Official Pioneer SC-75/77/79 Thread - Page 33 - AVS Forum
 4Likes
post #961 of 983 Old 08-10-2014, 09:37 AM
rprice54's Avatar
Quoted: 38 Post(s)
Originally Posted by wse View Post
LAN port vs WAN port? Sorry I am not a computer expert.
Also do you know if Pioneer will offer MCACC pro on the 79?
The newest airport express has two Ethernet ports. The WAN is what connects to your ISP router (if directly connected, I use mine as a WiFi extender so nothing on the WAN port. The LAN connects to the receiver. I have a switch attached to the airport and all my devices connect through the switch (blu ray, satellite, Apple TV)
rprice54 is online now
post #962 of 983 Old 08-10-2014, 09:38 AM
rprice54's Avatar
Quoted: 38 Post(s)
I don't see them upgrading the 79. That gives folks no incentive to move up.
post #963 of 983 Old 08-13-2014, 11:18 AM
gman1217's Avatar
Liked: 0
I've got an SC-75 and have a N00b question...
I have 7.1 in my viewing area and the HDZone going to my bedroom. I want to set up a L/R zone in the kitchen and a L/R zone on the back porch that can both control their own volume (via in-wall volume controls), be run independently from each other, but would only need the same source as the what is playing in the main zone. Basically I think I need a Zone 2 to function like the speaker B setup. Does this receiver allow zone 2 to concurrently play the same source as the main zone?
If so, I would set it up as a speaker B setup and get a simple high-level speaker selector. This doesn't appear to give me the option to control the volume independently from the main area. Is that correct? Either way, since the amp is only designed to power 1 set of speakers for zone 2/speaker B this would be a problem I think?
The other idea I had was to get a separate amp as well. The problem is that on page 38 of the owners manual for the SC75 it says that HDMI audio cannot be downgraded, which makes sense. However I would need to send audio as a L/R signal via the zone 2 output, since amps only seem to take low level L/R input. The only sources I would use in these zones are connected via HDMI. Am I correct in these assumption? Any ideas to accomplish what I'm asking?
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
gman1217 is offline
post #964 of 983 Old 08-21-2014, 07:58 AM
xhattan's Avatar
You can´t get audio to Zones 2 or 3 through HDMI, only picture is available. Audio will come out from your Tv but not from speakers connected to the receiver. Only analog audio is available outside the main zone, or through USB. Airplay is available too, only if Main Zone is also connected to the iOS device.
And yes, you can control the volume independently for all zones, with the remote. But I don´t think you can set Zone 2 for two separate rooms and control volume on each one. I think a Zone 3 would make more sense, for which you would have to reduce main Zone to a 5.1 setup or add an external amplifier.
Regards.
xhattan is offline
post #965 of 983 Old 08-27-2014, 03:43 PM
Liked: 0
These are two questions to SC-75/7/9 owners :
1) my SC-77 flips to TV optical input each time it comes on via Kuro Link's HDMI control. Pioneer says it's because it recognizes my Kuro doesn't have ARC HDMI and that the only way to stop it is to turn HDMI control off, which I don't want to do. Seems like a big oversight considering the receiver is so accommodating to older input/outputs otherwise and that the Kuro was pioneer's own flagship product. Anyone know another way of stopping the auto input switch?
2) The receiver has an SR logo on the front of the face but no SR in or out port on the back. It's the first to not have the SR port. Does the IR out double as an SR out?
I'm asking because I can't seem to get my BDP-23FD to turn on with my 111FD even though the HDMI test on works in the settings menu and all other HDMI controls work. So I'm trying to get SR power on to work and it's not working from the Kuro's out or the IR out on the SC-77.
Thank you.
Ilbisonte is offline
post #966 of 983 Old 08-30-2014, 12:22 PM
KC-Technerd's Avatar
Quoted: 17 Post(s)
Liked: 103
^ I don't believe that SR has anything to do with the functioning that you are hoping for.
The Sound Retriever (SR) Link is done over HDMI. I can't find any evidence that the BDP-23FD supports Sound Retriever Link. It appears that Sound Retriever Link has always used HDMI, and never had its own port. Is there some specific unit you have seen that had an SR in or out port? I also am not finding anything that suggests that the "SR" logo on Pioneer products refers to anything other than the Sound Retriever.
From the SC-77 Operating Instructions Page 74:
When playing a compressed audio file on the player, the file’s bitrate information is acquired using the Control with HDMI function, and the sound is optimized on the receiver based on this information.
Edit: I found the info on the Pioneer SR system just after I posted this. It appears that is actually what the SR logo refers to rather than the Sound Retriever. It appears that the SR system is now incorporated in HDMI, operating through HDMI CEC, rather than having its own in and out ports. I can't find that the SC-77 Operating Instructions make any mention of SR system. Pages 73-75 cover the "Control with HDMI" functioning.
From my own experience and what I've seen others post, HDMI CEC is usually more trouble than its worth.
KC-Technerd is offline
post #967 of 983 Old 08-30-2014, 01:06 PM
dabsim's Avatar
Quoted: 12 Post(s)
I'm sorry to barge in on this forum guys,but I need some help?
I'm originally on the sc37 . No one has responded. I guess you could say our site is really lacking communication at this time?
My SC37 will not connect to internet ? When I go into settings and I go to network settings 8t just buffers? That's it? It's trying to connect and cinfigure? But pic j7st bufferz?
Pleas can anyone help me with this issue?
Thank u, James C
dabsim is offline
post #968 of 983 Old 08-31-2014, 07:37 AM
Liked: 0
Thanks for your reply. I have a Pro 111-FD and a BDP-23FD which both have SR control and Kuro link /HDMI control as separately listed control functions in their manuals. SR control would have to be a function of this receiver since it depends on the 3.5mm mini plugs, not HDMI. The SC-77 has the logo on the front and the only plugs like that on the back are the IR and 12v trigger.
post #969 of 983 Old 08-31-2014, 11:37 AM
Quoted: 17 Post(s)
Liked: 103
I looked back through the manuals for the previous generations of this receiver, and the SC-67 (2012) also has the SR logo, but no SR Control jacks. The SC-57 (2011) does have the SR Control jacks (in addition to IR and 12V Trigger) and instructions for using them. The current generation Pioneer Blu-ray player BDP-53FD also has the SR logo near the remote control sensor, but does not have any 3.5 mm jacks at all (SR, IR or otherwise), and does not mention SR Control in the operating instructions. That leads me to believe that if the SR logo is implying any SR Control functions in the recent generations of products that do not have SR Control jacks, the functionality must be through the HDMI CEC system. Perhaps the SR Control functionality was removed (perhaps it was considered redundant with HDMI CEC/Kuro Link) but for some reason the SR logo continued to be used simply to mark the location of the IR remote control sensor. I think you may have to contact Pioneer to get a definite answer on this.
post #970 of 983 Old 08-31-2014, 12:51 PM
Liked: 0
That is fascinating. With real estate being so valuable on the front of a product, it would seem strange to have it if they didn't feature it.
SR control was also part of older Pioneer products which did not have HDMI connections. So, for a receiver to have SR control it would seem to me that it would need the jacks.
Perhaps they integrated it into IR repeating jacks? I will ask pioneer.
post #971 of 983 Old 08-31-2014, 05:15 PM
saprano's Avatar
Quoted: 99 Post(s)
Liked: 249
Has pioneer's new AVR's been released yet? I don't see a thread for them.
home theater addict
saprano is offline
post #972 of 983 Old 08-31-2014, 08:51 PM
Liked: 0
Anyone with the Pioneer SCLX-77 know how to manually adjust bass for preset configurations? EG: When its set to dobly 5.1 or dts or what not how do I then turn the bass up for those settings.
I can turn the bass up for other settings "Pure direct stereo" and what not, but when its set up for movies/xbox and I click the "audio" button nothing happens.
duram is offline
post #973 of 983 Old 08-31-2014, 09:46 PM
Liked: 0
As far as I understand you could do it a few ways:
-Go into manual speaker setup in the menu and increase the decibles for the channel level of the subwoofer
-go to audio parameters, turn EQ on and adjust bass level
-choose an advanced audio setting like rock/pop
-if your sub has a volume level turn it up.
post #974 of 983 Old 09-09-2014, 02:11 PM
Liked: 0
I'm still learning the new SC-77 after about 3 weeks or so. It replaced a Yamaha V2700.
The receiver is the center of the system. Its probably a typical set up. BD, DVD, DirecTv box, all connect via HDMI. DVDR connects both directions with comp./optical. The Samsung 8500 plasma is the only output, HDMI.
I had a little issue with down sampling FLAC's from an Oppo 103D, but I found the info on this forum to correct that problem. Thanks for that.
One of the things I miss is the ability to simply select a alternate audio source while watching a separate video source. The Yamaha had a audio input select button on the remote. It made listening to music while watching the TV very easy. Is there an easy way to do this with the SC-77?
We've got new speakers too so I can't really compare apples to apples, but I'm surprised the this receiver doesn't deliver the power I was expecting. Don't get me wrong. I don't have any problems with the quality. I just want more of it. We have B&W CM10's front, CMC center, sub, in-ceiling surrounds. Even though it's set up for 5.1 we primarily listen to music. I've run the full auto MCACC a couple of times and it does improve the sound all by its self. I haven't attempted any manual adjustment. As I've said, I enjoy the quality, I just want more. Any suggestions?
Thanks all
B
Billerator is offline
post #975 of 983 Old 09-09-2014, 08:35 PM
2therock's Avatar
Hi Guys,
I have really been enjoying my SC-75 since 1/14.
I had a little scare yesterday. I use a Comcast remote to one button fire up my TV, STB, and SC-75. No issues at all, works great.
Last night I fired it up and had no audio, Changed inputs, no audio. Went to the TV & STB in the BR, good audio.
Powered it all down and up a few times with no luck.
Booted the STB. No Audio.
Comcast boxes will lose surround sound sometimes and a boot fixes it. The STB has done this twice this year.
So in looking at the SC-75 while powered off I still see a single light on the front. OK, I pull the plug.
Now its good. My question is, is this common or an indicator of sorts?
Thanks, 2therock
2therock is online now
post #976 of 983 Old 09-10-2014, 07:42 AM
gman1217's Avatar
Liked: 0
If it was a blue light on the front right side when the receiver was off, it means that you have HDMI pass-through enabled so you could watch your last used input on your TV using the TV speakers without having to turn on your receiver. I'm not aware of any light that would indicate sound issues.
I have had a few instances using my cable box where the sound doesn't trigger for some reason and everything is silent. Typically if I mute and un-mute my sc-75 it fixes it. Occasionally I'll have to change inputs and then go back to my intended input. This rarely happens though.
gman1217 is offline
post #977 of 983 Old 09-10-2014, 08:49 AM
2therock's Avatar
At first I muted and un-muted both the cable box and the AVR.
The TV has the external speakers disabled. I only have a single HDMI from the AVR going to the TV.
I also changed inputs and they had no sound either.
Oh well. Technology eh?
Thanks, 2therock
post #978 of 983 Old 09-18-2014, 10:13 AM
Liked: 0
What do some of you use for optimum 1080i - 1080p upscaled picture? The manual really doesn't say much of what PCinema, PMotion +-4, Stream or 1080p vs. 1080 / 24p do. I'm trying reduce the interlacing artifacts and the choppiness of some motion when watching Dish. Thanks.
post #979 of 983 Old 09-18-2014, 11:07 AM
ss9001's Avatar
Quoted: 218 Post(s)
Liked: 324
are you connected via HDMI? what TV do you have and what's its native resolution? what's the resolution setting of the Dish box?
sounds like you may be double-processing/scaling or doing double conversion from interlaced to progressive and back to interlaced or vice versa. obviously I don't know your experience level in making adjustments to the settings.
if the the sat tuner is set to output interlaced, most likely, then you want to leave the Pioneer res to Auto and Pure Cinema to Auto IMO. if its set to 1080p, then deinterlacing serves no purpose since it's already done by the box. the video chip in the receiver may be double-scaling or double conversion. if your TV is LCD/plasma pixel display, then IMO, it should be the device to do the deinterlacing to progressive and you may want to turn the Pioneer's video converter off and be done with it.
1) check the Dish output, change if needed
2) try setting the Pioneer resolution to Auto or Through and Pure Cinema to Auto for the Dish input. set Pure Cinema if that doesn't help then...
2) just turn the Pioneer video processor to match the same resolution & i/p as the Dish
3. or just turn off Pioneer video processor for the Dish input. let the Dish box or TV do the scaling. if turning it off solves the problem, you can leave it off or continue to try adjusting but do one at a time, not both. I forget which Prog Motion direction makes the output more match film frame rate (24) and which makes the output more match video frame rate (60) but go one way and if that doesn't help, try the other.
you also may be down-rezzing the video in the Dish and then up-scaling it back again with the Pioneer and even with that not matching the TV.
but IMO, Progressive Motion/Pure Cinema is a setting that's probably best left alone or in default setting. it effects the 3:2/2:3 pulldown in the conversion of interlaced (480i, 1080i) to progressive (480p, 720p, 1080p for fixed pixel TV's) video scan & handling video content at 60 Hz (frames/sec) vs film content at 24 frames/sec. there is no one setting that one can say will be the right one for your setup...the default has always worked for me with both a 1080i RPTV and a 1080p plasma.
it was a tweaking tool but my experience never needing adjusting with Pioneer DVD & Blu-ray players to either a 1080i or 1080p display. improperly adjusted, it can contribute to degrading an image, possibly causing judder, motion artifacts.
my advice is unless you know what these settings do & how they work, leave them at the defaults, Auto, or just turn the Video Converter off for specific inputs in the setup menu. you can have it turned on for one input and turned off for another. if you do know the terminology & understand these settings, then you can tweak knowing you could make things better or worse
I've owned Pioneer players since the early 2000's, and in each case, other than noise reduction, I left settings like chrominance, progressive cinema, etc alone. Sure I tinkered with them just to see the results but always ended up putting them back to defaults because I didn't have the calibration tools to properly use them. unless one is a calibrator or knows how to use scalers & video enhancements, they can do more harm than good.
I do recall once encountering just exactly what you described and it was because of double conversions. that's why I suggest Auto default settings or Off
my 2c
Steve
ss9001 is online now
post #980 of 983 Old 09-18-2014, 12:32 PM
Liked: 0
Thanks for the precise reply!
It's a Dish 211k @1080i -> SC-77 -> Kuro 111fd
It's funny because when I set the receiver on 1080p output I get interlacing line artifacts when there is motion, and when it is on 1080 /24p output the artifacts are gone but the motion is slightly jittered.
I tried PCinema and PMotion and Stream toggling but those didn't seem to do anything.
What settings in the TV do I change to prevent over processing?
post #981 of 983 Old 09-18-2014, 12:33 PM
Liked: 0
...and it's all HDMI
post #982 of 983 Old 09-18-2014, 01:07 PM
ss9001's Avatar
Quoted: 218 Post(s)
Liked: 324
what happened when you 1st used Dish with the Pioneer?
was resolution set to Auto? if not, try Auto, then try Pure (1080i will be sent as 1080i, let the Kuro handle it)
and just for kicks, turn the Pioneer video processor off for your Dish input. is it OK then? that's the only sure way to not double do things Auto resolution or Pure should work but even the Pioneer manual says if picture deterioration occurs with the video processor on, try turning it off.
1080p is 1080p/60 hz 1080p/24 can give you judder if source is 60 frame/sec and that's where the 3:2 & 2:3 pulldowns come into play.
Steve
post #983 of 983 Old 09-19-2014, 08:45 AM
Liked: 0
Wow thanks for the help. I have the 1080i passed through to the Kuro and not only did it fix artifact and motion issues but it also seems to have improved the picture overall.
How is this possible if the receiver's video processing is supposed to be so good?
And more importantly, when do I use the receiver's supposedly superior video processing then?
Given that I don't want to change the Kuro's settings manually when I switch receiver inputs, and given that the image processing in the SC-77 is 6 years newer and probably better than the Kuro, when / what kind of source can I use the receiver's video processing with?
Or otherwise said, what's the best way to combine these two in their settings?
Pioneer
User Tag List
