The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 160Likes
post #91 of 4760 Old 08-02-2013, 02:53 AM
Jolly74's Avatar
The sound was to heavy and the amp was to big for my speaker setup,
I want a more detalied sound and not so heavy, if you know what i mean?
Jolly74 is offline
post #92 of 4760 Old 08-02-2013, 03:18 AM
PeterK's Avatar
Quoted: 41 Post(s)
Liked: 54
Hmm. Can you post what your speakers are please? No such thing as an amp that is too big really, not that would affect the sound negatively. There will be some slight audible differences possibly between electronics and the biggest difference would be if you are moving up the food chain with Audyssey.
Normally, improving your speakers will make the most improvement in audio quality.
PeterK is offline
post #93 of 4760 Old 08-02-2013, 06:46 AM
Jolly74's Avatar
Jolly74 is offline
post #94 of 4760 Old 08-02-2013, 02:56 PM
Jolly74's Avatar
slight audible differences possibly between electronics <---that was what i meant! but my i english is bad wink.gif
Jolly74 is offline
post #95 of 4760 Old 08-02-2013, 03:18 PM
PeterK's Avatar
Quoted: 41 Post(s)
Liked: 54
Did some research - not sure what subwoofers you have in your system. The normal package has subs that go down to ~40 hz with a 100 watt amp. If that is what you have, I would recommend looking at upgrades to your subs with more built in power and larger drivers as small underpowered subwoofers will produce bass that to me is "smeared" - not clear, detailed, quick. Have no idea what is available in your country.
The new receiver will do it's job just fine as the Marantz SR7008 is their top model. It will not be your problem and you need to look at your source equipment feeding the audio and especially the speakers or subwoofers as they may be your weakest link. Good luck to you. Pete
Oh and you should consider starting a separate post in the speakers forum here for any further questions to get better answers. smile.gif
PeterK is offline
post #96 of 4760 Old 08-02-2013, 11:13 PM
Jolly74's Avatar
http://www.triangle-fr.com/en/esprit/meteor_0.1/ <---I have two of those
http://www.hembiobutiken.se/produkt.asp?pgrpnr=140950 <---This is the Swedish webb page that i shop from, use google translate from Swedish to English....
Jolly74 is offline
post #97 of 4760 Old 08-04-2013, 10:52 AM
RickPas's Avatar
Quoted: 40 Post(s)
Starting to find my way around the new reciever.....I'm really starting to enjoy it....And my mic boom should be here tomorrow, so If anything it will sound even better...
Quick question when I run audyssey again.....I know it says to put the mic ear level at my listening position, If I do that the back of the couch will probably be right behind the mic, I thought I read that this is not good, but if I raise the mic higher than the back of the couch it will be alot higher than ear level...So what is recommended?
Rick
RickP.
RickPas is offline
post #98 of 4760 Old 08-04-2013, 11:23 AM
jdsmoothie's Avatar
Quoted: 13327 Post(s)
Liked: 6178
Either recline the back of the couch (if possible) or raise the mic a few inches above the back of the couch. Neither is ideal, but it's what you have to work with.
jdsmoothie is online now
post #99 of 4760 Old 08-05-2013, 02:58 PM
mnc
mnc's Avatar
Quoted: 611 Post(s)
Liked: 512
Has anyone compared the x4000 to the 7008?
NHT speakers, Denon 4520, Panasonic 65VT50, DUAL PSA XS30SE's
mnc is offline
post #100 of 4760 Old 08-06-2013, 01:42 PM
RickPas's Avatar
Quoted: 40 Post(s)
I got my Mic boom yesterday so I re ran Audyssey today....Here is what my new settings are....
Crossovers
Front- 150
Center-90
Surrounds-150
Sub- 120
It sounds really good so far on what I've listened to, but should I change the Fronts Down to 120 or lower? Keep in mind I have large speakers Triton 2's and a svs sub pb-12 nsd....
Also, when I listened back to music on HDMI I'm showing a PCM signal and when I changed it from Stereo to Direct, I got a lot fuller sound.....Is Direct a better setting when listening to stereo mode music??
The only other thing so far I changed right after I ran Audyssey was the Dialog channel, it had my center up to loud for my taste, so I lowered it and I like it much better...It did this even the first time I ran Audyssey...
Rick
RickP.
RickPas is offline
post #101 of 4760 Old 08-06-2013, 03:53 PM
jdsmoothie's Avatar
Liked: 6178
Review the Audyssey 101/FAQ Guide linked in my sig to learn why you don't want to lower any crossovers as well as how to optimize the use of Audyssey.
post #102 of 4760 Old 08-06-2013, 04:29 PM
RickPas's Avatar
Quoted: 40 Post(s)
So if I don't lower any crossovers is it ok to raise a speaker level? Like if I want to raise the sub a little?
Rick
RickP.
RickPas is offline
post #103 of 4760 Old 08-06-2013, 04:31 PM - Thread Starter
enricoclaudio's Avatar
Quoted: 1217 Post(s)
Liked: 1285
Rick,
Looks like you are doing something that's not correct because those speakers should be detected by Audyssey as full range. I don't know how the subwoofer in the Triton 2's work but for sure they can go very low (like 20Hz). It's not normal that Audyssey set the crossover at 150Hz in a speaker that can go below 20Hz.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #104 of 4760 Old 08-06-2013, 04:32 PM
mizzoufan2001's Avatar
I see the HDAM has trickled down to the 5008 and 6008, previously only on the 7007. Is this a meaningful upgrade that can be heard? 5007 and 6007 can be found cheap. Is it worth it to pay the premium for a 5008 over a 5007?
Hawkboy likes this.
mizzoufan2001 is offline
post #105 of 4760 Old 08-07-2013, 03:38 AM
jdsmoothie's Avatar
Liked: 6178
Rick
You can raise/lower speaker/sub levels to your heart's content as these are not set by Audyssey, but as I suggested, review the Audyssey 101/FAQ Guide which will explain this as well as help you troubleshoot why you're getting such high crossover settings in the first place.
post #106 of 4760 Old 08-07-2013, 10:56 AM
RickPas's Avatar
Quoted: 40 Post(s)
I was looking through the audyssey 101 faq and was wondering if this could have caused my Audyssey to set up with such high crossovers on my Triton 2's....I had the LFE+Main selected on the avr before running it.....Could this have caused my high crossover settings? Also, when it started Audyssey and set the level for my sub for 75 db I put it to 80 even though Audyssey told me it was too high....I know alot of people mention they keep their sub higher than the 75 that Audyssey reccomends...But Should I have left it at the 75 so Audyssey could run the eq then, bumped it up after???
Rick
RickP.
RickPas is offline
post #107 of 4760 Old 08-07-2013, 11:12 AM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
New Marantz owner here. I just picked up a 6008. I can't wait to get home and set it all up. biggrin.gif
Jolly74 likes this.
lulimet is offline
post #108 of 4760 Old 08-07-2013, 11:31 AM
Jolly74's Avatar
I orderd my marantz 7008 yesterday smile.gif it´s coming in stores in Sweden 16e of Aug.
Jolly74 is offline
post #109 of 4760 Old 08-07-2013, 02:19 PM
RickPas's Avatar
Quoted: 40 Post(s)
another question, does it matter what order you do in the 8 position audyssey settings? I think I might have did a few not in the right order as the diagram on the 101 thread.....
Rick
RickP.
RickPas is offline
post #110 of 4760 Old 08-07-2013, 02:29 PM
socalhdtv's Avatar
Anyone update the firmware on one of these units?
I updated the firmware on my brand-spanking-new 7008 and it stopped passing through video and audio signals one day later. Eg. unit would turn on, act like everything was fine, but not output video or audio.
Apparently of the 843 7008s delivered to US customers, this was the first sent back for repair.
My replacement unit wants to update the firmware but I'm gun shy about doing so.
socalhdtv is offline
post #111 of 4760 Old 08-07-2013, 03:03 PM
socalhdtv's Avatar
BTW - anyone bi-amping their unit? I'm bi-amping and running Zone 2 and Zone 3 off of a separate multichannel amp. I wonder if the bi-amping fried it?!?!
post #112 of 4760 Old 08-07-2013, 06:50 PM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
I opened up the box and I am disappointed that the remote is not back lit like my SR5005's was. frown.gif
lulimet is offline
post #113 of 4760 Old 08-08-2013, 05:01 AM
enjoythemusic's Avatar
socalhdtv am bi-amping the Dunlavy's and works fine here.
Firmware update went ok, but seemed to turn on Zone 2 and 3, thus had to turn them off to get proper video rez fed out to the Poineer Kuro.
Jolly74 likes this.
enjoythemusic is offline
post #114 of 4760 Old 08-08-2013, 07:04 AM - Thread Starter
Liked: 1285
I did updated the firmware on my SR7008 last week with no problems. Everything is working fine since the first day I got it. I got mine July 19th.
post #115 of 4760 Old 08-08-2013, 04:57 PM
jdsmoothie's Avatar
Liked: 6178
Rick
No, order does not matter ... just vary the positions within a 2'-3' radius around the #1 mic position and you should be good to go. smile.gif
post #116 of 4760 Old 08-08-2013, 05:00 PM
jdsmoothie's Avatar
Liked: 6178
Rick
No, Audyssey ignores any settings you have prior to running Audyssey. Yes, adjust the sub volume after Audyssey has completed as most folks like to run the sub about 5db hot.
post #117 of 4760 Old 08-08-2013, 10:56 PM
Jolly74's Avatar
Rick
Jolly74 is offline
post #118 of 4760 Old 08-09-2013, 09:25 AM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
I encountered something that I thought is strange. I wanted to play some apple losless tracks through the network feature from my NAS but the receiver wouldn't play them. No problem playing my tracks in MP3 format.
Then I used AirPlay to play apple losless tracks from my PC, which is connected to the SR6008, and they played with no problem. I thought that was strange.
lulimet is offline
post #119 of 4760 Old 08-09-2013, 12:08 PM - Thread Starter
Liked: 1285
What kind of NAS do you have? I have a Synology DS712+ and have no problems with FLAC or ALAC files. Try enabling DMA Compatibility.
post #120 of 4760 Old 08-09-2013, 01:48 PM
lulimet's Avatar
Quoted: 94 Post(s)
Liked: 92
It's a WD MyBook Live. It has the Twonky media server. I am not sure I have seen the options you have in yours.
lulimet is offline
Marantz Sr5008 , Marantz Sr7008 , Marantz Sr6008
