Behringer iNUKE NU1000DSP - Page 2 - AVS Forum
post #31 of 34 Old 07-28-2013, 04:35 PM
duc135's Avatar
Liked: 148
Sorry, for the late reply. Got home late from the concert and ended up having to work until 7 this morning. Took a 2 hour nap before having to do some gardening before it got too hot.
The Belkin will work, but is not ideal. It just adds another remote you'll need to use to power everything on. Your second link is exactly what you would need if the amp is connected to the same outlet or circuit as there will be no added benefit with the complexity of using homemade outlets with 12V trigger relays.
If you have the amp on a separate circuit and need step by step instructions on how to do it. Let me know. I need to make a couple more relay controlled outlets and I can take pictures as I make them and document it for you.
duc135 is online now
post #32 of 34 Old 07-29-2013, 08:20 PM - Thread Starter
powerlifter405's Avatar
All my electronics, the 3 or 4 of them will be on a single smart strip so I can try to get away w/ the triggered one.
If it doesn't work I'll PM for more info.
Thanks for the ideas!
Still a stereo Noob, Denon 2113 w/ Arx5 & A1b surrounds.
powerlifter405 is offline
post #33 of 34 Old 07-29-2013, 10:30 PM
duc135's Avatar
Liked: 148
If that's the case then all you need is a smart power strip like the one in your second link. Not sure what you'll be connecting to it and how much power you'll be giving your speakers and subs, but 15A may be pushing it a bit. You can always give it a shot. That should be the easiest route.
post #34 of 34 Old 07-30-2013, 06:01 AM - Thread Starter
I'll probably keep it simple, an Inuke 1000 or maybe a 3000 and I'll call it good. I'll have to verify the specs now that you mention it.
Behringer Nu1000dsp Inuke Power Amplifier
