The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 501Likes
post #1441 of 4833 Old 02-18-2014, 08:18 PM
Selden Ball's Avatar
Quoted: 3503 Post(s)
Liked: 1771
Originally Posted by rgiorgio View Post
just got message for new firmware update. anyone know what is does?
It fixes the Netflix Dolby Digital Plus bug.
Apparently Dolby updated the DD+ encoder and made it slightly incompatible with existing DD+ decoders, primarily resulting in distortion in the center channel audio. Netflix is using the new encoder. Lots of people with lots of different AVRs have been complaining about it for the past few months. D&M announced a schedule for when various Denon and Marantz audio equipment would be updated over the next month or so. It's your turn.
ProUnion likes this.
Selden
Selden Ball is offline
post #1442 of 4833 Old 02-18-2014, 10:46 PM
ProUnion's Avatar
Originally Posted by jdsmoothie View Post
SAVE/LOAD Audyssey settings
Yes, when it is connected to the home's WiFi network. Follow the directions I list in item #2 of the post below for either Internet Explorer or Chrome.
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq/0_100#post_23134212
Thanks JD!! Works like a charm...And also thank you for the great deal on my Marantz SR7008..I'm really enjoying XT32 Now to learn REW..
If anyone is in the market for a new AVR I'd highly suggest talking with JD @AV Science
AVR Marantz  SR7008
Mains Paradigm  Monitor11 S7
Center Paradigm Studio CC-590v5
Suround Polk RM2300
Sub Rythmik FV15HP
LED Samsung UN55F8000
ProUnion is offline
post #1443 of 4833 Old 02-19-2014, 05:54 AM
mthomas47's Avatar
Quoted: 3404 Post(s)
Liked: 5015
I had the same question since it is such a long update--53 minutes on mine. I just found this:
"Jan 29, 2014
Important message about Netflix and Dolby Digital Plus audio signals
Dear Marantz Owner,
Please be advised that we have identified an issue with some Netflix devices transmitting Dolby Digital Plus audio signals to our audio video receivers. We will start rolling out an online firmware update to correct the problem with effected models towards the end of February, staggering the update between models into March. In the meantime, setting your Netflix device’s digital audio output to PCM or Stereo should temporarily alleviate the issue.
We appreciate your continued patience as we work to resolve this issue.
The Marantz Team
Firmware Update Schedule
February 20 : SR6008, SR7008, AV8801, AV7701
March 6 : NR1504, NR1604, SR5008
March 19 : NR1603, SR7007
March 27 : SR6007, SR5007"
mthomas47 is offline
post #1444 of 4833 Old 02-19-2014, 08:14 AM - Thread Starter
enricoclaudio's Avatar
Quoted: 1512 Post(s)
Liked: 1666
Updating my 7008.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL, Sierra 2s & Lunas | Rythmik F12SE (x2) | Emotiva XMC-1 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Bluesound Node 2 | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
post #1445 of 4833 Old 02-19-2014, 12:47 PM
CrashMeister's Avatar
Question about the SR5008 and subwoofer (LFE, LPF).
My front (L&R) speakers are more than capable of handling bass. When listening to music (CD, AirPlay) I do not want the subwoofer active. I prefer direct stereo playback.
When watching TV or Movies, I want the subwoofer to be active.
The manual is somewhat confusing. It talks about LFE and the speaker bass as being separate, hence adding them together. I thought all bass below the crossover was LFE.
I have a 7.1 speaker setup. For music I only want the front L & R active with no subwoofer. For all else I want the full 7.1 available.
Can someone please clarify what can be set and under which circumstances.
Craig.
CrashMeister is offline
post #1446 of 4833 Old 02-19-2014, 01:03 PM
Liked: 1771
Craig.
LFE = Low Frequency Effects. It's the .1 channel in multichannel (e.g. 5.1) movie soundtracks. Sometimes people misuse that acronym when they actually mean the subwoofer output channel of the receiver. For example, D&M misuse it in their manuals and controls when they refer to the option "LFE+MAIN".
The subwoofer channel gets both LFE and whatever low frequencies bass management has removed from other speaker channels.
If you don't want any bass management to be applied to your stereo music, you have two options:
1) Change the configuration of the receiver's front speaker channels from "Small" to "Large". Bass management is disabled for "Large" speaker channels. Audyssey is still enabled, though.
2) Select either the "Direct" or the "Pure Direct" options. They disable all digital processing, including both Audyssey and bass management.
TurboTropic likes this.
Selden
post #1447 of 4833 Old 02-19-2014, 01:32 PM
Thanks for the reply. Just to confirm: If I select Pure Direct then the original source after DAC is passed ONLY to the front L&R speakers ?
post #1448 of 4833 Old 02-19-2014, 01:34 PM
Another SR5008 question. On my current AVR I can set the default decoding per input. So for a CD I can set 'Direct'. This means it will always switch to Direct whenever I change the source to CD. Does the SR5008 have this? I can't find it in the manual.
It's called "Listening Mode Preset" on the Onkyo. For each device, it allows a default listening mode for each input mode (Analog -> Direct; DTS -> THX Cinema etc.).
Craig.
post #1449 of 4833 Old 02-19-2014, 01:51 PM
Liked: 1771
"Direct" sends the input audio channels directly to the associated speakers. If it's a stereo soundtrack, only the front pair of speakers will be active. If it's a multichannel soundtrack, only those speakers will be active which are associated with the specific channels which are included in the soundtrack. "Pure Direct" also turns off some of the receiver's video circuitry to minimize any potential electrical interference, which is minimal anyhow.
Selden
post #1450 of 4833 Old 02-19-2014, 06:22 PM
jdsmoothie's Avatar
Quoted: 15372 Post(s)
Liked: 7517
Firmware Update
The first round of Netflix DD+ firmware updates was released today for the mid/upper level Denon and Marantz AVRs to include the SR6008 and SR7008. There are also a bunch of additional fixes as well which is why the update is 53 minutes in length. Although the AVR will generally provide an update notice, if that is not the case on your unit, simply select the Check for Update setting and start the update. You may want to wait a few days as the servers can get overloaded the first few days of a firmware release.
2/19/2014
- Crestron update
- Sirius XM API2.0
- When DTS-HD MA 96k audio is streamed, there is noise or no output
- Noise from DD+ stream from Netflix
- WMA 11/12 files not playing
- Noise from WAV file in NAS (Twonky Server 7) via remote app
- MSLEFT and MSRIGHT of the AMX command
- Noise between tracks of FLAC file
- No communication with Buffalo LInkStation
- No sound from SW in PURE DIRECT
- DIalogue Enhancer set by Menu is not memorized
- When connected Server shuts down in the Resume play of Last Sation of iRadio, the browsing of iRadio cannot be done
- AMP ASSIGN 7.1 + Zone 2, unable to choose SB/FH/FW (SR7008 only)
*** The 5008 is expected to receive the update on March 6.
jdsmoothie is offline
post #1451 of 4833 Old 02-20-2014, 12:46 PM
fx3000se's Avatar
Firmware update ... "Update retry" ...
Just got the notification about the new firmware today and said YES, DO IT.
1h later (no error, no notification) my SR 6008 rebooted and on the screen it said "Update retry" and it started again downloading,...
Should I let it go? I will...
(BUT) If it ends up in an endless "Update retry" loop, what should I do then?
fx3000se is offline
post #1452 of 4833 Old 02-20-2014, 01:04 PM
jdsmoothie's Avatar
Liked: 7517
Try powering the unit into Standby mode using the button on the front panel.
post #1453 of 4833 Old 02-20-2014, 01:07 PM
fx3000se's Avatar
2nd update try is still ongoing. Should I wait, or press the button now?
THX
fx3000se is offline
post #1454 of 4833 Old 02-20-2014, 01:24 PM
fx3000se's Avatar
2 attempts instead oft one ...
fx3000se is offline
post #1455 of 4833 Old 02-21-2014, 02:53 AM
atai's Avatar
Hello everybody,
I am a new owner of SR6008 and I am trying to set up this new fantastic machine on my HT.
The first problem I have found is the network connection.
I have a lot of FLAC files that I want to try to play from my new Marantz but at the moment there is no way to do it.
The Marantz is correctly connected to my home network and I can see my NAS (ReadyNAS N+).
I have allowed all the possible connection on my NAS and I can see the shares folder from my laptop.
I use a Sonos on my home to play these FLAC files and I never had problem about.
So why I can't find on my Marantz the FLAC files?
Everytime I select network and I browse my NAS I receive a message that say "Empy"
Please help me
atai is offline
post #1456 of 4833 Old 02-21-2014, 03:25 AM
jdsmoothie's Avatar
Liked: 7517
If they are multi-channel files, see if you can locate a stereo file instead.
post #1457 of 4833 Old 02-21-2014, 06:12 AM
atai's Avatar
Thanks for the answer.
Are all stereo files
atai is offline
post #1458 of 4833 Old 02-21-2014, 07:09 AM
restive's Avatar
Greetings
My brand new Marantz SR6008 is malfunctioning in couple of options.
1. Front USB not working. If connected an iPod or USB, it keeps displaying "Please Wait...."
2. Network could not be configured. Tried in DHCP mode. The Manual Mode is not activated in the setup options
Factory reset did not work for either of the problems. I tried updating the firmware through USB but did not work.
I thought I give it a try here, before I go to the trouble of sending it back, although I know its a long shot.
I would appreciate any effort though.
restive is offline
post #1459 of 4833 Old 02-21-2014, 04:48 PM
poolgod69's Avatar
Does the Marantz 5,6 and 7008 use a specific DAC or is their version of the DAC the Marantz Dynamic Audio eXpander (M-DAX)?
I am looking at the 6008 very highly for my wants and I am just looking for this final answer.
Thank you,
Brian
poolgod69 is offline
post #1460 of 4833 Old 02-21-2014, 05:00 PM
doopstr2's Avatar
Could someone clarify the power output of these receivers? Is the power output rated at all channels driven, or not.
For example for the SR5008, the Marantz website states "Rated at 100 watts into 8 ohms for each of the 7 channels"
However the first post of this thread states that power is rated at 100w with 2 channels driven.
doopstr2 is offline
post #1461 of 4833 Old 02-21-2014, 05:50 PM
[Irishman]'s Avatar
Quoted: 183 Post(s)
Liked: 123
Originally Posted by atai View Post
Hello everybody,
Please help me
You could also try dragging the files to a USB drive, plug it into the front USB port of ur Marantz, put the input on iPod/USB, and you can access them that way, at full rez.
COMING SOONFinding the Ark of the Covenant by Brian Roberts, in the iBook Store on iTunes, a new investigation into the Hebrew’s Most Sacred Relic!
[Irishman] is offline
post #1462 of 4833 Old 02-21-2014, 06:18 PM
jdsmoothie's Avatar
Liked: 7517
Virtually every AVR on the market is rated into only 1 or 2 CH. Marantz models generally can bench at the "marketed" rating into 2 CH.
post #1463 of 4833 Old 02-21-2014, 06:22 PM
jdsmoothie's Avatar
Liked: 7517
Thank you,
Brian
The 6008 and lower models use the same DAC although not sure of the spec while the 7008 uses the TI Burr Brown PCM1690.
post #1464 of 4833 Old 02-21-2014, 09:57 PM
Rick Young's Avatar
never mind ... I posted something about the DSPs in these units, not the DACs ... sorry ...
:o
Rick Young is offline
post #1465 of 4833 Old 02-22-2014, 12:58 AM
steveting99's Avatar
Quoted: 1842 Post(s)
Liked: 641
Hello everybody,
Please help me
Hi atai,
Has your NAS been set-up as a DLNA server? If so, has the server has to compile it's library of media folders for other devices (such as the Marantz) to serve up to. From memory, the Sonos require a PC to act as a server. The Marantz is the end device that is looking for a DLNA server that it can serve up files to.
I've got a Twonky server on the Western Digital MyBook 3TB NAS. Both the Marantz and MyBook are connected by hardwire to the router. On MyBook, I enable the Twonky server. Twonky then complies a list of all media files to be served up to DLNA clients. Using iDevice (or android), the Marantz remote app can see the media folders. I select the music folder which then lists album/artist/composer/etc. I'm able to select an album and play a tune.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #1466 of 4833 Old 02-22-2014, 08:17 AM
gce
gce's Avatar
Quoted: 47 Post(s)
I have my SR7008 and my Syno NAS connected to my network and that's it, no middle man. The SR7008 does all the heavy work and plays my FLAC files with no problems.
gce is offline
post #1467 of 4833 Old 02-22-2014, 01:50 PM
atai's Avatar
This works, but I need the access to my NAS where I have all the music files
atai is offline
post #1468 of 4833 Old 02-22-2014, 11:30 PM
atai's Avatar
Bad news!
I have selected from the list of computer available the Sonos device.
It was possible to see all the music of my NAS so I selected one song to play and from that moment the network is no more available and also the USB port.
When I select one of these 2 option I see the list of the songs from my Sonos with the one selected and an error appear say "wrong file format"
Please help!
atai is offline
post #1469 of 4833 Old 02-23-2014, 09:00 AM
atai's Avatar
Problem solved!
For the Network error I tryed everything but nothing so at the end I went on the guide set up application and I restart the network set up.
This has cleaned the network error.
Then I set up my NAS the DLNA on the correct way (the share name was not the one for the music files) and now everything work perfect
Many thanks to everybody for the support!
atai is offline
post #1470 of 4833 Old 02-23-2014, 09:05 AM
atai's Avatar
I have a question regarding the second HDMI output.
It can be used for different monitor type?
I have a VPR and a TV on the same room and I would like to use both 2 connected to the Marantz.
It's possible to use the zone 2 output for the TV just to save the VPR lamp when I don't see the movies and for ex. I want to hear some music from my NAS?
atai is offline
Marantz Sr5008 , Marantz Sr6008 , Marantz Sr7008
