9.2 Setup - Front Wide or Front Height? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-19-2013, 11:45 AM - Thread Starter
TTUEagle's Avatar
Generally speaking, when setting up a 9.2 configuration, which is better: adding (2) front wides or (2) front heights?
Looking for feedback from users who have tried both.
My room is twice as wide as it is deep, 40 x 20, screen on front wall, with 9' ceilings.
TTUEagle
Onkyo TX-NR5009, Def Tech 7001 fronts, Def Tech CLR3000 center, (6) Def Tech BPVX surrounds
TTUEagle is offline
post #2 of 7 Old 07-19-2013, 11:55 AM
duc135's Avatar
Quoted: 154 Post(s)
Liked: 219
Tough call. I think most of the recommendations I've read is to go with wides first. I haveread a smattering here and there from some people who prefer height over wides though so YMMV. I would just try both and see which you prefer.
duc135 is online now
post #3 of 7 Old 07-19-2013, 12:01 PM - Thread Starter
TTUEagle's Avatar
Yeah, I'll probably just hook the two up and move them around in the different configs and hear which location/setup sounds best.
TTUEagle is offline
post #4 of 7 Old 07-19-2013, 12:19 PM
sdurani's Avatar
Quoted: 4479 Post(s)
Liked: 2898
7 speakers should give you a nice 2D ring of sound around you.
Wides would fill in a gap in that ring between your Fronts and Sides, assuming there is a sonic gap in that direction (i.e., you don't hear phantom imaging there).
Heights would turn that 2D ring of sound into more of a 3D bubble of sound by including a vertical element (albeit ambient) in the soundfield.
So if you don't think a 7-speaker layout is seamless enough, go for Wides. If you want to expand the soundfield vertically, use Heights.
Sanjay
sdurani is offline
post #5 of 7 Old 07-19-2013, 12:31 PM
myoda's Avatar
Liked: 57
What speakers were you going to be using for the wides? I tried the wide setup, I preferred it, but my spouse did not. My living room looked like a speaker lab, but I thought it sounded more expansive.
CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), quality = 100
myoda is offline
post #6 of 7 Old 07-19-2013, 02:19 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
Ive ran both wides and heights in the past although not at the same time with surround backs...never had the room for them. I like both configurations, but I like wides more. Interestingly enough I did not care for heights using dsx but they sounded great using dolby PLIIz. Wides sounded great using dsx. Never had an avr capable of neo x so can't comment on how that dsp sounds.
Audyssey recommends wides before heights when using dsx.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #7 of 7 Old 07-20-2013, 02:37 PM
derrickdj1's Avatar
Quoted: 877 Post(s)
Liked: 590
I have also ran FH and FW at different times with my system. I like both, then what is the difference? I used the FH when things were setup on the long wall and now use FW with the setup on the wide wall. It also depends on the ceiling height of the room as well as how wide the room is for the system. Remember that these are not major speakers and provide spatial cues for the listener. For example my FH were 9 1/2 ft off the ground and with the FW speakers, they are 6 ft from the mains.
derrickdj1 is online now
