Well, except that center channel. Got any photos of your setup? Maybe we can help with placement advice...
post #546 of 4752 Old 11-10-2013, 04:12 PM
ken6217's Avatar
Quoted: 64 Post(s)
Hmmm, interesting. I had set Low Frequency Control on the back of the speaker from normal to boundary. I read the instructions again and I had the wrong setting.
I changed the knob setting and ran Audessy again. It now set it at 90hz.
Once I get rid of the shelving until it is sitting on, it will be better.
Ken
ken6217 is offline
post #547 of 4752 Old 11-10-2013, 04:21 PM
ken6217's Avatar
Quoted: 64 Post(s)
Here is a picture. It doesn't look it from the picture, but that center channel is approx 29x14x12.
The positioning is temporary. You can even see amps on the floor. I am getting a new plasma this week and it is going on the wall. The equipment will go in the room behind with the cabling go through the wall. The center channel will be on the proper speaker stand.
Thanks for helping.
Ken
ken6217 is offline
post #548 of 4752 Old 11-10-2013, 04:41 PM
jdsmoothie's Avatar
Quoted: 13211 Post(s)
Liked: 6105
Will this work?
Ken
Nice center speaker! The Audyssey mode will always show what the settings are after running Audyssey, while in Manual Setup mode you can change the front mains to SMALL/40Hz or 60Hz whichever you prefer. Audyssey does the EQ of the speakers and sub while the AVR sets the levels, distance settings and crossovers. Review the Audyssey 101/FAQ Guide for more information.
http://www.avsforum.com/t/795421/official-audyssey-thread-faq-in-post-51779/51700_100#post_21782993
jdsmoothie is offline
post #549 of 4752 Old 11-10-2013, 04:48 PM
Tom Grooms's Avatar
Quoted: 125 Post(s)
Liked: 207
Sounds like you're all set Ken. Now it's time to start enjoying it. smile.gif
post #550 of 4752 Old 11-10-2013, 04:55 PM
ken6217's Avatar
Quoted: 64 Post(s)
Thank you for your comments.
Do you mean I have to run manual calibration to do that? I am asking because after I ran Audessy, I then went into manual mode and looked at crossovers and it showed All or Individial. All meant 80hz. Individual showed Center - 90hz, Surrounds - 100hz, and Mains - Full. There was no way to change the Mains.
It looks like the only way to change Mains is to actually do a full calibration in Manual mode with an SPL meter?
Ken
ken6217 is offline
post #551 of 4752 Old 11-10-2013, 04:59 PM
jdsmoothie's Avatar
Liked: 6105
No, I mean to go into Manual setup, rather than using the Manual graphic EQ curves. Note that if you don't have a dedicated subwoofer, the mains will remain as LARGE.
post #552 of 4752 Old 11-10-2013, 05:44 PM
ken6217's Avatar
Quoted: 64 Post(s)
Oh, you mean go to Speaker Config and change the front speaker from Large to Small, and then go and change the crossover?
I just did it now and then looked at the crossover and it now shows 40hz.
I do have a sub.
I know this will be a dumb question, but I assume that all of the other settings that were created running Audessy will still remain even though I changed the mains to small @ 40hz instead of Large?
Ken
ken6217 is offline
post #553 of 4752 Old 11-10-2013, 05:49 PM
jdsmoothie's Avatar
Liked: 6105
post #554 of 4752 Old 11-11-2013, 06:09 AM
stereoforsale's Avatar
9.1 vs 7.1
I have a 9.1 setup (with height speakers). Every time I turn on Audyssey DSX and engage my height speakers, I lose my back left and back right channels. How do I engage ALL 9 speakers at the same time? confused.gif
(Note: I've tested this on true 7.1 blu ray material)
stereoforsale is offline
post #555 of 4752 Old 11-11-2013, 06:35 AM
ken6217's Avatar
Quoted: 64 Post(s)
Thank you.
Ken
ken6217 is offline
post #556 of 4752 Old 11-11-2013, 07:27 AM
ken6217's Avatar
Quoted: 64 Post(s)
Does anyone use Dynamic Equalization?
Ken
ken6217 is offline
post #557 of 4752 Old 11-11-2013, 09:57 AM
shadster's Avatar
Hello everyone. I was looking to buy the 5008 but I have a rather peculiar question that I haven't found an answer to in the manual.
I want to use a stereo power amp to drive my front speakers and use the 5008 to drive the rest, is this possible? Also, do I have Audyssey processing applied to the front speakers this way? (I hope so). Can I use Audyssey auto-setup with this configuration?
shadster is offline
post #558 of 4752 Old 11-11-2013, 10:12 AM
ken6217's Avatar
Quoted: 64 Post(s)
Not a peculiar question at all. I am doing this with my 7008 for fronts and center speakers.
Anyway, yes you can. When you run Audessy, the calibration will know you have the amp.
Ken
shadster likes this.
ken6217 is offline
post #559 of 4752 Old 11-11-2013, 10:46 AM
shadster's Avatar
Ken
Thank you for the quick answer, Ken.
shadster is offline
post #560 of 4752 Old 11-11-2013, 11:19 AM
Selden Ball's Avatar
Quoted: 3233 Post(s)
Liked: 1587
Originally Posted by stereoforsale View Post
9.1 vs 7.1
What model of receiver do you have?
Some receivers have only 7 audio channels. If that's the case for yours, 9 speakers can be connected but only 7 can be active at the same time.
Selden
Selden Ball is offline
post #561 of 4752 Old 11-11-2013, 11:30 AM
drewTT's Avatar
Quoted: 585 Post(s)
Liked: 607
Quick question on impedance. I have B&W CM9s speakers and just got the Marantz SR7008. The Marantz has a speaker settings option of either 6 ohm or 8 ohm. Since the CM9s are 8 ohm but can dip to 3 ohm, would it be best to set the Marantz on 6 ohm?
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is offline
post #562 of 4752 Old 11-11-2013, 11:47 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
The speaker impedance switch relates most strongly to bench testing, wherein the 6 ohm setting slightly increases the power available when amplifying steady sine waves at max output while driving resistive loads. As long as you stick to music and speakers, there should be no problem with the 8 om setting.
arnyk is offline
post #563 of 4752 Old 11-11-2013, 01:01 PM
I have the SR7008, which has 9 channel. But I'm bi-amping the L & R, so I'm using an external amp to power the 2 height speakers, which are connected to the receiver via the pre-outs for the height speakers. To be clear, all 9 speakers do work, and all have been calibrated using Audyssey. But the rears (6&7) and heights (8&9) won't play at the same time, and I've tired all the surround modes available when I turn on DSX and press and hold the MOVIE button. I'm stumped.
DoublP likes this.
post #564 of 4752 Old 11-11-2013, 01:29 PM
Liked: 1587
I suspect the receiver can't handle both bi-amping and 9 speaker channels at the same time. That's a total of 11 channels, after all.
You might try undoing the biamping. In general, bi-amping can't improve the sound if you're still using the speakers' original passive crossover networks.
Selden
post #565 of 4752 Old 11-11-2013, 01:53 PM
But isn't the pre-amp section of the SR7008 is designed to process signal 11 channels? If so, I'd be surprised that internal bi-amping would have any impact on the processing 9 channels. Why would the pre-amp section care if I were using all nine of the internal amps to power 7 speakers if I'm sending the 8th and 9th signal to an external amp? And even if you are right, then it would mean there is no way to run a 11.1 setup (using 9 internal amps + 2 external amps) and I think the receiver is clearly designed for this confused.gif
As for why I'm bi-amping: it's to give more headroodm. Also check out the FAQ on Anthem's website for why it's a myth that "passive bi-amping" doesn't work. Passive biamping significantly reduces the impedance on each amp, thereby reducing the current being drawn, and therefore leaving much more power for the speaker to enjoy... or something like that smile.gif
post #566 of 4752 Old 11-11-2013, 02:16 PM
jdsmoothie's Avatar
Liked: 6105
The 7008 is only designed for 9CH, regardless of whether using external amps or not. You must upgrade to the 8801 to get 11CH support.
post #567 of 4752 Old 11-11-2013, 02:40 PM
Thanks JDS, but in my case I only want to do 9CH, which (I think) the SR7008 is supposed to do, but it ain't working. Again my set up is:
- internal bi-amp L&R
- external amp for left and right Height speakers
- all other speakers are powered using the internal amps
- total of 9.1
All 9 speakers have been calibrated with Audyessy and all 9 work, but only 7 at the same time. If I turn on Audy DSX, I lose the back L & R. When I hold down the MOVIE button, none of the modes use all 9 at the same time... only 7 speakers will work and I have to choose between the Heights and the Rears. This can't be right, can it?
Just as an aside: the specs clearly say the pre-amp section is 11.2... and one would assume this means 11 at the same time. Plus the rear of the unit clear has 11 pre-outputs... maybe they not all are operational at the same time, but that's pretty misleading. but I digress smile.gif
post #568 of 4752 Old 11-11-2013, 03:35 PM
tripppsta's Avatar
Greetings all.... will the 7008 decode SACD/DSD received over HDMI?
And how do I inquire about Marantz sales through AVS?
tripppsta is offline
post #569 of 4752 Old 11-11-2013, 04:20 PM
jdsmoothie's Avatar
Liked: 6105
Yes, the 6008 and 7008 can both decode DSD over HDMI. To speak with AVScience Sales ... you can just call me.
post #570 of 4752 Old 11-11-2013, 04:32 PM
jdsmoothie's Avatar
Liked: 6105
- total of 9.1
Are the second set of FL/FR speaker wires connected to the Front Wide speaker posts? Is AMP ASSIGN set to "7.1 CH(Bi-amp)"? Is the Main Speakers setting set to "S. Back/F. Height"?
Regardless of the fact there are 11.2 pre-outs (and 11 sets of speaker posts) on the Denon 3313CI and X4000 and Marantz 7008, they are only designed for 7CH/9CH/9CH processing respectively. The extra pre-outs and speaker posts are simply there for convenience.
Marantz Sr5008 , Marantz Sr7008 , Marantz Sr6008
