Need new receiver!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-20-2013, 11:31 AM - Thread Starter
Dirtold's Avatar
I am needing to replace my Onkyo 875 receiver.
My choices for replacement are the Denon 4311CI or the Onkyo NR5009.
Any advice is appreciated including other suggestions.
I am only using a 5.1 system and can't really add any more speakers.
I watch cable, DVD, and streaming video.
Also have looked at Denon 3313CI and Onkyo 818 and Marantz sr7005.
I don't mind spending $1400 for a new receiver but I don't want to waste money for features I will never use.
Dirtold is offline
post #2 of 7 Old 07-20-2013, 01:41 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4780
What speakers do you have? Any particular reason you narrowed it down to the 4311CI or the NR5009?
lovinthehd is offline
post #3 of 7 Old 07-20-2013, 02:01 PM - Thread Starter
Dirtold's Avatar
I have PSB Mini Stratus speakers across the front.
No reason for choice other than reputation.
I have owned both Denon and Onkyo and been satisfied.
My main concern with them is they may be more receiver than I really need, hence the other listings.
I don't list other brands because I'm not that familiar with them, not that I am biased against them.
I have also read a lot pluses for Audissey MultiXQ32 and would like a receiver with that feature.
Dirtold is offline
post #4 of 7 Old 07-20-2013, 02:20 PM
lovinthehd's Avatar
Liked: 4780
I was wondering why a fairly high end receiver is all. As far as I know the minimum entry level is the Onkyo 818 for Audyssey XT32, so now makes more sense plus you have 4ohm speakers that could benefit from an avr with a fairly strong amp section. Personally I could go with either of your two picks and not consider them all that different.
post #5 of 7 Old 07-20-2013, 04:09 PM - Thread Starter
Dirtold's Avatar
I assume you mean the 4311CI or the 5009, but not the 818?
Dirtold is offline
post #6 of 7 Old 07-20-2013, 05:19 PM
lovinthehd's Avatar
Liked: 4780
Maybe the 818, it's on my short list for the XT32, 9 ch capability and the crossover thing. I currently have a lesser Onkyo (HTRC370) which has XT, and for now suits my purposes. However, if you want and can afford the pricier avr with a few more features, why not?
post #7 of 7 Old 07-21-2013, 02:34 AM
jdsmoothie's Avatar
Quoted: 14587 Post(s)
Liked: 6922
You may also want to consider the new Denon X4000 which also features both Audyssey MultEQ XT32 and Sub EQ HT, which although not designed to power 4-ohm speakers like the 4311CI, should be able to handle them at average listening levels, although does include a full set of 7.2 pre-outs as well.
If you give Craig from AVScience Sales a "call" on Monday .. he should be able to quote you a very reasonable price ....
jdsmoothie is online now
