Audyssey keeps telling me subwoofer -12 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 32 Old 07-30-2013, 04:52 PM - Thread Starter
Smatkov's Avatar
Hi there,
Ik own a Marantz NR160.
When I run Audyssey it keeps telling me it has set the subwoofer level to -12.0 - EVEN with the volume knob on my subwoofer turned all the way down.
My sub is a Boston Acoustics ASW250. I run it on the subwoofer output on my Marantz.
Any suggestion on what to do?
The bass IS quite boomy right now...
Thanks in advance for your reply!
Marantz NR1601
7.1 setup
Infinity Mains
Mordaunt Short Center
Boston Acoustics Sub
JBL Surround Speakers
(I keep on upgrading my HT, step by step...)
Smatkov is offline
post #2 of 32 Old 07-30-2013, 04:59 PM
jdsmoothie's Avatar
Quoted: 12139 Post(s)
Liked: 5528
Yes. Review the Audyssey 101/FAQ Guide linked in my sig. You may have to turn the sub down to as low as 1 out of 10 to get the volume closer to 0db than to -12db.
jdsmoothie is offline
post #3 of 32 Old 07-30-2013, 05:03 PM
afrogt's Avatar
Quoted: 1055 Post(s)
Liked: 757
That subwoofer has line level and LFE inputs, which one are you using?
Afro GT
afrogt is online now
post #4 of 32 Old 07-30-2013, 05:03 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Originally Posted by Smatkov View Post
Hi there,
Most of the subwoofers I've worked with go stone dead with the volume turned down all the way.
Perhaps an in-line RCA-> RCA attenuator will help.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=266-234
arnyk is offline
post #5 of 32 Old 07-30-2013, 05:12 PM - Thread Starter
Smatkov's Avatar
I already turned it (volume) down completely... (had it at 5 or 12 'o' clock and ran Audyssey, then at 4, 3, 2, 1) - I have read the Audyssey how to...
I am using the LFE input on the subwoofer.
Marantz NR1601
7.1 setup
Infinity Mains
Smatkov is offline
post #6 of 32 Old 07-30-2013, 05:19 PM
jdsmoothie's Avatar
Liked: 5528
Where is the sub placed? If near a wall (or worse yet a corner), move it away from the wall/corner.
post #7 of 32 Old 07-30-2013, 05:51 PM
afrogt's Avatar
Liked: 757
Try using the line input instead. turn the crossover all the way to the right and start with the volume in the 9:00 or 10:00 position. Doesn't matter if you use left or right input.
Smatkov likes this.
Afro GT
post #8 of 32 Old 07-31-2013, 01:13 PM - Thread Starter
Smatkov's Avatar
Thanks so far all of you!
I am going to run Audyssey again in half an hour, while using the line input - sounds logical to me this could work. Right now my wife is watching television so I have no choice but to wait...wink.gif
Does any of you have a clue what might be causing the sub to keep performing too loud when using the LFE-input? Can placement be a cause? I moved the sub 10 cm from the wall (don't know in inches, I think 4?).
Will post the outcome later today, maybe tomorrow!
Marantz NR1601
7.1 setup
Infinity Mains
Smatkov is offline
post #9 of 32 Old 07-31-2013, 01:23 PM
KBMAN's Avatar
Quoted: 255 Post(s)
Liked: 139
Why don't you just use Audyssey again, and then MANUALLY set the sub volume with an SPL meter from your seating position???
KBMAN is offline
post #10 of 32 Old 07-31-2013, 01:39 PM - Thread Starter
Smatkov's Avatar
Thanks for your reply.
Here's my answer:
Because I do not own an SPL meter, for instance. Furthermore: there is nothing more to set manually -> my receiver is at it's max (-12.0 DB) and the volume on the woofer itself has been turned down completely! Wat else could I set manually?
Marantz NR1601
7.1 setup
Infinity Mains
Smatkov is offline
post #11 of 32 Old 07-31-2013, 01:47 PM
afrogt's Avatar
Liked: 757
The line input will work, just try it.
Afro GT
post #12 of 32 Old 07-31-2013, 02:09 PM - Thread Starter
Smatkov's Avatar
Hi Afrogt,
I have done as you have told me: I connected via the line input but still Channel Level reports to have set the subwoofer at -12.0 DB -> tried to set volume at 10.00, then 09.00. then minimum....
Marantz NR1601
7.1 setup
Infinity Mains
Smatkov is offline
post #13 of 32 Old 07-31-2013, 02:28 PM
mogorf's Avatar
Quoted: 1059 Post(s)
Liked: 613
Hi Afrogt,
Here's another idea for some troubleshooting. The potentiometer behind the gain knob on your sub may be kaput. Try to apply some contact spray (WD 40 or something), make a couple of quick rotations on the knob afterward. Then try to listen to some bass heavy material and see whether rotating the gain knob changes the bass volume you are hearing. If no change call for service. Report back please. smile.gif
mogorf is offline
post #14 of 32 Old 07-31-2013, 02:43 PM - Thread Starter
Smatkov's Avatar
The gain knob = volume knob?
I have 2 knobs: volume and crossover, furthermore I hava a phase switch and off/on/auto switch.
Note: I think SOMETHING is kaput for when playing the reference disk, acquired from this forum, turning the volume knob had NO effect. Cable is in line input on SW and in Pre-Out on NR1601 receiver
As stated before, my sub is Boston Acoustics ASW250
Marantz NR1601
7.1 setup
Infinity Mains
Smatkov is offline
post #15 of 32 Old 07-31-2013, 02:50 PM
mogorf's Avatar
Liked: 613
Yeah, it should be the gain knob, also known as volume knob. Leave the others (crossover knob and phase switch) untouched. Please try my idea so that you can confirm it or rule it out. smile.gif
mogorf is offline
post #16 of 32 Old 07-31-2013, 03:01 PM - Thread Starter
Smatkov's Avatar
I applied some WD40 to the metal area between the volme knob and the housing of the sub, turned the knob several times and played some content from the reference BD I mentioned.
When I turn the volume knob during playback nothing happens / changes. Just the same amount of lows which is plenty.
Knob kaput? Needs fixing?
(Need I mention the sub was 9 months of age when I acquired it?)
Marantz NR1601
7.1 setup
Infinity Mains
Smatkov is offline
post #17 of 32 Old 07-31-2013, 03:12 PM
mogorf's Avatar
Liked: 613
Me thinks knob kaput and needs fixing regardless of how old it was when you acquired it! It's kaput today! tongue.gif Good luck to Ya.smile.gif
mogorf is offline
post #18 of 32 Old 07-31-2013, 03:22 PM - Thread Starter
Smatkov's Avatar
It's turning REALLY easy, more so than the crossover knob - could be the WD40 lol
When I wiggle the knob I can hear it, it crackles the woofer somewhat so yes, it's definately broken...
Thanks for your help!
Marantz NR1601
7.1 setup
Infinity Mains
Smatkov is offline
post #19 of 32 Old 07-31-2013, 03:27 PM
mogorf's Avatar
Liked: 613
mogorf is offline
post #20 of 32 Old 07-31-2013, 03:30 PM - Thread Starter
Smatkov's Avatar
Oh, and needs fixing like: take it to a professional? Or might this be obvious to DIY, just open the unit and the problem will be seen?
Marantz NR1601
7.1 setup
Infinity Mains
Smatkov is offline
post #21 of 32 Old 07-31-2013, 04:53 PM
mogorf's Avatar
Liked: 613
Should you not be a technically savvy guy, like knowing how to use a soldering iron, I'd recommend to take it to a pro or let him come to your house. Hope this helps. smile.gif
mogorf is offline
post #22 of 32 Old 07-31-2013, 07:41 PM
crowgwu's Avatar
crowgwu is offline
post #23 of 32 Old 07-31-2013, 09:57 PM
derrickdj1's Avatar
Quoted: 883 Post(s)
Liked: 593
That avr or sub is not functioning properly. A 250 watt, 10 in sub should be easier to integrate into a system. Something needs fixing or replacing.
derrickdj1 is offline
post #24 of 32 Old 08-01-2013, 11:23 AM - Thread Starter
Smatkov's Avatar
volume knob is working now! strange but true...
looks like i am running Audyssey setup again tonight!
will post the outcome later
maybe the wd40 kicked in
Marantz NR1601
7.1 setup
Infinity Mains
Smatkov is offline
post #25 of 32 Old 08-01-2013, 12:10 PM - Thread Starter
Smatkov's Avatar
I did!
Marantz NR1601
7.1 setup
Infinity Mains
Smatkov is offline
post #26 of 32 Old 08-01-2013, 01:03 PM - Thread Starter
Smatkov's Avatar
Audyssey is my friend again!
Subwoofer is set at -2.0 DB and that's pretty good.
Watched a load of stuff from the Reference BD from this forum and it sounded good! smile.gif
Thanks to all of you guys. Hope the volume knob holds out from now...
Marantz NR1601
7.1 setup
Infinity Mains
Smatkov is offline
post #27 of 32 Old 08-01-2013, 01:20 PM
mogorf's Avatar
Liked: 613
mogorf is offline
post #28 of 32 Old 08-01-2013, 05:36 PM
afrogt's Avatar
Liked: 757
You shouldn't need the use the volume knob anymore now that your system is set.
Did you end up using the line input or LFE input?
Afro GT
post #29 of 32 Old 08-02-2013, 07:00 AM - Thread Starter
Smatkov's Avatar
Marantz NR1601
7.1 setup
Infinity Mains
Smatkov is offline
post #30 of 32 Old 08-10-2013, 09:38 AM - Thread Starter
Smatkov's Avatar
Kinda off-topic: I replaced the wire from my Mordaunt Short center speaker. I went from quite an older wire to a new and shorter Monster cable. I think it produces less volume right now. Is this possible?
I guess I will run Audyssey setup again tonight!
Oh and guys thanks again for your input to my original post!
Marantz NR1601
7.1 setup
Infinity Mains
Smatkov is offline
Boston Acoustics Asw650 10 Inch Subwoofer , Audyssey
