No subwoofer sound in Pioneer Elite SC-37 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-30-2013, 07:51 PM - Thread Starter
Chris2207's Avatar
No sound coming from subwoofer output in pioner sc-37...I used the digital audio cable instead of RCA cable and it was working fine for a day and then no sound at all. I changed the cable from Audio cable to subwoofer RCA cable still no sound coming from the receiver. I did the static test from the other end of the cable from subwoofer and it was generating the sound so the sub is working and the receiver is just not sending the signal to the subwoofer. I removed the cable from the receiver and then i touched the surface of the "Pre-out" jack in the receiver then i could see the sound in the subwoofer so not sure if the subwoofer jack gone bad in the receiver. any help is greatly appreciated.
Speaker Setup in the receiver: Front speaker to "SMALL" and the cross over frequency is "100"
Make/Model - Pioneer Elite SC-37
Subwoofer - BIC America F-12
SoundBar: Polk Surroundbar 50
Chris2207 is offline
post #2 of 4 Old 08-04-2013, 04:32 AM
aragno's Avatar
I have the same problem.
AVR: Pioneer SC-37
Sub: HSU ULS-15
-Trey
aragno is offline
post #3 of 4 Old 10-06-2013, 08:16 AM
aragno's Avatar
AVR: Pioneer SC-37
Sub: HSU ULS-15
Problem solved. New subwoofer cable did the trick. Thanks to Blue Jeans for having what I needed.
-Trey
aragno is offline
post #4 of 4 Old 11-19-2013, 06:33 AM
millenia 300's Avatar
subwoofer sound .check out in the manual speaker set up to put the subwoofer to at least ''yes'' position and for real obvious presence,must be to the ''plus'' position.Makes a good difference.seems like that being the flagship receiver,the quality of sound is important to pioneer and in that case having a too much dominante bass is not adequate they make the yes mode a very low profile bass signal. try this if you haven't. i own the same receiver and gives astonishing bass
millenia 300 is offline
Pioneer Sc 37 7 1 Channel 3d Ready A V Receiver , Bic America F12 12 Inch 475 Watt Front Firing Powered Subwoofer
