Marantz SR7007 or Pioneer Elite SC72 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-02-2013, 07:19 PM - Thread Starter
BRob1's Avatar
Hello...Looking for advice on which one to go with. I have always been an Onkyo fan but am not any longer with all the HDMI board failures. Any advice on the Marantz or the Pioneer is greatly appreciated as I have no experience with either. Primary use is 50/50 music and movies. I have been to 3 different Magnolia's and talked with 3 pretty savvy sales folks and 2 out of the 3 prefer the Marantz over the Pioneer for sound quality and as a solid/stable unit.
Thanks in advance!
BRob1 is offline
post #2 of 3 Old 08-02-2013, 07:35 PM
Sean Spamilton's Avatar
Quoted: 339 Post(s)
Liked: 364
Thanks in advance!
I don't have experience with the Pioneer units, but had the Marantz 6007 and the sound quality was excellent. Unfortunately I bought it refurb and had a problem with it, and decided upon an upgrade to the Denon X 4000 when I swapped it. I can safely say though that if I had the money for the 7008 I would have bought that over the Denon. The 7008 has Xt 32 and sub eq, .. I bet it sounds amazing. As far as the two choices you listed, i'd take Marantz for sure.
Sean Spamilton is offline
post #3 of 3 Old 08-04-2013, 07:08 AM
simp1yamazn's Avatar
Quoted: 109 Post(s)
Liked: 77
+1 for the Marantz or the Denon x4000. Both have audyssey xt32 and subeq. The pioneer's i've owned have never been as easy to set-up and their room correction is no where near as advanced.
simp1yamazn is offline
Marantz Sr7007 Home Theater Av Receiver , Pioneer Elite Sc 72
