AVR for 5.1 (Biamp) living room + Sonos - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-04-2013, 01:38 AM - Thread Starter
nonstopdoc1's Avatar
Quoted: 106 Post(s)
I am looking for a AVR to upgrade my living room setup. I want 5.1 (Fronts Biamped) + 2 channels to drive outdoor speakers via Sonos. For last few years I have been using entry level Onkyo AVRs. I am considering following three options. Which one would you guys recommend?
Denon - AVR-X4000 (7 x 125 watts)+ Sonos Connect Amp (55w x 2) - $1300 + $500
Yamaha RX-A2030/Pioneer Elite SC -75 (9 channels) + Sonos Connect - $1600 + $350
Also, Yamaha and Pioneer have very similar specs. I know both are considered very good brands. Any reason to go with one over the other?
nonstopdoc1 is offline
post #2 of 4 Old 08-04-2013, 04:23 AM
GIEGAR's Avatar
Quoted: 706 Post(s)
Liked: 1221
Nice choices. My recommendation is the Denon AVR-X4000. This is purely on the basis that it packs Audyssey MultEQ XT32; widely regarded to be the best auto set-up and "room correction" routine available in a consumer level AVR today. This will have by far the most influence on the sonic performance of the AVR. I wouldn't buy anything without it.
Doc, as an aside... forget about passive bi-amping. It makes no actual or discernible difference. Here is a great post by member arnyk that discusses passive bi-amping in some detail.
[Clever move having "Biamp" in the title though - you'll get heaps of traffic on this thread! biggrin.gif]
GIEGAR is online now
post #3 of 4 Old 08-04-2013, 04:35 PM - Thread Starter
Quoted: 106 Post(s)
Thanks mate. I will look more into biamping to see if its worth it.
post #4 of 4 Old 08-14-2013, 12:58 AM - Thread Starter
Quoted: 106 Post(s)
Just ordered an open box Yamaha RX-A2030 from an Authorized dealer for 300$ less. Let's see how it goes. Thanks for your input
