The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 154Likes
post #901 of 4734 Old 12-21-2013, 03:55 PM
gce
gce's Avatar
Quoted: 45 Post(s)
Hi all,
I've read all the posts in this thread because I want to upgrade my Yamaha RX-A810 to a SR7008. I have a Denon blu-ray and STB (at&t) hooked to the Yamaha via HDMI and HDMI from the Yamaha to the Panasonic VT30. I also have a NAS (Synology) streaming FLAC to the Yamaha thru my network. All this works great with no problems. No Sync or dropout problems like I had with my Onkyo. Will the SR7008 be able to do all this with no problems? Another words no handshake problems?
Thanks...
gce is offline
post #902 of 4734 Old 12-21-2013, 06:14 PM
Tom Grooms's Avatar
Quoted: 125 Post(s)
Liked: 207
No issues, smooth as glass...
Hear me now, Listen to me later....
Tom Grooms is offline
post #903 of 4734 Old 12-21-2013, 06:41 PM
ronin22's Avatar
Quoted: 38 Post(s)
Hi all
Hope you can help me with a few things. I just switched over from a denon to the 7008 and using the same speakers but added 2 for 7.1
I have this audible static noise coming from the front right and only slightly from the front left and nothing from the center and surrounds. It does it on all sources and it's really frustrating. Another item is that when I try to adjust the channel levels it won't play a test tone. Any ideas?
Also, I ran auddessy as a 7.1 but why is it when a play a movie on hbo it's coming through as 5.1 but not being output to 7.1? I thought whatever the multi channel input you had it would be output through all existing channels
Lastly, can you not use auddessy when using the marantzs airplay function ? It goes to set up when I try to access it in the menu
Many thanks
ronin22 is offline
post #904 of 4734 Old 12-21-2013, 06:56 PM
danbry39's Avatar
Originally Posted by Hawkboy View Post
I've updated to the new firmware on my SR5008 and now my SiriusXM is not working. I can login but all I get are two options:"account info" and "sign out"... If I select "account info" it says it's all good, but there are no music channels whatsoever to select. Anyone else having this problem since the firmware update?
Please take my information with a grain of salt, as I'm an old time audio person, but just catch up on the latest technology when I go through major revisions in my system.
I have the SR5008 and after the recent update (not sure it's related), I couldn't get my Panasonic BluRay to play. I checked the HDMI connects and unplugged the receiver for a few seconds with no change to what was going on.
JDSmoothie advised that a soft reset requires unplugging the unit for at least 10 minutes, so I unplugged it for a bit more than 30 minutes, leaving the DVD player playing during that time. When I plugged the receiver back in, all was good. The DVD was again connected.
Hopefully, this might work for you as well.
danbry39 is offline
post #905 of 4734 Old 12-21-2013, 07:00 PM
Tom Grooms's Avatar
Quoted: 125 Post(s)
Liked: 207
I'd start by swapping speaker cables (right front to surround back etc) and see if the noise follows the amp channel or stays with the speaker.
Press and hold "movie" on the oem remote during 5.1 playback and select an algorithm to engage 7.1 playback.
post #906 of 4734 Old 12-21-2013, 07:08 PM
Slater32's Avatar
Really starting to hate this 5008 already........
Had dynamic volume set to compensate for loud commercials & all of a sudden something has changed itself & can not even select the dynamic volume to change the setting as another setting is overriding it & has turned it off.
Have no idea what has changed & how to correct it, i hate headaches.....
Slater32 is offline
post #907 of 4734 Old 12-21-2013, 08:23 PM
ronin22's Avatar
Quoted: 38 Post(s)
Thanks Tom
But I don't see how switching cables is going to tell me anything. I mean I have sound without static from the surrounds and center it's just the front right and a very small amount from the front left. Previous set up with the denon had no issues and I just have a funny feeling it is the unit itself but maybe I'm missing something?
It's weird that the test tone doesn't work and every time I change the channel I can hear the unit click like an amp being engaged.
ronin22 is offline
post #908 of 4734 Old 12-21-2013, 09:23 PM
Ronnies Beard's Avatar
Just bought the SR5008.  Can't figure out how to calibrate my 4 subs, every time i play the test tones so I can measure with my SPL meter it doesn't play them at a set volume like my old AVR, My last receiver used to set them at 75 db's, what volume do I play these tones at? and where do I start the Level Trim at, 0 db's then up the volume to 75?
Ronnies Beard is offline
post #909 of 4734 Old 12-22-2013, 04:46 AM
jdsmoothie's Avatar
Quoted: 12949 Post(s)
Liked: 5978
The test tones used for the Audyssey setup are at 75db, however, the individual speaker/sub test tones are based on the master volume so doesn't really matter what volume you have it at as long as each sub is at the same level at that volume. Then when you run Audyssey, they will collectively be set based on the 75db test tone. Keep in mind that although there are two sub pre-outs, the AVR only sees the total input as if only one sub was connected.
jdsmoothie is online now
post #910 of 4734 Old 12-22-2013, 05:50 AM
Tom Grooms's Avatar
Quoted: 125 Post(s)
Liked: 207
Originally Posted by ronin22 View Post
Thanks Tom
Switch the front speakers and the surround speakers and see if the noise shows up in the surround channels. Is the noise present on all sources? Don't guess, test. Does it get louder when you add gain? Play some content and hit pause, adjust the volume up and down. Does the noise get louder as volume is increased?
post #911 of 4734 Old 12-22-2013, 07:05 AM
mnc
mnc's Avatar
Quoted: 586 Post(s)
Liked: 492
Does that mean when using 2 subs they can't be setup as LR stereo?
NHT speakers, Denon 4520, Panasonic 65VT50, DUAL PSA XS30SE's
mnc is offline
post #912 of 4734 Old 12-22-2013, 07:23 AM
Selden Ball's Avatar
Quoted: 3216 Post(s)
Liked: 1579
What do you mean by LR stereo?
Subwoofers usually are used only for the lowest two audible octaves, those frequencies below 80 Hz.
Bass frequencies below about 80 Hz can't be localized. I.e. the vast majority of people cannot determine what direction those sounds are coming from. (People can tell the directions of the higher frequency resonances, but they aren't produced by the subwoofers.) As a result, the subwoofers and the frequencies they produce don't contribute to stereo audio imaging.
However, those frequencies do tend to interact with the room, since most listening rooms have dimensions corresponding to the wavelengths of specific bass frequencies, resulting in standing waves with peaks and nulls at particular locations in the room. Where you put the subwoofers can be used to optimize the locations of the standing waves, either to keep them away from the primary listening position or to have one subwoofer fill in the nulls produced by the other one. As a result, the calibration procedure has to hear the sounds produced with both subwoofers active simultaneously.
Edited to add:
This is an overly simplified description, and subwoofers do produce some output at higher frequencies, but their contribution there isn't significant.
Selden
Selden Ball is online now
post #913 of 4734 Old 12-22-2013, 07:25 AM
ronin22's Avatar
Quoted: 38 Post(s)
thanks again
it did it on multiple sources and after listening closer i do hear it a little through the left surround. i reset the processor a few times and when i run through the original set up with Auddessy its there. As far as volume I don't think it increased with it but cant be sure
I lost my patience with it so I hooked up my Denon and there is no static so I'm just going to send it back
ronin22 is offline
post #914 of 4734 Old 12-22-2013, 07:55 AM
[Irishman]'s Avatar
Quoted: 175 Post(s)
Liked: 121
Have you done a reset to defaults and rerun Audyssey? It's annoying, but that's what I'd do.
COMING SOONFinding the Ark of the Covenant by Brian Roberts, in the iBook Store on iTunes, a new investigation into the Hebrew’s Most Sacred Relic!
[Irishman] is offline
post #915 of 4734 Old 12-22-2013, 08:22 AM
Slater32's Avatar
Think im good but not certain at this point. Unplugged the unit for 10minutes & went back in, my audy. settings were still there & was able to highlight & function dynamic volume again.
I like my idea better of returning it & getting an Onkyo.... ya im just frustrated!
Seen lots of other threads where people feel Marantz is relly dialed for music & doenst stand-out & shine for movie watching...
Slater32 is offline
post #916 of 4734 Old 12-22-2013, 09:28 AM
Liked: 1579
Sorry, but that last is just "placebo". People hear what they want to hear. Any electronics differences in the equipment in this price range are so subtle that we really are unable to hear them. That's somewhat glib, but speakers and room acoustics dominate our audio experience, which is why room EQ like Audyssey can be so important.
And no company's manufacturing process is perfect. Some defective units always manage to sneak through even the most stringent quality control procedures. frown.gif
Selden
post #917 of 4734 Old 12-22-2013, 09:55 AM
gce
gce's Avatar
Quoted: 45 Post(s)
I've read this above a couple of times in this thread and what to ask those who have the SR7008 dialed in, what do you think about the Movie experience? I'm like 50/50 with Music and Movies and would think the SR7008 would be good at HT as well as Music?
gce is offline
post #918 of 4734 Old 12-22-2013, 10:01 AM
mnc
mnc's Avatar
Quoted: 586 Post(s)
Liked: 492
Edited to add:
My subwoofers are built in to my L&R towers and my crossover is set to 120Hz. Didn't know if this would result in "stereo" bass or not. Like you said though, probably can't localize left or right bass sounds even in my setup. Just wondering if makes a difference or not if there is a choice for how the 2 subs are setup.
mnc is offline
post #919 of 4734 Old 12-22-2013, 10:44 AM
Liked: 1579
Edited to add:
If you want to use them that way, just hook the subs to the sub outputs of the receiver and disconnect them completely from the higher-frequency drivers in the speaker. Don't be upset when the receiver chooses a high crossover frequency for the main speakers. After all, they won't have any woofers any more. Connecting the subwoofers separately lets Audyssey use its separate subwoofer equalization channel which has a higher resolution than the main speaker EQ channels.
Quite a few people prefer to configure these types of speakers (ones with builtin subwoofers) just like the more common full-range passive speakers and add a completely separate subwoofer which can be placed at a better location in the room to get the best low-frequency response.
Selden
post #920 of 4734 Old 12-22-2013, 03:57 PM
llep64's Avatar
Quoted: 83 Post(s)
The 7008 is great with music and OK with HT. IMHO .
llep64 is offline
post #921 of 4734 Old 12-22-2013, 04:25 PM
drewTT's Avatar
Quoted: 575 Post(s)
Liked: 606
Care to elaborate?
LG OLED65E6 | Marantz AV8802A | Marantz MM8077 | Panasonic DMP-UB900 | PS Audio PerfectWave P3 | B&W CM9 | B&W CM5 | Dual JL Audio Fathom f112
Maingear Drift Z170 GTX 1080 HTPC | BDI Mirage 8227 | Logitech Harmony Elite | Synology DS916+ | TEAC UD-503 | Focal Solo6 Be | Vizio P50-C1
drewTT is offline
post #922 of 4734 Old 12-22-2013, 04:48 PM
MGTR420's Avatar
Quoted: 34 Post(s)
Liked: 40
Anyone have an idea why my subwoofer suddenly would stop working? I replaced the subwoofer because I was within the return policy. Reconnected it, doesn't work, tried a new RCA cable, still doesn't work. Ran the audessy set up again, nothing... frown.gif
Edit: Or why just my subwoofer 1 doesn't work?
MGTR420 is offline
post #923 of 4734 Old 12-22-2013, 05:09 PM
Tom Grooms's Avatar
Quoted: 125 Post(s)
Liked: 207
LMAO
mdbrown likes this.
post #924 of 4734 Old 12-22-2013, 05:13 PM
gce
gce's Avatar
Quoted: 45 Post(s)
Originally Posted by drewTT View Post
Care to elaborate?
...and you also drewTT, you have a SR7008 too. What do you think? I would think with Audyssey MultEQ XT32 and the dac's this thing would dial HT in better then most AVR's?
gce is offline
post #925 of 4734 Old 12-22-2013, 05:13 PM
llep64's Avatar
Quoted: 83 Post(s)
Ok.
llep64 is offline
post #926 of 4734 Old 12-22-2013, 05:23 PM
drewTT's Avatar
Quoted: 575 Post(s)
Liked: 606
I think it is a very good receiver. Fantastic sound quality. Audyssey does an excellent job dialing in my pretty terrible room.
drewTT is offline
post #927 of 4734 Old 12-22-2013, 05:24 PM
jdsmoothie's Avatar
Liked: 5978
Is it plugged in and turned on?
post #928 of 4734 Old 12-22-2013, 05:42 PM
MGTR420's Avatar
Quoted: 34 Post(s)
Liked: 40
Yes it is, I plugged it in to Subwoofer 2, and it plays just fine now, but the second I unplug it, and put it in to Subwoofer 1, it doesn't work. Its just weird that over a week my Subwoofer 1 stopped working.
MGTR420 is offline
post #929 of 4734 Old 12-22-2013, 06:07 PM
Tweaked05's Avatar
Quoted: 42 Post(s)
Liked: 26
Have you checked in the setup to make sure that you have it set for 2 subwoofers?
Tweaked05 is offline
post #930 of 4734 Old 12-22-2013, 06:22 PM
rossi46's Avatar
Quoted: 40 Post(s)
Liked: 27
2. As long as the HDD is formatted properly ... shouldn't be an issue.
The HDD has definitely been formatted correctly, that's what's frustrating. I can connect the external HDD to my laptop, and move files back and forth, create new folders, play music or movies off of it, etc. When I connect the HDD to my Oppo BDP-103, it can also read and play .flac audio and .mkv movie files with no issues at all.
It's just the Marantz that seems to be unable to browse beyond showing me "Volume 1." (Which is not the name of any folder on the drive.)
Right now my "fix" is to go external HDD --> Oppo (via USB) --> Marantz (via HDMI), but I'd like to cut out the "middle man," so to speak.
Thanks for all the assistance, JD.
LG OLED 55" B6 | Oppo UDP-203 | Yamaha RX-A1060 | KEF KHT-3005 | BlueJeansCable
- video and audio calibrated by Jeff Meier -
rossi46 is offline
Marantz Sr5008 , Marantz Sr7008 , Marantz Sr6008
