The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 152Likes
post #991 of 4701 Old 12-28-2013, 08:25 AM
Hensley300's Avatar
Hello all,
After doing a good deal of research and comparing, I did finally settle the best receiver for me would be the SR7008.
I went to best buy to look at the model they had on display. It was a sr6008. I looked it over and played with some settings for awhile. It was just as I expected.
I then put my hand on the top and noticed it was very hot. I did the same to the sr6008 and it too was very hot to the touch
I compared it with a Yamaha nearby and it wasn't nearly as hot.
That being said,these were in tight enclosures which obviously counts for something. But has anyone that owns these had any problems with them going into protection mode because of the heat?
I don't plan to drive them too hard too often but I do like to turn things up on my favorite songs and movies
-John
"Alcohol: The cause of and solution to ALL of life's problems" Homer Simpson
Hensley300 is offline
post #992 of 4701 Old 12-28-2013, 08:38 AM
Tweaked05's Avatar
Quoted: 41 Post(s)
Liked: 26
Originally Posted by Hensley300 View Post
Hello all,
-John
I have watched multiple movies now at volumes that I enjoy, but my wife feels is too loud. Reference level or not, I don't know, but no problems with my 7008.
Tweaked05 is online now
post #993 of 4701 Old 12-28-2013, 08:49 AM
[Irishman]'s Avatar
Quoted: 175 Post(s)
Liked: 121
Originally Posted by Tweaked05 View Post
Can anyone help me out with Airplay from my Ipod Touch? My SR7008 is on my network and so is my Ipod, but I can't find the Airplay icon on my ipod. I checked the version of IOS on my ipod and it is 5.1.1 which as I understand it should have airplay.
The Airplay icon is app-centric , which means you'll only ever see it when you're in the app. Also keep in mind that not every app is Airplay-able. The icon looks like a rectangle with an upward- pointing arrow . Try Apple's music app first just to test it out.
COMING SOONFinding the Ark of the Covenant by Brian Roberts, in the iBook Store on iTunes, a new investigation into the Hebrew’s Most Sacred Relic!
[Irishman] is offline
post #994 of 4701 Old 12-28-2013, 09:03 AM
stereoforsale's Avatar
Originally Posted by Selden Ball View Post
1) This suggests that there might be a problem with your center channel and/or the associated speaker. That's where most of the dialog is provided by movies.
2) The change in volume level is normal when DynVol is enabled. It takes a little while for it to readjust the overall volume level when there's an abrupt change.
3) With 87dB sensitivity, your speakers are somewhat inefficient for use in a home theater.
Thanks for the tips.
1) dialogue is fine, it's just too low sometimes when Dyn Vol is not engaged. I can increase the volume so the dialogue is more audible, but like I said, then the louder scenes are far too loud. Yes, increasing the volume of just the centre channel might help (as opposed to using Dyn Vol) but I suspect this will create other problems... but I may try it out.
2) good to know. I suspected this was the reason. Not ideal, but at least there is no point getting an external amp if it won't solve the problem.
3) sensitivity is 90db for the matrix 803s (my L&R) and 89db for the matrix HTMs (my centre and rear left and rear right). I use the 805s for the surrounds only (87db), but they are quite close to the seating area. Best speakers I ever had... and probably the best ever in their price range... irreplaceable smile.gif
stereoforsale is offline
post #995 of 4701 Old 12-28-2013, 02:51 PM
gce
gce's Avatar
Quoted: 45 Post(s)
I'm running a 5.1 system and don't see going to 9.2 or even 7.2 in the future. It looks like the X4000 and the SR7008 have the same amp's? Do they have the same DAC's? They do both have MultEQ XT32. So in my case why would I like the SR7008 over the X4000? Which one sounds better? I'm looking for the best sound I can get out of an AVR.
gce is offline
post #996 of 4701 Old 12-28-2013, 03:32 PM
jdsmoothie's Avatar
Quoted: 12140 Post(s)
Liked: 5530
The SR7008 has 2 more amps than does the X4000, so then with only a 5.1 setup in the main zone, the SR7008 can power a set of Zone 2 and Zone 3 speakers as well (eg. patio, deck, bedroom, office, living room, etc.). There are those that prefer Marantz more so when more detailed music listening is especially important to them.
jdsmoothie is online now
post #997 of 4701 Old 12-28-2013, 04:33 PM
gce
gce's Avatar
Quoted: 45 Post(s)
This would be especially important to me. So if the SR7008 is more detailed, in music than the X4000 then the SR7008 would be the one I'd want.
Thanks jd!
gce is offline
post #998 of 4701 Old 12-28-2013, 05:46 PM
Tom Grooms's Avatar
Quoted: 123 Post(s)
Liked: 205
You can't power zone 3 speakers with the 7008 internal amps. Zone 3 is external amp only. I hate the amp assign limitations of the current D&M products
Hear me now, Listen to me later....
Tom Grooms is offline
post #999 of 4701 Old 12-28-2013, 06:48 PM
PeterK's Avatar
Quoted: 41 Post(s)
Liked: 54
Well according to the 7008 manual, you can run 5.1 and power zones 2 and 3 or run 7.1 and power zone 2.
The Denon 4520 has 9 amps as well and all 9 amps are available to be assigned as needed. Highly configurable.
PeterK is offline
post #1000 of 4701 Old 12-28-2013, 07:06 PM
gce
gce's Avatar
Quoted: 45 Post(s)
yeah, I read that on page 147 but really don't think I'll need a zone3. Good to know this is possible with a 5.1 setup tho.
gce is offline
post #1001 of 4701 Old 12-28-2013, 07:13 PM
Tom Grooms's Avatar
Quoted: 123 Post(s)
Liked: 205
Sorry, you can power zone 3 in a 5.1 main zone setup. In my room with a 7.1 setup and 9 internal amplifiers available, I can only use 1 pair (zone 2). Zone 3 requires another amp.
post #1002 of 4701 Old 12-28-2013, 08:40 PM
CrashMeister's Avatar
Originally Posted by stereoforsale View Post
... matrix 803s (my L&R) ... Best speakers I ever had... and probably the best ever in their price range... irreplaceable smile.gif
I have a pair of 803s (L&R) powered by a Rotel 120W amp. Been giving my goosebumps from pure listening pleasure for 15+ years and still going strong. Best money I ever spent.
CrashMeister is offline
post #1003 of 4701 Old 12-29-2013, 11:12 AM
MerlinBike's Avatar
I just installed a brand new SR5008 two days ago. It worked great for all of 15 hours— video, AirPlay, everything I wanted worked great. Then it asked to do a software update, downloaded the update, and then went into an update loop. I pulled the plug for a few hours, held the power button down for a few minutes, did a reset to factory settings a few times, tried starting it with the PRESET CH +/- buttons held down, and it still just keeps trying to update the software, ending up with a "Cannot connect OE" message. (The sequence of the messages is "Update Retry//DSP 07min/ Connect failed OE" and then it starts the sequence again, doing it over and over.) Marantz is closed on weekends, so no help there.  My network is fine: the Marantz even shows up on AirPlay for a few minutes when it powers on.
Any ideas?
MerlinBike is offline
post #1004 of 4701 Old 12-29-2013, 11:17 AM
jdsmoothie's Avatar
Liked: 5530
post #1005 of 4701 Old 12-29-2013, 04:54 PM
MerlinBike's Avatar
Thanks. They did not work, so I guess its me and Marantz on the phone tomorrow.
post #1006 of 4701 Old 12-29-2013, 10:09 PM
dibart77's Avatar
Hi all!  I recently purchased an SR5008 and have been having a couple of issues that have got me at my wits end and I need help from smarter / more experienced people than myself!
First, here's my current equipment:
     - Oppo BDP_103 Blu-Ray
     - Sony Cable Box
     - Marantz SR5008
     - Panasonic TH-42PH9UK Plasma
     - All connected via HDMI (latest)
My issues are:
A) I am having an issue where I can't get video to display on the plasma.  When I run the Marantz on-screen display/setup without the other components turned on, I am all good and have great 1080p video on the display.  As soon as I turn on the Oppo or the cable box, I lose video and can't get it back.
I upgraded the firmware in the Oppo, the cable box, and the SR5008.  Didn't help.  Can't find anywhere to get firmware update for the plasma (nothing on Panasonic's site, nothing on OSD).
When I connect the Oppo or the cable box directly to the HDMI input on the plasma, I have no issues at all.  So it seems to me that the SR5008 is the problem?
I determined that this must be an HDCP issue, so I bought a Dr. HDMI and now I have video!  The only negative with this workaround is that when I switch sources (say, from Blu Ray to Cable), I need to turn the plasma on and off before the new source will display.
Any suggestions on how to fix the above issue CORRECTLY (rather than the Dr. HDMI in the chain)?  If not, any suggestions on how to avoid having to power cycle the display?
B) Issue B is interesting.  Watching a movie, gets to a loud / exciting section in the movie and the sound is cutting out (on ALL 5.1 channels -- not like one speaker with a loose cable, it's all channels).  Like, for a split second.  Keeps doing it.  Almost like some protection circuit, although I do NOT have this on loud (watching Monsters University with my wife and young kids, not blasting at all).  Have never had this issue in the past with my Denon AVR-2809CI and the same Oppo player.  Any thoughts here?
I am getting discouraged by these two issues and am strongly considering sending the Marantz back.  I looked at getting a Denon but then realized that they have the same back panel, so I assume they have the same guts, so I'd probably have the same issues...
Any help or suggestions you guys can give would be really appreciated.  Thanks all!
Jeff
dibart77 is offline
post #1007 of 4701 Old 12-30-2013, 04:59 AM
fx3000se's Avatar
 Please read through the Audyssey 101/FAQ Guide linked in my sig
Could it be that the mentioned link is no more "there" ;)
Would appreciate to read this 101/FAQ
- Clemens
fx3000se is offline
post #1008 of 4701 Old 12-30-2013, 05:19 AM
jdsmoothie's Avatar
Liked: 5530
post #1009 of 4701 Old 12-30-2013, 06:25 AM
Hensley300's Avatar
BTW,
Are you guys having success with the logitech harmony one remote or better with another model like the ultimate?
post #1010 of 4701 Old 12-30-2013, 11:19 AM
lizrussspike's Avatar
Quoted: 505 Post(s)
Liked: 637
I too have watched many movies in my two months of SR7008 ownership, and found that even after two movies, the top of the Marantz gets "luke" warm to the touch.
I have it in an open TV stand, with a glass shelf over it about 2 inches. Love the 7008:)
lizrussspike is offline
post #1011 of 4701 Old 12-30-2013, 02:53 PM
petercw2's Avatar
Can anyone tell me if the two sub pre-outs can be separated (via the on-screen UI) so that one sub is working the Front L/R and surrounds and the other sub pre-out is dedicated to the center channel?
thanks.
petercw2 is offline
post #1012 of 4701 Old 12-30-2013, 03:23 PM
I used to run mine with a Class pre-amp/processor and Parasound amp. The sounds greatly improved with the SR7008 (at less then 1/3rd the price!). I think much of it has to do with Audyssey calibration. We are pretty lucky to get the last reasonably priced B&W 800 series... things got way too expensive after the matrix series. Happy Listening!
post #1013 of 4701 Old 12-30-2013, 07:06 PM
Tom Grooms's Avatar
Quoted: 123 Post(s)
Liked: 205
thanks.
No, it's doesn't work that way. No reason for it, in fact it would just mess things up. Talk about a placement and calibration nightmare...
post #1014 of 4701 Old 12-30-2013, 07:17 PM
RDHolmes's Avatar
Quoted: 85 Post(s)
Liked: 76
     - Sony Cable Box
     - Marantz SR5008
My issues are:
Jeff
Here is what I would do.
1. Make sure that all the HDMI cables are plugged in straight and securely.
2. Try a different High Speed HDMI cable between the Marantz and the Display.
3. Try different High Speed HDMI cables between the OPPO and the Marantz.
How long are your HDMI cables?
Do you have HDMI CEC turned on in any of the devices. If yes, try turning it off.
Do you get the sound drop outs when using DR. HDMI?
Bob Holmes
Curmudgeon
RDHolmes is offline
post #1015 of 4701 Old 12-31-2013, 03:54 AM
jdsmoothie's Avatar
Liked: 5530
thanks.
As Tom indicated, no. Additionally, on the 5008 and 6008 the dual sub pre-outs are nothing more than an internal "Y" splitter of a single sub pre-out, whereas on the 7008 each sub pre-out will independently control the volume of each sub.
post #1016 of 4701 Old 12-31-2013, 04:01 AM
jdsmoothie's Avatar
Liked: 5530
@dibart77
1. HDMI handshake issues with cable boxes are common ... the better configuration is HDMI to the TV with optical from the cable box to the AVR. Also, confirm the "Deep Color Output" setting on the Oppo is set to OFF.
2. Check the level of Dynamic Volume that is being used as you may want to lower it or turn it off completely.
post #1017 of 4701 Old 12-31-2013, 11:16 AM
Harmon Fan's Avatar
Quoted: 16 Post(s)
Does anyone know if Marantz uses the same DAC in their SR5008 and the UD5007? I am wondering if I will benefit by using the Analog outputs of my 5007? Thanks for any input.
Main. Marantz SR7008, UD5007, Integra CD3.2 Paradigm Reference Studio 60v5 fronts, Reference Center, Rears, Def Tech Super Cube
Sony 46HX750
Harmon Fan is offline
post #1018 of 4701 Old 12-31-2013, 11:42 AM
ollegg's Avatar
Greetings and Happy New Year!
Is there a way to bi-amp the center channel on SR7008 please using one of the unused channels? I have a 7.2 set up.
Thank you in anticipation
ollegg is offline
post #1019 of 4701 Old 12-31-2013, 01:08 PM
jdsmoothie's Avatar
Liked: 5530
No Audyssey with the multi analog inputs is why most prefer using HDMI. smile.gif
post #1020 of 4701 Old 12-31-2013, 01:10 PM
jdsmoothie's Avatar
Liked: 5530
Sorry, but no, although there would be no benefit even if you could (just as there is no benefit using the on board feature for the FL/FR speakers). wink.gif
Marantz Sr5008 , Marantz Sr7008 , Marantz Sr6008
