Krell Foundation Owners Thread - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 661Likes
post #2521 of 4909 Old 11-22-2014, 05:33 PM
thedonovanz's Avatar
Quoted: 46 Post(s)
Originally Posted by rhale64L7 View Post
Just remember it is like anything else you have hooked up in this hobby. Outputs to inputs
This is not a hobby. It is an addiction. Adding the Foundation to my system was like adding Peyton Manning to the local high school team. Sure they play better, but now I am forced to add a new center and a couple of top notch wide receivers. It is an exhausting and addicting search trying to find speakers that are worthy enough to play with the Krell.
thedonovanz is offline
post #2522 of 4909 Old 11-22-2014, 06:12 PM
rhale64L7's Avatar
Quoted: 846 Post(s)
Liked: 335
Lol
JVC RS4810 projector Stewart Cima 115" 2.35 screen, ATI 523 and 528 amps
7 mirror imaged 2 way DIY monitors. All matched to within 1db. All parts matched, 1 SVS SB16 ultra subwoofer
Emotiva XMC-1 processor Marantz UD5007 Bluray player
Furman sequencer ran off of a double 50amp breaker,Furman power conditioner
All in a dedicated 15x22x8 foot dedicated home theater.
rhale64L7 is online now
post #2523 of 4909 Old 11-22-2014, 08:22 PM
artur9's Avatar
Quoted: 603 Post(s)
Liked: 215
Originally Posted by vvuuren View Post
I'm not sure that it would make that much of a difference with a sub unless the distances are very different?
I like to / need to crossover my speakers high enough that they are localizable. Just enough to be annoying.
artur9 is offline
post #2524 of 4909 Old 11-23-2014, 07:49 AM
lsdec's Avatar
Quoted: 178 Post(s)
Liked: 116
The Foundation is really a great sounding processor. It does its job very very good. It does have room eq. Although not the greatest solution but in my room it works perfectly. My room is very well treated.
If you have the funds i know you wouldn't be disappointed in its sound quality. The little mini review of the Foundation vs the xmc1 really can't be taken very seriously. Because I have now heard the Classe on Bowers and Wilkins 801s and in that room it wasn't even close to the sound i get with my equipment.
The xmc1 really might be great for the money but if it is as great as that review nobody would want anything else unless they wanted the new surround formats.
Now if emotiva comes out with their reference processor this might change. But for now if great sound is what your after the Foundation has it. I can assure you no disappointment in sound quality.
Just curious, why can't that mini review be taken seriously?
lsdec is offline
post #2525 of 4909 Old 11-23-2014, 11:07 AM
rhale64L7's Avatar
Quoted: 846 Post(s)
Liked: 335
You can if you want to. But the reason i cant is because someone else has posyed that his avm30 sounds way better than the xmc1 and i have heard that. It in my opinion it isn't close to the Foundation in sound quality. And i am getting the sense that the xmc1 sounds about the same as the umc. And he didn't compare analog quality. He might not have even had either of the two calibrated properly.
There is just to many unknowns with that review. And i am not the only one that has suggested this. Even some in the actual xmc1 thread.
I am not saying at all that in his opinion with how they were setup with his equipment in his room that the xmc1 sounded better to him. I am sure he was genuine in his statement.
post #2526 of 4909 Old 11-23-2014, 12:51 PM
LOL... no doubt you speak from experience! I guess there are worse things to obsess about and spend money on.
I always wondered how the Krell would sound with my speakers (Kef Reference 4's), as I was quite pleased with their performance with my old Yamaha DSP-A1. I am hoping the Krell will provide an entirely new level of enjoyment.
Perhaps I should ask some of the Krell honchos what their favorite speakers are based on their experiences?
FLRon is offline
post #2527 of 4909 Old 11-24-2014, 07:23 AM
vvuuren's Avatar
Quoted: 209 Post(s)
Liked: 92
I use B&W 802D with Krell Evolution 600 monos and B&W 805s for sides. The 802's rocks with the 600's!!! Also B&W DB1 sub.
FLRon likes this.
vvuuren is offline
post #2528 of 4909 Old 11-24-2014, 07:42 AM
rhale64L7's Avatar
Quoted: 846 Post(s)
Liked: 335
I use diy 2 way with too much money in the crossovers
post #2529 of 4909 Old 11-25-2014, 06:27 PM
Hi all! I'm having some difficulties setting up the connections from the Oppo 105 to the Foundation.
I have two balanced XLR's from the 'stereo out' of the oppo to the Foundation 'analog in' XLR on the Foundation. Sounds great! Problem arises when I try to play a 5.1 DVD. I get no rear or center sound. I thought the Oppo 'HDMI 1 Output' connected to one of the Foundation HDMI Input slots would be the answer, but I get nothing. Any help would be greatly appreciated. Thanks!
FLRon is offline
post #2530 of 4909 Old 11-26-2014, 02:07 AM
rhale64L7's Avatar
Quoted: 846 Post(s)
Liked: 335
I think by default the bd1 input is hdmi in 1. Is your hdmi going out of the oppo and into this HDMI1 input? Then you have to select bd1 input on the Foundation.
Have you went through the menu and set anything up? You have to read the owners reference which I will admit is pretty bad.
post #2531 of 4909 Old 11-26-2014, 02:08 AM
rhale64L7's Avatar
Quoted: 846 Post(s)
Liked: 335
See on the Foundation you have to setup each source in the menu. It is very configurable but it can be a daunting task.
post #2532 of 4909 Old 11-26-2014, 02:14 AM
rhale64L7's Avatar
Quoted: 846 Post(s)
Liked: 335
Have you ran speaker setup? This is the first thing in the menu.
post #2533 of 4909 Old 11-26-2014, 06:38 AM
Yes, I ran the speaker setup and everything is OK. I will try to revisit it later with a clear mind.
FLRon is offline
post #2534 of 4909 Old 11-26-2014, 08:27 AM
rhale64L7's Avatar
Quoted: 846 Post(s)
Liked: 335
Check my first post after your question then. That should solve your problem.
post #2535 of 4909 Old 11-26-2014, 06:23 PM
scpanel's Avatar
Quoted: 66 Post(s)
Liked: 25
I am getting ready to remodel a bathroom and having an electrician wire a new 20a ckt, for guess what??? HaHa, eventually a Chorus maybe next year! Maybe I can find a nice one thats a year old or so
scpanel is offline
post #2536 of 4909 Old 11-26-2014, 06:27 PM
rhale64L7's Avatar
Quoted: 846 Post(s)
Liked: 335
Good deal. I am sure you will be able to find a used one for about 3000-4000 less.
post #2537 of 4909 Old 11-27-2014, 10:24 AM
vvuuren's Avatar
Quoted: 209 Post(s)
Liked: 92
Originally Posted by jsetliff View Post
Krell contacted me today to send in my unit for the 4k upgrade! Will mail it tomorrow
Did you get your Foundation back yet?
vvuuren is offline
post #2538 of 4909 Old 11-27-2014, 03:16 PM
rhale64L7's Avatar
Quoted: 846 Post(s)
Liked: 335
I had the same question. Haha. I think it is next week he gets it back.
post #2539 of 4909 Old 11-28-2014, 08:14 PM
rhale64L7's Avatar
Quoted: 846 Post(s)
Liked: 335
Folks the ibias amps are starting to get some rave reviews from professional reviews and owners. Some on audiogon are saying that they sound more like class a than the evo series. And are a little more tube sounding. I like the German review. That person said about exactly what I said about the Chorus. He also said pretty much that the first reviewer that sent it to him should have waited because it sounded much better as time went on.
post #2540 of 4909 Old 11-28-2014, 08:46 PM
scpanel's Avatar
Quoted: 66 Post(s)
Liked: 25
great, one day I will get one here
scpanel is offline
post #2541 of 4909 Old 11-29-2014, 09:00 AM
As an update, I finally figured out the set-up process and the Foundation now recognizes the HDMI signal from my Oppo. I'm hearing my music in a way that I never experienced before. I've been letting it play to get more break-in hours and I am very pleased with the Krell system.
Thanks again for the help!
Ron
FLRon is offline
post #2542 of 4909 Old 11-29-2014, 09:06 AM
rhale64L7's Avatar
Quoted: 846 Post(s)
Liked: 335
No problem Ron. I am glad you like it. It is an awesome sounding piece of equipment. This is one of the many reasons why I have a problem with that comparison between the Foundation and the xmc1. There is no way another 7.whatever channel processor is going to trounce the Foundation.
There is some that probably sound better. But trounce I can't believe.
post #2543 of 4909 Old 11-29-2014, 11:49 AM
artur9's Avatar
Quoted: 603 Post(s)
Liked: 215
Do you have a link for that? Google translate works ok for German, less so for audiophile terms but still makes things readable.
artur9 is offline
post #2544 of 4909 Old 11-29-2014, 02:33 PM
rhale64L7's Avatar
Quoted: 846 Post(s)
Liked: 335
No not in English I pretty much had to decipher some myself. But what got translated well enough was pretty darn good. I cant wait for Krell to post the review translated properly on their site.
Also what people are saying over on Audiogon that have heard the Evo E series are saying that these new amps sound better than even the E series. That is high praise.
post #2545 of 4909 Old 11-30-2014, 11:59 AM
jsetliff's Avatar
Quoted: 101 Post(s)
Liked: 48
No, I have not yet received it back. I am hoping it comes this week.
jsetliff is offline
post #2546 of 4909 Old 11-30-2014, 04:05 PM
scpanel's Avatar
Quoted: 66 Post(s)
Liked: 25
cant wait to hear the results, I have not heard as yet on my upgrade.
scpanel is offline
post #2547 of 4909 Old 11-30-2014, 05:14 PM
vvuuren's Avatar
Quoted: 209 Post(s)
Liked: 92
I haven't either!
vvuuren is offline
post #2548 of 4909 Old 11-30-2014, 05:49 PM
rhale64L7's Avatar
Quoted: 846 Post(s)
Liked: 335
Me neither. How many of these are there? I wouldn't think a lot. But must be. I thought you got in early vvuuren.
When did you folks get in on the upgrade? I know I was a bit after you both. I got in when I ordered my Foundation and Chorus. I saved a bunch by doing so. It was a no brainer.
post #2549 of 4909 Old 11-30-2014, 06:49 PM
vvuuren's Avatar
Quoted: 209 Post(s)
Liked: 92
I thought I got in early. You can imagine how anxious I am because I still need to send my amp back for repair the same time!
vvuuren is offline
post #2550 of 4909 Old 12-01-2014, 02:19 AM
rhale64L7's Avatar
Quoted: 846 Post(s)
Liked: 335
I am sure you are anxious.
Denon Avp A1hdci Ultra Reference A V Network Streaming Preamplifier
