The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 76 - AVS Forum | Home Theater Discussions And Reviews
 152Likes
post #2251 of 4701 Old 05-07-2014, 04:22 AM
jdsmoothie's Avatar
Quoted: 12144 Post(s)
Liked: 5532
Originally Posted by Kutter View Post
Ok, I might be missing something obvious here, but for the Network reset my understanding is I'm supposed to Power On the receiver while hold the + and - "preset" buttons. Looking at the front panel of my receiver I can't figure out which are the + and - preset buttons - I have nothing with that label.
Sorry for the dumb question...
On the SR7008, you would use the MOVIE and MUSIC buttons instead.
jdsmoothie is offline
post #2252 of 4701 Old 05-07-2014, 06:49 AM
scoe141's Avatar
Originally Posted by Chris0119 View Post
Not sure if the 7007 has HDAM (Hyper Dynamic Amplifier Module)...which is a new feature Marantz added this year.
So, assuming the 7007 does not have it, the 5008 would be a step up in that regard.
7007 has more power...and an extra HDMI out...but depending on your speakers and room size etc. I doubt if you would notice the extra 25 watts.
If you look at the specs, the DSP is the same (Analog Devices ADSP21487)...and I beleive the video chip (also Analog Devices) is the same...so in terms of video performance and compatibility they are identical.
Dimensionally the 7007 is quite a bit bigger so if you you have size constraints in your wall unit or rack that may be a factor.
Looks like they both only use the Audyssey XT, I beleive the XT32 is unique to the 7008.
Pretty much boils down to power, but I would stay with the 5008 for the HDAM alone, which seems to have a pretty significant impact on the audio overall from everything I have read.
Thanks for the input. (No pun intended of course...) Im running Infinity P163 in the front, 153 in the rear and an 8" sub.  I'll be adding a center channel at some point as well.  Room size is 12x14x9... so it's not huge by any means.
scoe141 is offline
post #2253 of 4701 Old 05-07-2014, 11:52 AM
skidawgz's Avatar
Quoted: 24 Post(s)
Liked: 45
Originally Posted by scoe141 View Post
I recently bought the 5008 and absolutely love it. However I recently saw that the 7007 is on sale for a 100 dollars more.  Im just wondering if I should return the 5008 and get the 7007. Anyone have experience with both units?  Currently I wouldn't have any need for the extras that come with the 7007.  I'm just curious if the internal components, build,quality etc of the 7007 would justify the extra 100 bucks.  Thoughts?
Thanks for any insight.
If it is only $100 I would definitely grab it. You certainly are not gaining much, but you do gain a little bit with each feature. As said a few post above, HDAM is on the 7007.
One of my favorite things about the 7xxx is the screen under flip down door. Keeps the Marantz look, and clues me in when my TV is off during music listening.
AVR: Marantz 7008 Phono: Pro-Ject Debut III Speakers: BW CMC2 + 2xCM9 (front) + 2xCM5 (rear)
TV: Panasonic 65ZT60, Samsung 60F5300
skidawgz is offline
post #2254 of 4701 Old 05-07-2014, 12:50 PM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
Well, my 7008 got here a day early yesterday, so I spent the whole morning and early afternoon today disconnecting the Onkyo 818 and connecting the 7008. I got everything all connected, even FINALLY, after 6 long years of staring at them, connected my Tannoy Mercury M1 bookshelves to use as Front Heights (too tight to do a front wide config). I've had the speaker stands ready for them for a year and a half. tongue.gif Ran Audyssey and it set my Front L/R to large -- hmm, does that mean it won't send any low end frequencies from the front to the sub? I mean, my Tannoy Sensy wide-bands do go down pretty low, 30Hz, but they hardly give the kind of BOOM you'd get from a sub, for films anyway. For music they are very respectable. Some people have been fooled into thinking I was running a 2.1 configuration. Anyway, firmware is downloading now --an estimated 52 minutes! eek.gif Time for lunch.
I do have a question about the video processing in the Marantz -- is it input specific, or does it apply universally? I don't seem to see a setting to apply the scaling to only specific inputs. For instance, I'd like to use the built-in processing on the Marantz to de-interlace the signal from the Fios box, but allow my Oppo BDP-105 to pass through untouched. Can I do that without having to switch the processing on and off manually all the time?
I did notice that, for whatever reason, the 7008 was not finding all of the hi-res FLAC music files on my NAS, For example, I recently downloaded the new Aerosmith releases from Acoustic Sounds in 96/24 and it wouldn't see them, but it would see the older Done With Mirrors 96/24 FLAC files from HDtracks in the same directory. Weird. I use the 105 for playback anyway, but if it's a defect or something, it'll have to go right back to Crutchfield.
Brandon A. DuHamel
Founder & Editor-in-Chief
TheaterByte
GoldenBoy is offline
post #2255 of 4701 Old 05-07-2014, 02:25 PM
HzSoGood's Avatar
Finally ran Audyssey on my new SR5008.
Incredible, incredible difference now from my old SR5000.  Stunning, the Game of Thrones opening theme never sounded so good.  I'm stunned.  Reality melts away within minutes of several of favorite movies and shows.  With only 5.1, there is total immersion.
One curious thing though, I expected the SR5008 (100watts) to be considerably louder than my old SR5000 (70watts).
Using their 1 to 100 scale, I'd always ran the SR5000 at "72".  The new SR5008 seems to be set at 80 for the same effect and that's still a tad low.   I know this is very unscientific but...  Curious about this discrepancy.
My speakers, remain the same as the original setup.  4 ohms...
HSG
HzSoGood is offline
post #2256 of 4701 Old 05-07-2014, 02:47 PM
jdsmoothie's Avatar
Liked: 5532
There is no direct correlation between the two volume scales.
post #2257 of 4701 Old 05-07-2014, 07:22 PM
scoe141's Avatar
^^^+2  I was told you can "throw that out the window".  No correlation indeed, like JD said.
scoe141 is offline
post #2258 of 4701 Old 05-07-2014, 07:32 PM
scoe141's Avatar
Thanks skid- I was going back and forth on this for the past two days.  I finally decided today to get the 7007 and return the 5008.  I absolutely LOVED the 5008 so I hope that I won't miss it.  I combed over the features between the 5008, 7007 and even the 7008.  There really aren't many differences.  I like the added power, the front facia and of course the blue led ring.  I know it's superficial, but I just love that clean look on the front of the 7007/08. There were minimal differences between the 07/08 other than the extra channels, Audessy XT32 and some inputs.  I'm not sure if they did anything under the hood.
Is that flip down door spring loaded?  Does it flip down, or do you push it in and then comes down? I was curious how it retracted.
scoe141 is offline
post #2259 of 4701 Old 05-07-2014, 08:26 PM
rodneyiii's Avatar
Quoted: 17 Post(s)
HSG
If the volume number difference bothers you, the 5008 might have a digital gain setting like my 7008 does. That will give all the digital signals a boost at the preamp level to give the same output volume at a lower volume setting.
rodneyiii is offline
post #2260 of 4701 Old 05-07-2014, 08:27 PM
rgiorgio's Avatar
Quoted: 54 Post(s)
Liked: 40
XT32 with the Sub Eq is a huge difference
7.2 with Thiel Power Points, twin Seaton Submersive F2's in Espresso. D-Sonic Amp, Marantz Pre-Pro, Richard Grey Power, Control 4 Home Automation, lots of Blue Jean Cables, Oppo 103D, QNAP 423, Roku, Darbee, Samsung Plasma 64" 8500 all in a Salamander Synergy 247 in Walnut.
rgiorgio is offline
post #2261 of 4701 Old 05-07-2014, 08:32 PM
rodneyiii's Avatar
Quoted: 17 Post(s)
My network card lost its mind several days ago and I just unplugged the system power. It worked for me. Just like rebooting a PC.
post #2262 of 4701 Old 05-07-2014, 08:34 PM
Kutter's Avatar
Quoted: 38 Post(s)
Liked: 41
I did the Network reset and then just recalibrated with Audyssey.
The reset fixed the streaming issues. I was able to access the files on the hard drive connected to my router, but this time the files played immediately instead of locking up and not starting. 44, 96, and 192 all streamed perfectly.
I'm glad I was able to fix the issue with the reset. I guess the question is what is happening that resets are needed to fix the issue?
I didn't try unplugging the system power - in hind sight I wonder if that would have also done the trick...
Kutter is offline
post #2263 of 4701 Old 05-08-2014, 06:08 AM
jdsmoothie's Avatar
Liked: 5532
Similar to having to reboot your PC from time to time, so to must the processor in the AVR be reset, although a "soft reset" can be attempted first by unplugging the power cord for at least 10 minutes which does not reset any settings but may resolve some issues.
post #2264 of 4701 Old 05-08-2014, 06:57 AM
scoe141's Avatar
Thanks- that's what I've head around the forum.  I believe the 7007 is upgradable to the XT32, but would need to find a tuner.
scoe141 is offline
post #2265 of 4701 Old 05-08-2014, 08:22 AM
jdsmoothie's Avatar
Liked: 5532
The SR7007 only uses MultEQ XT and is not upgradeable to XT32, rather you would need to upgrade to the SR7008 to get that feature to also include Sub EQ HT (dual sub calibration). The SR7007(and the SR6008) is capable of using the Audyssey Pro Kit ($700) but the improvement would not be even close to just upgrading to XT32 for roughly the same cost as the Audyssey Pro Kit is going to use the same MultEQ XT that is on the AVR.
post #2266 of 4701 Old 05-08-2014, 08:30 AM
mthomas47's Avatar
Quoted: 2467 Post(s)
Liked: 3072
If the choice were between the 5008 and the 7007, I would probably lean toward the 7007, as others have advised. If the choice were between the 7007 and the 7008, I would most definitely choose the 7008. XT-32 is a substantial technology upgrade, and the audio reviews on the 7008 seem generally superior, as well. Of course, there is also a cost difference, but if you contact jdsmoothie the difference may not be insurmountable.
(I like the blue LED ring too, and the door opens by pushing down.)
scoe141 likes this.
mthomas47 is online now
post #2267 of 4701 Old 05-08-2014, 10:37 AM
tommaazz's Avatar
Quoted: 224 Post(s)
Liked: 127
Hi. I have a question...i have my sr7008 for about half a year now and i had only 5.2 speakers until now...today i have added a front height speakers (why not if the receiver is for the task wink.gif ) and i have put the receiver in 7.1 ch + zone and now i can hear the releys switching when i scroll through the movie...before i didnt hear it but now it is getting on my nerves...everytime the receiver loses the sound i can hear the releyes switching...is there something i can do or i have to live with it if i want 7.2 (with front height). anyone have any recomendtaions?
Marantz sr7008 (running 9.2 audyssey DSX, DTS:NEO X), monitor audio bx6,bx center,bx fx (4x),bx1,sub SVS sb13ultra (2x), panasonic 60asw654, LAPTOP ACER Aspire V17 Nitro Black edition
tommaazz is offline
post #2268 of 4701 Old 05-08-2014, 03:27 PM
Tom Grooms's Avatar
Quoted: 123 Post(s)
Liked: 205
You'll get accustomed to the relays clicking, that's what they do. Give it a week and you won't even notice.
Hear me now, Listen to me later....
Tom Grooms is offline
post #2269 of 4701 Old 05-08-2014, 03:47 PM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
That clicking has been bugging the crap out of me. OTOH, it is not as loud as the clicking from the Onkyo 818, but the Onkyo did not click as frequently. This 7008 clicks even when I skip through commercials on the DVR.
Brandon A. DuHamel
TheaterByte
post #2270 of 4701 Old 05-08-2014, 06:16 PM
Damon2311's Avatar
Can anyone suggest full range speakers for a marantz sr7008, I don't want to add a amp. Budget of 3,000 I have def tech bp7004 now love everything about them but the mids are lacking, compared to infinity beta 50s I had. I have been looking at the kefs Q and R series but there is know where around me I can listen, also I seen that drop low and should be treated as a 4 ohms speaker. I heard the b&w cm9 and Martin logan motion 40, I prefer the logans also a 4 ohms speaker. I also been doing my research online of jbl studio 580 and some Internet direct aperion, emp, svs, and so on. I wanna find maybe a high efficiency 6 to 8 ohm speaker, with out any outboard amp I want the sr7008 to handle everything I have it hooked to a panamax m5300 for clean power and high cables. Also I have done a little research on MA gx300. So marantz sr7008 owners can u guys steer me in the right direction and tell me what you think, starting to get very confused.
Damon2311 is offline
post #2271 of 4701 Old 05-08-2014, 08:12 PM
scoe141's Avatar
Thanks JD.  Very helpful!
scoe141 is offline
post #2272 of 4701 Old 05-08-2014, 08:20 PM
Tgterm's Avatar
Quoted: 178 Post(s)
I just realized that the Vienna Acoustic Haydns I am running on my sr7008 are 4 ohm speakers. Is this a dangerous situation for this receiver? They are older speakers, and I have been considering an upgrade, but like Damon 2311, I'd be very interested in expert opinions here...thanks.
Tgterm is online now
post #2273 of 4701 Old 05-08-2014, 08:36 PM
Chris0119's Avatar
I am running Aperion Intimus speakers with my 5008...the sound is pretty amazing (5.1 config).
I like Aperion because they are very neutrally balanced speaker...solid construction, thick 18mm MDF casing etc.
They seem to pair well with Marantz...so much so Aperion sells Marantz and only Marantz receivers on their website.
I took a leap of faith having never heard Aperion...but after all the positive reviews I decided to give it a shot as I was on a $2500 budget for speakers at the time.
Thus far I have no regrets.
I have heard more expensive Paradigm's, and Klipsch reference series (RF-82 package)...and to me...the Aperion's seem warmer and more tonally consistent throughout the full sound spectrum. The imaging is amazing...and finally - the aesthetics (forgive my bias) are fantastic.
The free shipping and 30 day trial period is nice as well.
That said, all speakers have their highs and lows (no pun intended)...so I guess its all a matter or preference, and of course budget!
Final note, Aperion's are pretty efficient and easy to drive, so the 7008 could handle them with ease up to a 7.2 config I would think without any issues.
Chris0119 is offline
post #2274 of 4701 Old 05-08-2014, 08:43 PM
Chris0119's Avatar
The settings for video and audio are input specific...so whatever input you are on when you make setting adjusts will remain tied to that particular input.
P.S - IMHO forego the 'double bass' approach and set your FL/FR speakers to small...they may be good at handling LFE...but generally you will get cleaner/crispier bass letting your sub handle anything below 60-80Hz...especially since you have the XT32 with the 7008 and it does such a good job at stringing everything together.
post #2275 of 4701 Old 05-08-2014, 09:35 PM
skidawgz's Avatar
Quoted: 24 Post(s)
Liked: 45
Don't seek advice here, post in the speaker section! Not that many people will see your post in this thread.
skidawgz is offline
post #2276 of 4701 Old 05-08-2014, 10:33 PM
Damon2311's Avatar
Thanks Chris, sorry skidawdz
post #2277 of 4701 Old 05-09-2014, 12:10 AM
Zsoltan54's Avatar
I absolutely love my GoldenEar Triton Two Towers. Sonic perfection, efficient, and affordable. Also look at the rest of the GoldenEar line. Raking in the awards and accolades everywhere.
Zsoltan54 is offline
post #2278 of 4701 Old 05-09-2014, 03:59 AM
steveting99's Avatar
Quoted: 1795 Post(s)
Liked: 614
Damon2311,
Welcome to AVS!
Speakers are a very personal choice.
I initially went with and up-grade with KEF speakers and compared to my older HTiB system, it was definitely a step up in sound quality. Inevitably, the itch to up-grade comes up now and then (think AVS members call this disease up-gradititus:eek:), causing some who this disease to ask on AVS forums questions like what is better sounding; A or B? The smartness of the reply is usually go and have a listen... Unfortunately this just causes frustration as there are so many variables affecting the listening experience; i.e. room, source, sound pressure levels, placement, budget, etc. So they go researching, find new interesting speaker manufacturers and try to narrow down their choices. They then ask again on the forums, what is better sounding; A or B? The same smart reply comes back ... go and have a listen. Frustration sets in, then...
It is unfortunate there is no cure for this disease..
I say the above in jest as it's currently happening to me. Your current def tech speakers are nice. I would like to go over the big picture regarding sound reproduction chain in most homes. It goes something like this:
(i) Source (i.e. CD/vinyl/computer file) ---> (ii) device player (i.e. CD player/turn table/media player) ---> (iii) pre/pro ---> (iv) amp ---> (v) speaker ---> (vi) room interaction ---> (vii) listener's ears
I assume you've got (i) and (ii) sorted out. The Marantz SR-7008 is (iii) and (iv) combined as an AVR. Since (vii) can't be changed, that just leaves (v) the speakers and (vi) room interaction. You might want to try improve sound quality through placement of your current speakers and listening position with measurement like REW first as it more cost effective. Room treatment is another option to deal with (vi) and generally improves sound quality overall.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
post #2279 of 4701 Old 05-09-2014, 07:29 AM
HzSoGood's Avatar
(Regarding:
"Originally Posted by HzSoGood View Post
HSG")
Thanks Rodneyiii,
This is a very useful suggestion.  I've set my "amp output safety limit" to 80, which is the highest value the SSR5008 permits.
If I could set it to 85, I would; but it's either 80 or full 100.
I hope to find this digital gain setting info in the manual.  I feel like it could use just a tad more punch at that level from time to time depending on what I'm listening to.
OK, just did a quick look through manual seems like it might be available in the "Sound modes and surround parameters" Section...
HSG
HzSoGood is offline
post #2280 of 4701 Old 05-09-2014, 07:37 AM
GoldenBoy's Avatar
Quoted: 34 Post(s)
Liked: 26
Right, but the Manual seems to say that if you make changes to the settings after running the Audyssey setup you can no longer apply Audyssey dynamic EQ and so forth? I'm confused, because the manual is very poorly written and laid out, IMHO.I've just been trying to feel my way through all of the settings and peeking at the manual, abysmal grammar and all.
EDIT: Page 192 of the manual:
  • If you change the speaker settings after performing Audyssey® Setup, it will not be possible to select Audyssey MultEQ® XT32, Audyssey Dynamic EQ® and Audyssey Dynamic Volume® (vpage 167, 168, 169).
  • “Manual Setup” can be used without changing the settings. Please set if necessary.
So how do I get the benefit of XT32 if it can't be used once I go in and change the speaker size settings manually? Or is that a misprint? I don;t quite understand that last line there about manual setup being used without changing the settings. (???)
Brandon A. DuHamel
TheaterByte
Marantz Sr5008 , Marantz Sr7008 , Marantz Sr6008
