Yamaha RX-V675 receiver, no subwoofer output - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-29-2013, 02:50 PM - Thread Starter
Defcon's Avatar
Quoted: 1104 Post(s)
Liked: 572
I have a RX-V675 connected to a SVS cylinder sub via the sub1 preout. YPAO was run with gain at 0 and sub volume at 50% as suggested in the manual. The results of YPAO were -
- all distances were accurate
- all my speakers were set to small, which is correct.
- the LCR and surround speakers were set to either 0dB or a small value like +/- 2dB, sub was set to -4.5dB. I tried increasing the sub gain to no effect
- I set bass crossover to 80Hz
From the setup page, test tones to all speakers are fine, but the sub is not audible. If I turn the sub to nearly 100% then I can hear a faint output but that's obviously not right. With my previous Pioneer receiver, I barely had to set the SVS to 1/4th volume to get enough bass for my apartment. With Yamaha, even without YPAO I should be able to hear bass, right?
Defcon is offline
post #2 of 11 Old 07-29-2013, 03:16 PM
abba1's Avatar
Quoted: 23 Post(s)
Hi have the 3010 and have witnessed the same thing. I don't believe that Yamaha / YPAO emits test tones for subs. Could be wrong.
abba1 is offline
post #3 of 11 Old 07-29-2013, 04:06 PM - Thread Starter
Defcon's Avatar
Liked: 572
Forgot to add - the Sub is set to Normal, and Phase is Neutral.  I have heard the test tone but it is really faint and only when I turn the sub all the way up. And YPAO did detect that a sub was present.
But your sub is working, right?
Defcon is offline
post #4 of 11 Old 07-29-2013, 09:32 PM - Thread Starter
Defcon's Avatar
Liked: 572
Any advice or things to try? I see this is a very common issue with Yamaha, but I find it hard to believe. I know my sub is working just fine. And I've tried every setting I can see in the setup menu.
ellievsir likes this.
Defcon is offline
post #5 of 11 Old 07-30-2013, 05:19 AM
abba1's Avatar
Quoted: 23 Post(s)
[/quote]
Yes, the sub is working. Look it, I'm no pro at these things so I'd like to think that YPAO got it right or at least in the ballpark! My only suggestion to you is to let your ears be the judge. Pick a familiar movie and listen to the bass. If it's too weak, kick up the sub volume in the manual set-up, not the sub itself. Too strong...turn it down a notch or two. Good luck!
abba1 is offline
post #6 of 11 Old 02-15-2014, 10:07 AM
gezzerboy's Avatar
Did anyone get to the bottom of this. I have a very similar problem
gezzerboy is offline
post #7 of 11 Old 04-21-2014, 11:40 AM
audioAVfan's Avatar
Hi Everyone . . . I had a similar problem with my yamaha receiver . . . in my case the solution was simply, the problem was the wire I was using! It was NOT the correct wire for the subwoofer. NOTE, the (thick) yellow analog video cable or any component cable can be used for the sub-woofer (these cables are 75 ohm compliant, which is what is needed for subwoofer cable). If you purchase a dedicated cable for the sub-woofer, it is using the same guts as the wire used on component cable (75 ohm compliant). So, if you have an extra component cable (use the red one since that's the color usually assigned to sub wiring), use that and see if this clears up your problem. Also, try running your yamaha on pure direct to see if you hear a difference in the sub . . . pure direct removes the YPAO set up specs and uses the audio being sent without any alterations. But note, YPAO does output a subwoofer test signal. Hope this helps!
audioAVfan is offline
post #8 of 11 Old 04-21-2014, 07:18 PM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
-4.5db subwoofer setting means subwoofer gain is too high. Turn it down until ypao sets it near zero.
The cable should say 75 ohm. Ypao does output a subwoofer test signal.
kikkenit2 is offline
post #9 of 11 Old 04-22-2014, 05:04 PM
wes182's Avatar
Quoted: 51 Post(s)
Liked: 26
I had an issue with a a720. I "fixed" it by running analog cables from both of the a720 sub outputs to the sub. Sub accepted two analog inputs (luckily). I think the sub outs from Yamaha send a weaker signal. Just my subjective opinion. You can try upping the sub volume as well. Also try running the test tone at a higher level.
wes182 is offline
post #10 of 11 Old 04-22-2014, 05:27 PM
novisnick's Avatar
Liked: 29
Yamaha does run test tones, I think you have to set sub down low. I used REW to set my subs and boy! Did they come alive.
I had to manually input the peq settings.
novisnick is offline
post #11 of 11 Old 11-07-2014, 01:53 PM
Liked: 0
Same issue here, but I'm pretty sure it's not the wire.
I used the same connection in an identical receiver upstairs and the sub plays fine. This was an RCA cable from subwoofer out to sub. That connection didn't play on one 765, but did play on another. By the way, the 'troubled' receiver ran a good test tone to the sub. I just don't get it.
Any help would be appreciated.
demo4578 is offline
Yamaha Rx V675 7 2 Channel Network Av Receiver
