Change 2.0 to 2.1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-17-2013, 05:00 PM - Thread Starter
FuzzyReets's Avatar
Quoted: 209 Post(s)
Liked: 24
Hi folks. I just re ran my audyssey setup and now I cna't figure out which setting i need to put on to have my 2.0 sources add the sub to the mix and run 2.1. Help appreciated. Thank you.
Denon x2300w
XBox One S
Sony BDP-S6500
Apple TV4
LG OLED65B6p
FuzzyReets is offline
post #2 of 6 Old 08-17-2013, 05:04 PM
JHAz's Avatar
Quoted: 306 Post(s)
Liked: 273
Typically, turn on the sub in the receiver and set speakers to small or set a crossover for them. The content itself does not have a .1 channel . . .
JHAz is offline
post #3 of 6 Old 08-17-2013, 05:46 PM
jdsmoothie's Avatar
Quoted: 12633 Post(s)
Liked: 5782
After running Audyssey, the sub should have been set to YES. As suggested, ensure your speakers are now set to SMALL/80Hz (or reset them to SMALL/80Hz) and then the audio below 80Hz will be redirected to the sub.
jdsmoothie is offline
post #4 of 6 Old 08-24-2013, 06:25 PM - Thread Starter
FuzzyReets's Avatar
Quoted: 209 Post(s)
Liked: 24
Oh I see. I'm setting my fronts to full range now so I guess the sub won't be on correct?
Denon x2300w
XBox One S
Sony BDP-S6500
Apple TV4
LG OLED65B6p
post #5 of 6 Old 08-24-2013, 07:12 PM
Trendy's Avatar
"full range"??
No. Set the speakers to "small". This will force the receiver to send everything below the crossover frequency to the sub.
Trendy is offline
post #6 of 6 Old 08-24-2013, 08:30 PM
afrogt's Avatar
Quoted: 1097 Post(s)
Liked: 783
What receiver do you have? Onkyo, Denon, Marantz? All 3 use Audyssey. Sounds like you have an Onkyo.
Your speakers should no longer be set to "full range" once you add a subwoofer.
Afro GT
afrogt is offline
