The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 86 - AVS Forum | Home Theater Discussions And Reviews
 152Likes
Old 07-02-2014, 10:22 AM
Liked: 4
^ I with ya... my Marantz 5008 gets very warm\hot... but I am not sure to what extent is 'normal' for these receivers either.
Does anyone run a separate external fan on theirs?
Shimmy Bang Bang is offline
Old 07-02-2014, 10:29 AM
garontee's Avatar
Liked: 0
Originally Posted by rodneyiii View Post
Do you already have the cooling fan? If not, look at the fans from the ebay seller below. He has units that are powered by a variable voltage transformer but use the 12 volt trigger output on your 5008 to turn the fans on and off. He also has thermostat controls for turning the fans on as well. I have one of these setups on my 7008 and it works great.
http://stores.ebay.com/AV-Cabinet-Co...p2047675.l2563
The fans I have are free salvage from old computers, I was going to buy silent fans. Now I don't have to, those are the perfect solution. I have never used the 12v trigger, I had looked into soldering my own relay for it but got overwhelmed and wasn't sure I knew what I was doing. Thanks for the tip, I'm off to buy one of those.
garontee is offline
Old 07-02-2014, 08:05 PM
CHILINVLN's Avatar
Quoted: 37 Post(s)
Liked: 33
Any issues with the SR5008 properly handling a SVS PB-2000 subwoofer?
http://www.svsound.com/subwoofers/po...0#.U7S6DiQgZaE
I just wanted to verify before I went through the hassle or ordering and testing it out.
CHILINVLN is offline
Old 07-02-2014, 08:53 PM
x0tiq's Avatar
Which Blu-ray player that goes nicely together with SR5008?
x0tiq is offline
Old 07-02-2014, 10:53 PM
steveting99's Avatar
Quoted: 1795 Post(s)
Liked: 614
Chilinvln,
Most modern AVR's incorporate bass management including directing the LFE signal to the sub. So any current Marantz AVR would work with any current sub.
The issue of the sub being right for your room is the issue. How much volume of air the sub needs to displace to reproduce the bass frequencies is very dependent on the room dimensions, Main Listening Position and sub placement.
Note that room correction for the bass frequencies helps and Audyssey makes a noticeable difference in the sound reproduction chain. This is apparent when engaging Audyssey Dynamic EQ and Dynamic Volume.
Marantz SR-7009, Oppo BPD-93, MTV 7000D, aTV, Harmony Home Control remote, KEF E301+T101, MiniDSP (2x4)+(10x10HD)+(DDRC-88A), Emotiva 2xXPA-5 (Gen2), Rythmik 2xF12G+2xF8, HiMedia Q16, LG 55EC9300.
steveting99 is offline
Old 07-03-2014, 01:13 AM
jdsmoothie's Avatar
Quoted: 12160 Post(s)
Liked: 5539
No. The sub can be used with any of these models.
jdsmoothie is offline
Old 07-03-2014, 01:35 AM
Liked: 614
x0tiq,
Any modern blu-ray player have HDMI out that would be connected to the Marantz SR5008.
A popular model on AVS is the Oppo BDP-103. Once the sticker shock is overcome, most consumers wouldn't need all the features offered by Oppo. Not to worry, there's plenty of choice from the like of Sony, Panasonic, Samsung, LG, etc. that one can look at.
CNET offers some interesting write-ups: http://www.cnet.com/topics/blu-ray-players/
Old 07-03-2014, 06:26 AM
CHILINVLN's Avatar
Quoted: 37 Post(s)
Liked: 33
Originally Posted by steveting99 View Post
Chilinvln,
Approximately 3,000 cubic feet. Primary listening position is about 60-80% back from the screen depending which row you sit in. Sub can be placed either in the front corner or rear corner, I currently have a .2 setup with a sub in each (smaller subs from Def Tech, front is 800 and rear is 600). My preference would be to have a large sub and under-utilize it a bit as my current subs are pushing their max limits and not quite providing enough for the room.
Old 07-03-2014, 09:06 AM
x0tiq's Avatar
x0tiq,
thanks for that link ...
x0tiq is offline
Old 07-04-2014, 10:08 AM
rodneyiii's Avatar
Quoted: 17 Post(s)
Yes, unfortunately they run warm even when not doing much work. See post 2545 above for a link to the fan company I got mine from. They have many different setups to choose from that sit on top of the AVR. They can be controlled by either an included thermostat or a relay that connects to the 12 volt trigger output on the AVR. They are very quiet but move enough air to keep the unit cooled down.
rodneyiii is offline
Old 07-04-2014, 12:05 PM
Acaps's Avatar
Quoted: 28 Post(s)
I have had my 7008 for about 6 months and am loving it - so much so that I have decided to sell my NAD M25 amp as the 7008 is driving my Paradigm's very well.
I have ran into a recent issue with airplay and need some guidance. The 7008 is hooked up to my network, and I was able to do airplay via my Iphone 4s easily - I'd simply go to my music library on my phone and hit thte little orange button on the bottom right of the phone and away it went. So irecently upgraded my Iphone with the new software. When I do the same steps on my phone to get my music going via airplay, there is no longer that orange idicator on the bottom right of the screen allowing me to play on the Marantz. For the life of me I cant find anything.
What am I doing wrong? Thanks so much
Acaps is offline
Old 07-04-2014, 12:20 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi Acaps, swipe up on the phone and check airplay is enabled for Marantz 7008.
JChin is offline
Old 07-04-2014, 03:08 PM
Acaps's Avatar
Quoted: 28 Post(s)
Perfect! thanks so much
Acaps is offline
Old 07-04-2014, 03:12 PM
Liked: 0
Airplay on screen display?
Apologies if this is answered elsewhere, but haven't seen it. Is there a way to have the 7008 put on screen (TV) information about what track is being played when using airplay? The information is scrolling across the front panel display when I flip the door down, so I know the receiver has it. (otherwise am loving this receiver . . ). All other video connections are working fine, and i get other on screen displays (e.g. setup information, volume, etc).
Is there a setting I need to change?
Thanks for the help!
Jorell10022 is offline
Old 07-04-2014, 05:23 PM
Tgterm's Avatar
Quoted: 181 Post(s)
I would really appreciate if you wouldn't mind peeking at this one and telling if if this one will work on the SR7008? I have not used one of these before, so it would save me the angst of picking the wrong one...thank you!
http://www.ebay.com/itm/Mega-fan-Rec...p2056016.l4276
Tgterm is online now
Old 07-05-2014, 06:52 AM
rodneyiii's Avatar
Quoted: 17 Post(s)
I also have a 7008 and this is the one I bought. It has two 80mm fans on an enlarged base instead of the single 120mm fan shown in yours. That one may also work fine but I wanted a bit more coverage across the top front of the 7008. The 12v trigger fans run whenever the AVR is turned on even if the unit doesn't need extra cooling.
http://www.ebay.com/itm/Receiver-Amp...-/290647791169
After using the 12v triggered one for a while, I decided to order the thermostat control unit ($15) to see how that worked. I actually like it better since the fans don't run all the time. You can get that fan/switch combo here:
http://www.ebay.com/itm/Amp-Receiver...-/360590577966
I have my thermostat set in the front center of the top vents with the fans on either side since that is where most of the heat builds up.
Go here if you want the single 120mm fan:
http://www.ebay.com/itm/Receiver-Amp...-/360341717625
The vendor, Don, was very easy to work with and answered any questions I had before and after my purchase. You won't be disappointed.
Old 07-05-2014, 07:14 AM
Tgterm's Avatar
Quoted: 181 Post(s)
Rodneyiii -
Thanks very much for the reply. So, you are using the fans with just the thermostat now, correct (I.e., not using the 12volt trigger)? At what temperature do you set the thermostat to turn the fan on?
Thanks again.
(Edit) I think I answered my own question...turns on at a preset 84 degrees...thanks.
Old 07-05-2014, 09:38 AM
x0tiq's Avatar
In afew days time, I'm sure of getting SR5008.
But after reading about Dolby Atmos, I decided to wait for the Marantz Dolby Atmos edition of amps.
Was it a good move to hold or just get SR5008?
x0tiq is offline
Old 07-05-2014, 09:58 AM
rodneyiii's Avatar
Quoted: 17 Post(s)
Rodneyiii -
Thanks again.
Yes, as you found, the turn on setting is fixed at 80-84 degrees. The vendor also has an adjustable thermostat but it costs much more and may not be worth the difference. I don't know if you saw that the power supply for the fans has a multi-volt output so the fan speeds can be fast or slow depending on your cooling and fan noise desires.
Old 07-05-2014, 10:00 AM - Thread Starter
enricoclaudio's Avatar
Quoted: 1104 Post(s)
Liked: 1133
For 5 years I have been using the same two 12V fans with my last three receivers, Onkyo 876, Onkyo 809 and Marantz 7008. They are Scythe S-FLEX SFF21E, 12V and 1200 RPM. Very silent (20dB) with a lifespan of 150000 hours. I have them running 24/7 for the last 5 years and they work perfect, same low noise as the first day. Two months ago I got a Cooler Master JetFlo 120 fan for $18 and it's very good too. I'm using it to cool down the top part of my audio rack. It's more silent than the S-FLEX I'm using with my receiver so I may get two more to replace the S-FLEX. My point is that you don't need a thermostat or things like that, just keep the fans running 24/7. Also make sure you get a fan like the Cooler Master JetFlo that comes with POM Bearing which increase lifespan and reduce noise.
erhurd likes this.
Enrico Castagnetti @ Rythmik Audio
Media Room: Ascend Acoustics Sierra Towers w/ RAAL, Horizon w/ RAAL & Sierra 2s | Rythmik F12SE (x2) | Marantz SR7008 | Parasound Halo P5 | Emotiva XPA-3 & XPA-200 | Oppo 105D | Sony HW40ES |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac|
Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz NR1606 | Emotiva XPA-200 Gen 2 | Samsung UN50JU6500 |
enricoclaudio is offline
Old 07-05-2014, 01:28 PM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
I like to keep it simple; just put your receiver on top of your cabinet, or somewhere it is NOT inside of an enclosure, and then, you NEVER have to worry about a receivers worst enemy, heat, causing any harm..
Yeah, I know some folks can't do it for a variety of reasons, but I have ALWAYS found a way to make sure my AVR is not inside of any enclosure.
wase4711 is offline
Old 07-05-2014, 02:10 PM
vodil's Avatar
Quoted: 85 Post(s)
Liked: 27
Question Harmony Remote problem
I cannot get the up or down arrow on my Harmony One to work on my 7008. I have tried programming direct from the remote but it still does not work. Marantz remote works and Harmony arrows work on other functions. Anyone have this problem?
vodil is offline
Old 07-05-2014, 02:48 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi vodil, in the Harmony software go into review/update the Customize Button options for the Marantz. And change Tune Up/Tune Down to Direction Up/Direction Down.
JChin is offline
Old 07-05-2014, 06:15 PM
vodil's Avatar
Quoted: 85 Post(s)
Liked: 27
Thank You
That did not quite work the first time. I did it again and relearned the commands and it seemed to work.
This seems like a bug in the database. I hope someone can fix it.
vodil is offline
Old 07-06-2014, 06:32 AM
rodneyiii's Avatar
Quoted: 17 Post(s)
I'm curious if you have one of these Marantz AVR's. They all run hotter than other, similar AVRs. Mine in not in a cabinet but on an open shelf with nothing stacked above it. If I play music at high volumes for a while, I can cook an egg on the top panel. For whatever reason, the internal fan comes on much later than I would expect. $50 bucks is a cheap way to avert heat damage.
Old 07-06-2014, 06:36 AM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
Yes, I currently have a sr 6008, and it sits on top of my cabinet, fully exposed to "outside" air...
It gets warm, but not hot, no matter how I am driving it, so its never hot enough to "cook an egg" on..
Its plugged into a power conditioner, which is plugged into another power conditioning strip, so I dont know if that helps..both are Tripp Lite Products..
wase4711 is offline
Old 07-06-2014, 06:43 AM
rodneyiii's Avatar
Quoted: 17 Post(s)
Originally Posted by enricoclaudio View Post
...My point is that you don't need a thermostat or things like that, just keep the fans running 24/7.
The reason I wouldn't suggest keeping the fans on all the time is dirt, dust, and hair accumulation. Constant air movement will keep drawing junk into the unit. Any pet owners know what I'm talking about. If you have a computer that stays on all the time, take a look at how much stuff builds up in the power supply and in the cabinet. I disassemble mine about once a year and blow out the cabinet and PS to eliminate buildup on the heat sinks and circuit boards.
Natural convection keeps my Marantz cool most of the time but when needed, the extra fans turn on by themselves and do the job.
Old 07-06-2014, 06:57 AM
Tgterm's Avatar
Quoted: 181 Post(s)
Rodneyiii -
I went with the exact same fan setup you did from that seller -with the thermostat. And, you were right - very helpful vendor, answered all my questions. For 50 bucks, I like having the extra insurance when Zeppelin starts melting my 7008's innards...;-)
Old 07-07-2014, 01:52 PM
mthomas47's Avatar
Quoted: 2471 Post(s)
Liked: 3077
LFE Offset
Does anyone know whether our xxx8 Marantz receivers offer an offset option for LFE? I know that Denon does (or has) on at least some of its models, but I can't find anything in my owners manual or onscreen menu. Of course, I could just be overlooking it so I thought I would ask. Thanks!
mthomas47 is offline
Old 07-07-2014, 04:18 PM
Tom Grooms's Avatar
Quoted: 123 Post(s)
Liked: 205
Whats an "offset option" do?
Tom Grooms is offline
Marantz Sr5008 , Marantz Sr7008 , Marantz Sr6008
