Total NEWB needing help with AV Receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-20-2013, 07:10 PM - Thread Starter
farleyville's Avatar
I hate to even post this, because I know people ask all the time, and the answer will vary between everyone. However, I just purchased my first projector for my home theater and need to set up a home theater sound system.
I want to keep cost to a minimum, but want to get something that will last for a while as well. Was thinking of buying monoprice in wall and ceiling speakers and buying a receiver, but NO CLUE what i'm looking at between brands, etc.. What should I be looking for? It would be nice to be able to control through my Ipad but thats not a necessity?
Any help you could give this audio idiot would be appreciated. Thanks.
farleyville is offline
post #2 of 10 Old 07-21-2013, 04:41 PM
JBWIII's Avatar
Liked: 43
In my opinion, important features to consider:
5.1, 7.1 or more--how many speakers do you want to run? Even if you only have 5 speakers and a sub in your main room, you might still want a 7.1 because they have the capability to run a second pair of stereo speakers elsewhere in the home.
Networking--all by the most basic models these days have networking built-in. However, most do not have wi-fi built-in so you have to hook them up via ethernet cable or buy an adapter. Networking gets you (i) direct access to streaming services (pandora, etc.), (ii) Airplay and the ability to play files from your computers, (iii) control apps for apple and android phones/tablets, and (iv) easy firmware updates.
Room correction--software that adjusts the frequency curve for each speaker to try to adjust for your acoustic conditions. It uses a little microphone to do this. Many mfgrs use Audyssey; others (like Yamaha) use their own. Audyssey seems to be the leader.
HDMI standby pass-through--a lot of people like this. It gives you the ability to watch TV or a movie without turning on the receiver. Good for sleeping babies, nighttime viewing, etc., where you just want to listen through the TV's speakers. With your PJ though you might not care.
HDMI conversion--ability to take, e.g., component video (from an older DVD player, a Wii, etc.) and output it via the HDMI cable along with your other HDMI sources. Otherwise they just pass the video in whatever form it was sent and you have to run several sets of cables to your projector/TV.
Budget--how much are you willing to spend? If you have $1000 to spend, you'll get everything you need--just take your pick of the 2013 models. If you want to limit it to $300 or $500, then you'll have to make some choices.
JBWIII is offline
post #3 of 10 Old 07-22-2013, 04:27 AM
jdsmoothie's Avatar
Quoted: 12114 Post(s)
Liked: 5515
jdsmoothie is online now
post #4 of 10 Old 07-22-2013, 05:17 AM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
How big is your room and what is your real budget?
Also, is this just for home theater or will you be listening to music too?
bladerunner6 is offline
post #5 of 10 Old 07-22-2013, 07:52 AM - Thread Starter
Thanks Everyone for the responses. The room will be a dedicated home theatre, but a smaller one.. Roughly 13 x 15.. As far as budget, I really don't have one, but can't see myself spending more than $750 or so on the speakers + Receiver.
We will not be listening to much music in this room, as it will be a dedicated home theater, but I have read that some receivers have a zone 2, that might allow music to be be played in another room as well. That might be something I'm interested in.?
post #6 of 10 Old 07-22-2013, 07:59 AM
Quoted: 20 Post(s)
Liked: 59
At that budget, I would probably start with the front three, sub and receiver.
Maybe some Polks, Primus or Pioneers.
post #7 of 10 Old 07-22-2013, 10:30 AM - Thread Starter
Any specific receiver you would suggest?
post #8 of 10 Old 07-22-2013, 11:46 AM
Quoted: 20 Post(s)
Liked: 59
A refurbed Denon 1612 or 1613 from here:
https://www.accessories4less.com/index.php
post #9 of 10 Old 07-23-2013, 06:58 AM - Thread Starter
I'm currently looking at a Onkyo TX-NR616 or a DENON AVR-1913.
Both of which are 299.99 Refurbished.
Any thoughts on those two units??? And am I taking too much of a risk for a refurb... on Amazon for another $60 I can get a new unit?
post #10 of 10 Old 07-23-2013, 04:20 PM
Quoted: 20 Post(s)
Liked: 59
It looks like you are talking about the Onkyo at Amazon.
I think most people here would prefer the Denon for the Audyssey MultEQ.
