The **OFFICIAL** Marantz SR5008, SR6008 and SR7008 AV Receiver Owner's Thread - Page 99 - AVS Forum
post #2941 of 2957 Old 09-14-2014, 07:48 PM
steveting99's Avatar
Quoted: 205 Post(s)
Liked: 91
Originally Posted by cordobaman View Post
Pending an "Official" SR5009 thread...
Is anyone using a SR5009, streaming DSD via a NAS on a wired network (.dsf files)? Will the SR5009 play the .dsf's in multichannel? How does the sound/function of the DAC in this Marantz compare to others (like in an OPPO 105D)? TY!!
The 2014 Marantz models support DSD playback via network or USB. Some details for 2014 non-Atmos Marantz models are here: The *** Official Marantz NR-1505/1605 *** Slimline Receiver Owners Thread
For the SR5009, refer to page 241 of the owner's manual. There appears to be support for multi-channel DSD playback on page 123 of SR5009 owner's manual. You may want to post the question to current owners of the SR5009.
The Oppo plays back DSD via the analogue outputs that can go into the multi-channel inputs of the SR5009. Note that for this connection there would be no Audyssey room equalisation and would sound very different compared with MultiEQ ON.
Maranatz NR1504, Oppo BPD-93, MTV 7000D, LG LW6500, aTV, WDTV Live, Harmony 650 remote, KEF E301, MiniDSP(2x4), Rythmik F12G
steveting99 is offline
post #2942 of 2957 Old 09-15-2014, 05:07 AM
Liked: 0
I apologize should this question been asked before.
Recently added PS4 to my system.
Which HDMI connector should I use on the SR7008, Game or Blue Ray?
Thank you!
Jim
Jim1290 is offline
post #2943 of 2957 Old 09-15-2014, 05:22 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 982 Post(s)
Liked: 1494
Whichever you prefer.
"JD" –
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
; shop.avscience.com ; 585-645-1006, AVScience - Authorized dealer for AV Gear
Mon - Fri: 8am – 8pm EST (Sat/Sun too, will return call if I don't pick up)
Call for pricing on Denon, Marantz, Yamaha, Def Tech, Atlantic Tech, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #2944 of 2957 Old 09-15-2014, 07:22 AM
Liked: 0
Thank you JD, as always.
Jim1290 is offline
post #2945 of 2957 Old 09-15-2014, 10:32 AM
jeffbar's Avatar
Liked: 24
Seemingly simple thing that has me befuddled. I want to set the receiver so the volume is at zero every time I switch the input to Sonos.
I want to control volume through Sonos so I am not switching back from one remote (or app) to another. Right now, I have to turn the AVR volume to zero (relative scale) before using the Sonos volume control or the sound won't be loud enough
Is this possible per individual source? I also want to do the same thing on my Denon 4311. Or should I make a setting change in Sonos?
jeffbar is offline
post #2946 of 2957 Old 09-15-2014, 11:10 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 982 Post(s)
Liked: 1494
First I would suggest there's an issue if the AVR must be set to 0db. On both models you can set the Zone 2 "Power ON Volume" to 0db. On the 4311CI this can also be accomplished by using a Quick Select button for each Zone 2 source. This feature does not exist on the 2013 Marantz models.
"JD" –
post #2947 of 2957 Old 09-15-2014, 11:27 AM
jeffbar's Avatar
Liked: 24
Thanks JD. I set the AVR to 0, so I can raise on the volume via Sonos to a higher level than would otherwise be the case. With the AVR at zero, I usually don't push the Sonos about the midpoint on the Sonos app volume control before it gets too loud. I probably would be fine setting the AVR at 15-20.
I can set Zone 3 on the 4311 to a different power-on volume. Easy enough.
But I only use the Marantz for one zone (front speakers are biamped). Sounds like I have to manipulate both volume controls to get it right on the Marantz. I don't mind, but I am trying to simplify for my wife. She likes it ... real simple!
jeffbar is offline
post #2948 of 2957 Old 09-15-2014, 11:31 AM
jeffbar's Avatar
Liked: 24
On the Marantz, would there be any downside if I changed the source level on the input to the max (+12, I think), with, say, a power-on level of 25-30?
jeffbar is offline
post #2949 of 2957 Old 09-15-2014, 11:39 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 982 Post(s)
Liked: 1494
Nope, but note that both settings are connected .. so increasing the Source Level will decrease the Master Volume level the equivalent amount.
"JD" –
post #2950 of 2957 Old 09-15-2014, 06:07 PM
trmoore2's Avatar
I have a new Marantz Sr7009 and it seems warm/hot to the touch. I called Marantz and they stated that their receivers operate at 120 degrees. I placed a thermometer on top and it is 106 degrees. I am only running a 5.1 configuration, so this seems very warm. Any thoughts or knowledge?
trmoore2 is offline
post #2951 of 2957 Old Yesterday, 05:17 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 982 Post(s)
Liked: 1494
Wrong thread, But normal.
"JD" –
post #2952 of 2957 Old Today, 06:09 AM
tim leonhardt's Avatar
anyone able to get flickr working? i follow the directions in the manual yet the sr6008 can't seem to find anything. internet radio works fine.
one other item - on my nr1604 (love it) when playing the tuner or internet radio the tv will go blank after a few seconds - thus preventing burn in. can't get the sr6008 to do the same thing. it just continues to display the radio station info on the tv. i can change the video source to blu-ray with no output but it's a bit of a pain if i want to change stations...
tim leonhardt is online now
post #2953 of 2957 Old Today, 06:48 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 982 Post(s)
Liked: 1494
Setup - Video - On Screen Display - Now Playing - Auto Off (p. 159 Owner's manual)
"JD" –
post #2954 of 2957 Old Today, 07:05 AM
Ya, I've had it set to Auto Off yet it still won't go off. Tried with tuner and internet radio - no dice.
post #2955 of 2957 Old Today, 07:27 AM
Yanec's Avatar
Hi guys, please advise a new 7008 owner!
I am wondering if I should bi-amp my speakers (I would do it straight away if I didn't have to do some construction works in order to hide the new cable - this would be difficult). The speakers I am using are the Epos M16i they are 4 ohm, 88.5 dB and allow for triple amplification: http://www.stereophile.com/content/e...r-measurements
Will bi-amplification using an AVR like the SR 7008 improve audio quality and how? What should the improvement in sonic characteristics be and how is it explained? Since the speakers allow for triple amplification which two should I keep coupled? I guess the mids and highs as this seems more logical, but I highly appreciate advise!
Yanec is online now
post #2956 of 2957 Old Today, 07:36 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 982 Post(s)
Liked: 1494
Soft reset (unplug unit for 10 minutes). If no joy then microprocessor reset.
"JD" –
post #2957 of 2957 Old Today, 12:05 PM
thanks, the soft reset worked. flickr is still an issue
Marantz Sr5008 , Marantz Sr7008 , Marantz Sr6008
Gear in this thread - Sr5008 by PriceGrabber.com
