Denon AVR X-4000 / AVR-X3000 firmware update problems - AVS Forum | Home Theater Discussions And Reviews
post #1 of 30 Old 07-29-2013, 09:10 PM - Thread Starter
sna77's Avatar
I have been unable to update the firmware on both an AVR-X3000 and AVR-4000.
My receivers are hardwired directly into a Verizon FIOS modem and have no problems with network connectivity tests / using Sirius, Pandora etc. When I turn on the unit, I get a notification that I need to update the firmware, so I hit OK, and then the unit resets and I get a message "Update Retry Please Wait." That sets the unit into a loop, that it never gets out of. I took my X-3000 back to Best Buy and returned it for an X-4000. They'd never heard of the issue either... Decided to try the X-4000 instead... Same thing on the firmware update: "Update Retry Please Wait." If you wait long enough, you get a "Connection Fail 21" error.
I called Denon support and was given these instructions to get the unit out of the firmware loop (it worked):
Here is the instructions for a NIC card reset on a X4000 to get it out of its firmware loop.
Step 1: Turn off unit hitting the "on/standby"
Step 2: Hold down the "Up and Down arrow" on the front of the Denon. This can be located in the drop down cover.
Step 3: While holding those two buttons turn the unit back on. The front screen should start flashing. Let it flash 5 times and then let go of the "Up and Down" arrows.
Completing these steps will reset your unit and kick it out of the firmware Loop.
While that method successfully restores my receiver to factory settings, I still am unable to update the firmware. I'm within my 30 days still, and am ready to return this product if I can't reliably update the firmware.
BTW, this was the last communication I received from Denon regarding the firmware, as they've gone silent in response to my last emails.... Total BS answer as I have been trying for 3 weeks now... It's irritating as hell, because it requires me to redo all the settings every time I fail the update.
If anyone has a solution, please let me know. This is 2013--your network device needs to be able to update it's software without problems (see any TV, DVD player, AppleTV etc etc).
sna77 is offline
post #2 of 30 Old 07-29-2013, 09:38 PM
scottcocoabeach's Avatar
I have updated my X3000 firmware two times without any issues either time. The process takes close to an hour. If I had to take a guess I would think your router is probably blocking a port or otherwise blocking the transfer. I would try and go into the router and temporarily turn off any firewalls and try the update again. I seriously doubt you have received two receivers with the same issue. It's most likely your Internet connection that is causing problems. I'm on AT&T Uverse.
scottcocoabeach is offline
post #3 of 30 Old 07-29-2013, 09:49 PM - Thread Starter
sna77's Avatar
Agreed that I most likely didn't get 2 bad receivers...
That being said, Denon needs to design software that will work with basic home network setups. My FIOS router has the default settings on it--the same router they give out to thousands of customers and as I mentioned above, updates firmware without issue for a number of other network devices...
Anyhow, I made the receiver a DMZ host (no luck still), tried updating the firmware from the web interface instead of receiver (no luck) and am now messing with port forwarding in the FIOS router (the firewall settings have been set as low as possible)...
I'm about out of options now... Hopefully the Denon techs can escalate to someone who wrote the software for the device so they can tell me more info about the ports and type of packages being sent down...
sna77 is offline
post #4 of 30 Old 07-30-2013, 03:42 AM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5499
Although the issue is indeed likely related to settings on your FIOS router, there are some things you can try ....
The 'Official' 2013 Denon "E Series" / "X Series" AVR Model Owner's Thread & FAQ
Also note that the Web Control feature allows you to SAVE the configuration file (to include Audyssey) to a PC so if you have to reset the unit the config file can be LOADed to restore the unit to the configuration settings prior to the reset.
For more info, join us in the 2013 Denon AVR-E/X Models, especially reviewing posts #3-6 in that thread.
jdsmoothie is offline
post #5 of 30 Old 08-01-2013, 11:57 AM
Truckondo's Avatar
Quoted: 13 Post(s)
FiOS routers are the devil! I had a client with issues getting Airplay to work on a Yamaha receiver. One of my coworkers went back to her home and put on a Netgear router behind the FiOS Actiontec router and it fixed the Airplay issue. It would be nice if they would have just a basic Internet modem to interface easier with your own router like most cable companies.
Truckondo is offline
post #6 of 30 Old 08-01-2013, 12:01 PM - Thread Starter
sna77's Avatar
2 issues with that:
- FIOS communicates with all the TVs via IP. Each cable box has an IP. They chose 192.168.1.0 as their default subnet (groan).
- TIf you add another router behind the FIOS router, you wind up double-NAT'ing--which generally causes a whole mess of other issues.
That being said, I've seen the old G band FIOS routers mess with AirPlay also--Will try sticking the receiver behind an different router today to see what happens...
Do these things have wifi built in (didn't see an option)? If so, I could connect it to my 4G LTE hotspot and see what happens...
sna77 is offline
post #7 of 30 Old 08-01-2013, 05:35 PM - Thread Starter
sna77's Avatar
So I got it working... Plugged an Apple Airport Extreme in behind the FIOS firewall, and hard wired the receiver, double NATted and all. The update downloaded right away, update went off without a hitch...
GRRR, FIOS router....
sna77 is offline
post #8 of 30 Old 02-09-2014, 01:39 AM
For home use I am not sure what impact Double NATing will cause. Sure uPNP will not work but that's expected in this scenario.
T WAR is offline
post #9 of 30 Old 02-09-2014, 08:27 AM
AussieSteve's Avatar
Hello,
I recently purchased an AVR-E400 and have had exactly the same issues. I also have verizon Fios. The unit has been able to determine that an update is available (most of the time, but not always) yet the update process has never been successful.
This is mostly a problem because the TV and AppleTV etc do all update and I have consistent HDMI handshake issues. Not fun watching a movie and loosing the the picture every 5 to 10 seconds. You have to stop and restart the movie for the picture to come back (for another 10 seconds).
Trying to troubleshoot myself, I connected a packet sniffer to the network and determined the IP address of the update server (all other traffic coming out of the unit was broadcast based, only one IP comes up when you select update firmware).
This address, however, does not appear to be network accessible on the verizon network. I tried trace route to the IP and it gets several hops into verizon's network before it stops (at Newark, NJ in my case).
Which means sending a replacement device and/or troubleshooting/resetting the devices locally does not appear to have much to do with the actual problem - just the symptoms.
I have an open issue with Denon, asked them if I could manually apply the update (i.e via USB etc). Their response is "no - it cannot be done that way" - since then I provided the additional details on the connection issues and am awaiting their response.
My suggestion, in that note to Denon, is for them to find out with Verizon why we cannot see their network and update server.
If I was going to take a wild guess - the previous poster also lives in NJ, uses Fios, and therefore connection dies at same place in the network.
I could be completely wrong - but it does't seem likely. Also, any receiver could have this problem, not just the AVR-E400.
lets see what Denon do.. but if I don't hear from them soon, I will send it back, but will not replace it with another Denon since it will in all likelihood (without information to the contrary) have exactly the same problem.
Note: Having read the above posts, I may see if someone has CableVision or other provider, and try it from their house. That would eliminate the Verizon elements from the scenario.
AussieSteve is offline
post #10 of 30 Old 03-17-2014, 08:18 PM
venturacaliguy's Avatar
Just found this forum. Checking back in with any of you to see if you've had better luck placing this unit onto another providers network? I live in California and have Fios, yesterday my X3000 noticed me to update the firmware. Since then I cannot get the unit to update. Consistent network errors. I know the unit has a valid IP as I can access the setup menu through the web interface as well as the Android app I have to control it. I have tried the Factory reset but am stuck in the update loop.
venturacaliguy is offline
post #11 of 30 Old 03-17-2014, 08:32 PM
jnnt29's Avatar
Quoted: 115 Post(s)
Liked: 131
I had the same issue did a factory reset and ran a line directly from the modem by passing any network switches to my X4000 and it updated correctly.
My set up
Marantz SR-7008, Emotiva XPA-3
Samsung UBD-K8500 Ultra 4K Blu Ray Player
Klipsch RB-81II, RC-52II, Boston Acoustics Micro 120s
Klipsch SW-310, RPW-10, Samsung UN65JS8500FXZA
http://www.avsforum.com/avs-vb/showthread.php?t=1227096
jnnt29 is offline
post #12 of 30 Old 09-13-2014, 07:49 PM - Thread Starter
sna77's Avatar
Try this on FIOS routers. Fixes AirPlay issue.
There is a hidden menu on the FIOS routers:
IGMP proxy Hidden Menu
http://192.168.1.1/index.cgi?active_page=6059
Turn IGMP PROXY to DISABLE...
SOURCE: http://johndmichels.com/2012/09/06/t...store-airplay/
sna77 is offline
post #13 of 30 Old 10-14-2014, 06:30 AM
Liked: 0
First post on this forum. A bit of a "me too", I'm afraid.
AVR-X1100W connects well enough to know there is an upgrade, not well enough to complete it. Move closer to router, connect directly with patch lead, etc. Go back to Best Buy (where I bought it), plug it into a network patch - no joy. Move it two desks along, a different patch on the same network - there she blows. All updated.
This seems unreasonably sensitive to the network connection to my untutored eye. A "download the patch and install it from USB" route would be sensible as a backup, as would some kind of different time-out setting. Alternatively, Denon may just have some issues making their files visible, as previously noted. Spending an hour resetting it "4 to 5 times" doesn't make any kind of sense. What changes the fifth time that didn't change the first time?
Denon web site a bit pathetic - neither UK nor US version of the site list the 1100 as a model, never mind give me the firmware file.
So now I have updated firmware, for no known reason (no record I can find of what was the problem to which it was the solution) and an unreasonable reluctance to ever update anything again.
Damian
black_bird_blue is offline
post #14 of 30 Old 10-14-2014, 06:40 AM
jdsmoothie's Avatar
Liked: 5499
The new X1100W is listed on Denon's website at ---> http://usa.denon.com/us/product/home...rsht/avrx1100w
The firmware change log is listed in the Owner's thread at ---> The 'Official' 2014 Denon "S Series" / "X Series" AVR Model Owner's Thread & FAQ
post #15 of 30 Old 03-07-2015, 03:41 PM - Thread Starter
sna77's Avatar
update... Whatever the issue was, Denon fixed it. I got a notice for a firmware update yesterday, ran it, and it downloaded right away and installed. Finally. Ugh--tech support refuses to acknowledge the issue, then magically fix it in a firmware release.
BUT--this firmware update that just came out messes with Pandora--Pandora (which I pay for) now times out. It used to play forever. EFF YOU Denon / Pandora / whoever did this. I work from home and listen all day to Pandora on my Denon uint, now every 2 hours I have to go in front of the TV and select "I'm still listening." Guess I'll be looking for an alternative to Pandora now.
sna77 is offline
post #16 of 30 Old 03-07-2015, 03:45 PM
jdsmoothie's Avatar
Liked: 5499
Consider yourself lucky. My X4000 has always timed out from day 1 with "Are you still listening" even with a paid Pandora account.
post #17 of 30 Old 03-07-2015, 04:36 PM - Thread Starter
sna77's Avatar
ugh.. that sucks. WTF is the point. I'd guess I'll use Sirius--but the Sirius sound quality on the unit isn't as good as Pandoras...
sna77 is offline
post #18 of 30 Old 03-07-2015, 06:50 PM
highfigh's Avatar
Quoted: 560 Post(s)
Liked: 172
Hardwire the AVR when updating firmware. It's more critical that the connection be good and DON'T EVER shut down the AVR while it's updating. It can work using WiFi, but I wouldn't necessarily count on it.
If it takes a long time, do it later- it means their server is tied up. They're not google or yahoo and they don't have a way to connect an unlimited number of users.
highfigh is offline
post #19 of 30 Old 03-08-2015, 05:57 AM - Thread Starter
sna77's Avatar
Good advice, but the two things you mention (server availability and wired / wireless connection) are not the issue of the thread.
Every room in my house has cat6 run to it--every component was hardwired. The issue of the Denon units not updating behind FIOS routers was seen by many and was repeatable, regardless of a wired or wireless connection... The units won't update, but if you stick them behind a second router (double NAT-ing essentially) they immediately download the updates (so it isn't a server availability issue either).
Interested to see if others that were having issues are now able to update behind a FIOS router. If so, it would appear Denon made changes to security profiles on their distribution gateways...
sna77 is offline
post #20 of 30 Old 03-08-2015, 06:44 AM
jnnt29's Avatar
Quoted: 115 Post(s)
Liked: 131
My only way to update my 4000 is to wire it directly to the FIOS router to get the update to work. If and when the next one comes out the I'll try it off the switch.
My set up
jnnt29 is offline
post #21 of 30 Old 03-08-2015, 06:50 AM
jdsmoothie's Avatar
Liked: 5499
Sure. I actually no longer use my main system for Pandora, rather now stream it to a Denon HEOS wireless speaker, which although doesn't cut out as often, will still stop a few times a week.
post #22 of 30 Old 03-11-2015, 08:54 AM
jsevinsk's Avatar
I just tried to get that firmware update for my AVR-E400, and it went poorly. I'm stuck in that update retry loop, even after resetting it. (Hold in the two buttons, wait for five flashes). The bad part is that I'm now getting NOTHING out of the HDMI output, so I can't even use this receiver anymore until this is fixed.
No, I don't have a FIOS router.
jsevinsk is offline
post #23 of 30 Old 03-11-2015, 08:58 AM
jdsmoothie's Avatar
Liked: 5499
Unplug the power cord for about 10 minutes and then plug back in and try again. Also reboot your router. If still no joy, give the Network reset listed in the post below a try ....
post #24 of 30 Old 03-11-2015, 02:35 PM
jsevinsk's Avatar
The "network reset" worked. Thanks!
jsevinsk is offline
post #25 of 30 Old 09-12-2015, 11:29 AM
walke108's Avatar
Liked: 25
Has there been any new revelations on this? I have never been able to get my X4000 to update. I don't have Verizon Wireless. I am connected straight to the modem via Motorola Surfboard 6141 and still no luck. I have never been able to successfully use the Denon App remote control which I assume is somehow connected to the problem...
walke108 is offline
post #26 of 30 Old 09-12-2015, 11:36 AM
jdsmoothie's Avatar
Liked: 5499
The OP resolved his issue. Follow along with his posts and perhaps you will too.
post #27 of 30 Old 09-12-2015, 12:15 PM
walke108's Avatar
Liked: 25
Not quite sure what else to do. Doesn't work directly connected to modem and doesn't work connected to the airport express. What else is there to try?
walke108 is offline
post #28 of 30 Old 01-14-2016, 04:24 PM
Liked: 0
Network reset!
<The url should be here, you can find it above... I'm not worthy of posting urls yet... have to make 5 posts before I'm allowed to post any links >
I stumbled upon this thread trying to "unbrick" my AVR-X2000 receiver after update loop and trying to update via USB key as well.... the Network reset did it for me... turned off update reminders and notifications, never going down that road again....
Karl Kristjánsson is offline
post #29 of 30 Old 05-22-2016, 12:12 AM
redcoupebandit's Avatar
5-22-2016 I JUST did this upgrade to my Denon AVR X4000. I bought 2 years ago and just set it up yesterday (2 years later, along with my Epson 6030 UB Projector, Oppo 103-D, and Rythmik FV15HP DUALS.
I downloaded to a USB Zip Drive and followed instructions, took 1 hour! It had 2 minutes but I left and when I came back the stero was on (that was the last thing I had on prior to unplugging per the instructions).
OK, how do I KNOW for sure if the Update was Successful? Is there a Menu I can go and check a Firmware # to ensure I have the latest? Please let me know!
Gary
redcoupebandit is offline
post #30 of 30 Old 05-22-2016, 07:44 AM
jdsmoothie's Avatar
Liked: 5499
Gary
Yup as long as the AVR is connected to the internet, on the remote press SETUP - GENERAL - INFORMATION - FIRMWARE - VERSION ...... if it says "LATEST" it has the latest firmware.
