How To Remove Bare Speaker Wire Strips From Within AV Receiver Speaker Terminals - AVS Forum | Home Theater Discussions And Reviews
Old 08-20-2013, 05:09 AM - Thread Starter
noiselisten's Avatar
Hello
The speaker wire was poorly terminated. Loose speaker wire strips are within the speaker terminal.
What is the best way to remove all those bare speaker wire strips from within the av receiver's speaker terminal?
The av receiver is the RX-V673.
Please see a photos of the av receiver at the following official link: http://usa.yamaha.com/products/audio-visual/av-receivers-amps/rx/rx-v673_black_u/?mode=model
The speaker terminals are the Yamaha type that have a knob that can be tightened and loosened. However, the know doesn´t seems to come off completely. The speaker terminals can receive banana plugs.
noiselisten is offline
Old 08-20-2013, 06:50 AM
mastermaybe's Avatar
Quoted: 362 Post(s)
Liked: 306
Just FYI: these are simply typical 5 way binding posts...nothing really proprietary about them.
Although you cannot back the screw-down portion of the post all the way off, can you at least get enough space where you can utilize a small needle nose pliers or even a small flat head screwdriver to remove what remains? Of course ensure the unit is unplugged, whatever route you choose.
You could also try a strong magnet.
Bit of an odd problem I must say. I've never had speaker connect THAT onerous to remove.
James
noiselisten likes this.
Actual phone call (see pic to left):
Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
Old 08-20-2013, 11:23 AM
braveheart123's Avatar
Quoted: 311 Post(s)
Liked: 273
Vacuum cleaner
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
Old 08-20-2013, 01:09 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Compressed Air should do the trick.
If you mean the cheap spring clip terminals then you'll pull the wire out with needlenose pliers. Please unplug the unit first!!!!!!!
Afro GT
afrogt is online now
