The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 92 - AVS Forum
post #2731 of 2744 Old 07-24-2014, 03:59 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 389 Post(s)
Liked: 1333
Assign the OPT1 input to the same input used by the HDMI input (eg. Game).
INPUT MODE - "Digital" (p. 157 Owner's manual)
VIDEO MODE - "Game" (p. 151 Owner's manual)
"JD" – jd@avscience.com ; shop.avscience.com ; 585-645-1006, AVScience - AVSForum sponsor for 15 years
Mon - Fri: 8am – 8pm EST (Sat/Sun too, will return call if I don't pick up)
Call for pricing on Denon, Marantz, Yamaha, Onkyo, Klipsch, Def Tech, Oppo, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #2732 of 2744 Old 07-24-2014, 12:06 PM
trdtac's Avatar
Auto Standby - SR6008
New owner here of the SR6008. I am just absolutely enjoying this AVR. I do have a question if I may... Is it possible to configure the AVR to ignore certain inputs (particularly HDMI), when the Auto Standby feature is enabled?
I have a Roku 3 which when not in use, goes to sleep. It then enters a screen saver mode. It does not have an on/off button. The SR6008 is still sensing video input, which prevents it from turning off automatically..(which it is doing as it supposed to)... I want to omit this HDMI input, so the AVR can shut off...
People in my household tend to fall asleep, leaving the AVR turned on all night..
trdtac is offline
post #2733 of 2744 Old 07-24-2014, 12:16 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 389 Post(s)
Liked: 1333
If the Roku is selected as the source, you would need to either deselect it or you could also use the Sleep Timer if within 2 hours of using the AVR.
post #2734 of 2744 Old 07-24-2014, 01:53 PM
trdtac's Avatar
Thanks for your quick response of options and for your expertise.
trdtac is offline
post #2735 of 2744 Old 07-24-2014, 03:11 PM
spyrelx's Avatar
Marantz Airplay vs AppleTV - sound quality
Hi,
I'm curious if any of you have found a noticeable difference in sound quality between using Airplay functionality provided in the Marantz vs using an AppleTV plugged into an AVR. The reason I ask is I haven't purchased a new AVR yet and I'm wondering if an Airplay equipped AVR like Marantz would provide better sound for Airplay transmitted tunes than having my AppleTV plugged into an AVR that doesn't come with Airplay.
My understanding is that everything in Airplay is streamed 44/16 but that the AppleTV will convert to 48/16. So IN THEORY, using the AppleTV means you go through an extra conversion as well as additional connectors. I'm just wondering if in reality there is any noticeable difference.
spyrelx is offline
post #2736 of 2744 Old 07-24-2014, 05:47 PM
ronin22's Avatar
Originally Posted by spyrelx View Post
Hi,
Hi
I have Apple TV and just picked up a 7008 about 6 months ago. I did a test (not very scientific) between playing through the Apple TV and just using the airplay on the 7008. To my ears there was a difference and I'm sure there are people out there who would say its placebo effect but I know what I heard and I preferred airplay right off the marantz.
But then everyone's ears are different.
ronin22 is offline
post #2737 of 2744 Old 07-26-2014, 05:14 AM
Liked: 0
Video pass-thorugh
Hey guys,
I have the Marantz SR5008. Part of my setup is as follows;
  • PS3 plugged in via HDMI ( for both video and audio ).
  • PC plugged in via optical only ( just for music ).
Now, sometimes I like to play games (PS3) while listening to music (PC). So, what I'd need is a kind of HDMI pass-through, but for when the receiver is on another source, instead of in stand-by. I've already tried assigning the PC optical channel to the PS3 source, but all I get is the PS3 audio, because the it is still sending audio down the HDMI. (Obviously, I wouldn't particularly like to go into the PS3 settings every time to change the audio output back and forth)
So basically, is it possible ? I want video from one source, and audio from another (even while the PS3 is still sending audio.)
theghostoutside is offline
post #2738 of 2744 Old 07-26-2014, 06:35 AM
JChin's Avatar
Quoted: 41 Post(s)
Liked: 122
Originally Posted by theghostoutside View Post
Hey guys,
Hi theghostoutside, while listen to PC (assigned to optical 2 "CD") and the PS3 is on, press the "Option" button, scroll down to "Video Select" and select yes and choose the PS3 as the source .
JChin is offline
post #2739 of 2744 Old 07-26-2014, 06:38 AM
lulimet's Avatar
Liked: 55
Yes, Jchin is right. That's the way to do it.
lulimet is offline
post #2740 of 2744 Old 07-26-2014, 04:21 PM
Liked: 0
Wow. Too easy. Thanks guys.
post #2741 of 2744 Old 07-28-2014, 08:47 AM
ajmasala's Avatar
Hi :
I have an SR6008 AVR. I recently purchased a two channel amplifier to drive my mains L&R.
I have the 2ch amp hooked up to the two pre-outs on the AVR and all seems to be well. The amp is currently driving my main speakers.
I was wondering if there is an additional setting on the AVR where I inactivate the AVR's amps for the L&R speakers ?
I cant find anything in the Marantz manual other than how to connect an amp to the pre-outs.
Thanks..
ajmasala is offline
post #2742 of 2744 Old 07-28-2014, 08:47 AM
inklake's Avatar
Hi,
When I go to the radiomarantz.com vtuner page, changes I make to the "Added" stations, are not being picked up by my receiver.
This used to work.
On the radiomarantz page it says:
Your added station <station> will appear on your MARANTZ Product after it is next updated. You may update your MARANTZ Product immediately by following the Manual Update instructions that came with your MARANTZ Product.
I have an SR6008.
inklake is offline
post #2743 of 2744 Old 07-28-2014, 05:41 PM
gce
gce's Avatar
Originally Posted by ajmasala View Post
Hi :
Thanks..
All you have to do is hook them up. No additional settings. You should run audyssey again.
gce is offline
post #2744 of 2744 Old 07-28-2014, 06:04 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 389 Post(s)
Liked: 1333
Hi :
Thanks..
The on board amps will always be active. No way to shut them down.
Marantz Sr5008 , Marantz Sr7008 , Marantz Sr6008
