Krell Foundation Owners Thread - Page 19 - AVS Forum | Home Theater Discussions And Reviews
 661Likes
Old 01-07-2014, 11:52 AM
ProAudioSlave's Avatar
Quoted: 35 Post(s)
iBias sounds interesting. If that Chorus 7200 offers similar power consumption to the power amp I already have, I'll definitely be trying one out.
ProAudioSlave is offline
Old 01-07-2014, 01:35 PM
rhale64L7's Avatar
Quoted: 826 Post(s)
Liked: 326
^ I would like to know the outcome of that.
JVC RS4810 projector Stewart Cima 115" 2.35 screen, ATI 523 and 528 amps
7 mirror imaged 2 way DIY monitors. All matched to within 1db. All parts matched, 1 SVS SB16 ultra subwoofer
Emotiva XMC-1 processor Marantz UD5007 Bluray player
Furman sequencer ran off of a double 50amp breaker,Furman power conditioner
All in a dedicated 15x22x8 foot dedicated home theater.
rhale64L7 is online now
Old 01-07-2014, 01:40 PM
rhale64L7's Avatar
Quoted: 826 Post(s)
Liked: 326
Originally Posted by ProAudioSlave View Post
Yes, I made sure I was using the correct IP address.
Running the network update it displays "check failed" just after webpages.inf
I reserved an IP Address for the Foundation on my router and have tried both DHCP and Static. I've checked the IP address both on the Foundation and on the attached devices on the router admin webpage. I can ping the IP address from my PC, but I just keep getting a page cannot be found error, or something to that extent.
Ok I had a problem when I did it in a Google search. It said exactly what you are saying. I had to do it on my android phone in the address bar of internet explorer Http:// and the rest dont remember off the top of my head. Wouldn't work on my windows 8 pc either.
Old 01-07-2014, 01:45 PM
scpanel's Avatar
Quoted: 66 Post(s)
OK tried 2 other Hi res mics and none picked up any speakers so back to sub calibration based on sound/ear. I may run REW later this week.
scpanel is offline
Old 01-07-2014, 01:47 PM
Quoted: 35 Post(s)
Good point, I forgot to try the Android tablet again. I'll give it a go later.
Old 01-07-2014, 02:30 PM
rhale64L7's Avatar
Quoted: 826 Post(s)
Liked: 326
Interestingly enough my phone saved a widget that looks exactly like the Foundation and named it home. This after I saved the page in my bookmarks.
Old 01-07-2014, 03:06 PM
Quoted: 35 Post(s)
Tried again from a tablet and a phone, both Android, but still a no go.
It wouldn't be the end of my interest in the Foundation if it was only the browser control that didn't work, for whatever reason. I only intended to control it that way until I get around to programing an App, making use of the feedback. That is my goal for my whole system, a single App with feedback on the screen of the tablet.
Old 01-07-2014, 04:32 PM
rhale64L7's Avatar
Quoted: 826 Post(s)
Liked: 326
Ok gotcha. I sure wish it would work though.
Old 01-07-2014, 09:26 PM
scpanel's Avatar
Quoted: 66 Post(s)
Not sure if this will help you:
I had the same issue at first and noticed that my IP on the Foundation had an extra 0's in that third spot as I recall, and I set my browser to 192.168.1.91 and it works fine. It works on my PC, Nexus 7 and IPAD. I finally got it to work after trying various things as well. Have you tried a single number in that 3rd spot?
scpanel is offline
Old 01-08-2014, 07:53 AM
vvuuren's Avatar
Quoted: 209 Post(s)
Liked: 92
Mine works perfectly on my iPad with two o's in the third spot (exactly as it says on the Foundation).
vvuuren is offline
Old 01-08-2014, 11:53 AM
scpanel's Avatar
Quoted: 66 Post(s)
thats interesting, I had the same issues ProAudio had until I tried dropping them. Not sure why.
scpanel is offline
Old 01-08-2014, 11:58 AM
Quoted: 35 Post(s)
I've tried it exactly as displayed on the Foundation (192.168.000.015) and the way that it appears as an attached device on the router (192.168.0.15) as well as 192.168.000.15 and 192.168.0.015, just to cover all the possibilities.
Without the extra 0's is the correct address as I can ping it fine. I'll try again over the weekend, just in case I'm doing something wrong. If I work it out or Krell contacts me with a solution I'll post back here with an update.
Old 01-08-2014, 12:43 PM
rhale64L7's Avatar
Quoted: 826 Post(s)
Liked: 326
Interesting enough my browser automagically drops the zeros after I type it in and hit go or search.
Old 01-08-2014, 01:15 PM
scpanel's Avatar
Quoted: 66 Post(s)
Really 3 0's in that 3rd? have you tried a 1 for fun?
scpanel is offline
Old 01-08-2014, 02:25 PM
rhale64L7's Avatar
Quoted: 826 Post(s)
Liked: 326
Yes that could be a problem. Can you set a static ip address for a single component on a network? If you can I would definitely try that. Or maybe unhook the Foundation from your network then plug it back in and let it set another ip address. Then type that in to your browser.
Old 01-08-2014, 03:18 PM
Quoted: 35 Post(s)
No. I've configured my router to only allocate addresses in the range of 192.168.0.2 to 192.168.0.54, so anything not within that range will not have access to or be available on my network.
Old 01-08-2014, 03:20 PM
scpanel's Avatar
Quoted: 66 Post(s)
I didnt set up a static address either, and its worked perfectly.
scpanel is offline
Old 01-08-2014, 03:26 PM
Oppo Beta Group
RichB's Avatar
Quoted: 870 Post(s)
Liked: 571
Those are the addresses allocated by your router but other addresses within your subnet can be statically assigned.
For example, 192.168.0.55 is available and can be accessed if you statically assigned it to a device.
You can download Advanced IP Scanner to see where your devices are allocated.
- Rich
Oppo UPD-203 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 |ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG B6 | Lumagen 2020
RichB is online now
Old 01-08-2014, 03:50 PM
Quoted: 35 Post(s)
I've allocated an address and that is the one used if I enable DHCP or use a static address. It still doesn't work. This is taking the thread off track, so I'll report back when it is solved.
Old 01-08-2014, 04:54 PM
scpanel's Avatar
Quoted: 66 Post(s)
Thats strange, maybe you could try 192.168.1.2 to 192.168.1.54 and see if it makes a difference. I configure networks all day and never use 0 in that 3rd place. I always (especially for home users) use 1. Its pretty much a standard here.
scpanel is offline
Old 01-08-2014, 05:15 PM
rhale64L7's Avatar
Quoted: 826 Post(s)
Liked: 326
Here is the 300 watt Krell amp at ces. It is obviously a working unit. Cant wait to get some feedback.
Old 01-08-2014, 05:42 PM
scpanel's Avatar
Quoted: 66 Post(s)
Great looking amp... Want a new 7 channel to match but 10K not sure!
scpanel is offline
Old 01-08-2014, 06:39 PM
rhale64L7's Avatar
Quoted: 826 Post(s)
Liked: 326
Yeah chorus 7200 at 9500.00 dollars is still steep. But normally amps do last a long time. Figure maybe 15-20 years. So when you figure it that way maybe not to bad.
Old 01-08-2014, 07:31 PM
scpanel's Avatar
Quoted: 66 Post(s)
Sounds pretty darn good with my MPS 1 so no rush! They even look good together too
scpanel is offline
Old 01-08-2014, 07:50 PM
rhale64L7's Avatar
Quoted: 826 Post(s)
Liked: 326
What is an MPS1?
Old 01-08-2014, 08:26 PM
scpanel's Avatar
Quoted: 66 Post(s)
What is an MPS1?
Emotiva MPS 1 is a 200w per channel - 7 channel amp and each amp is a card in a slot.... Class H
scpanel is offline
Old 01-09-2014, 03:17 AM
rhale64L7's Avatar
Quoted: 826 Post(s)
Liked: 326
Ok thanks.
Old 01-09-2014, 08:01 AM
vvuuren's Avatar
Quoted: 209 Post(s)
Liked: 92
I don't think it's expensive for a 7 channel Krell if it sounds as good as their previous amps. My amps are working fine so I'm not replacing either but for a new buyer that wants Krell its a good option. Haven't heared the Emotivas so don't know if its worth the extra money. (I do own Krell amps). I would love to hear what people say about their sound!
vvuuren is offline
Old 01-09-2014, 09:36 AM
rhale64L7's Avatar
Quoted: 826 Post(s)
Liked: 326
Yeah thats what I am saying pretty much.
Old 01-09-2014, 11:25 AM
vvuuren's Avatar
Quoted: 209 Post(s)
Liked: 92
Just listening to some multichannel SACD's. Freaking amazing!!! Can't stop smiling. Always been a 2 channel guy with more expensive equipment in my 2 channel: dCS Puccini with U-clock, Krell Evolution 202 pre, Krell EV600e fronts driving B&W 802d's which have always sounded very good but my SACD's are now sounding as good as they can. I can't believe the change the Foundation is making. I'm a very happy audiophile right now! I've been bashed on a different forum about Krell vs Emotiva and called stupid buying more expensive equipment but now that doesn't matter at all. So far I've been lucky with my wireless updates and connecting through my iPad. Only problem is I can still not play video through Foundation to my Runco because of pink picture but that is the Runcos fault because it works fine on a different TV. Can I say again how good it sounds?
vvuuren is offline
Denon Avp A1hdci Ultra Reference A V Network Streaming Preamplifier
