Please help me...receiver dilemma - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 08-20-2013, 05:26 PM - Thread Starter
1irishman's Avatar
Hi everyone,,I could use your help...I have done some research but am so new to this surround sound stuff that I don't really understand it all.
Here is the scenario: Standard sized family room with a 56 inch tv...2 zones. Interior zone has three DEFINITIVE Mythos 2 speakers (left, center, right) surrounding the tv and two DEFINITIVE Mythos Gels for the rear pair . The sub is a DEFINITIVE Cube1, I think,,but not sure,,,might be a supercube 11. Outside (Zone 2) are 2 fairly large wall mounted SONANCE speakers.
I can't get anything new.
I am trying to decide between the PIONEER ELITE VSX-33 7.1 or the Yamaha RX-V773 7.2. Each are refurbished units. Looks like the Pioneer hit the market in 2010 and the Yamaha hit it in 2012.
The Yamaha refurb price is $449 out the door with a 1 year warranty.
The Pioneer refurb price is $480 out the door.
I am looking to get durability,,I won't be using all the bells and whistles. Any help is appreciated and thanks in advance
1irishman is offline
post #2 of 11 Old 08-20-2013, 07:08 PM
Trendy's Avatar
I would compare each unit against it's equivalent new price. Then decide if the saving is a fair trade off for less warranty and potentially fewer features. Personally I buy my amplifiers new and run them until they fail or become obsolete. Obsolesce is potentially a greater concern with an AVR. I'm on my 4th AVR now but still using the same stereo amplifier I purchased back in the mid 1980s.
Trendy is offline
post #3 of 11 Old 08-20-2013, 08:30 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
The Yamaha uses YPAO calibration which has a universal crossover for all speakers which is a drawback. You have Mythos Gem surrounds which have 3.5" drivers. You'd probably want to cross them over at 100hz while your fronts should probably be crossed over at 80hz.. With the Yamaha you can only have one crossover setting.
The Pioneer uses MCACC calibration and you can set the crossover for the front, center and surrounds independently.
I'd get the Pioneer for that reason despite the shorter warranty.
Afro GT
afrogt is offline
post #4 of 11 Old 08-20-2013, 08:54 PM
Trendy's Avatar
Interesting point raised by afrogt about the crossover points. A quick check on the manufacturer's literature indicates that they recommend a 120 Hz crossover for the Mythos Gem. Perhaps the Pioneer would be a better choice.
Trendy is offline
post #5 of 11 Old 08-21-2013, 04:21 AM - Thread Starter
1irishman's Avatar
Thanks. I discovered the Pioneer warranty is 90 days for what it's worth. I too am leaning toward the Elite.
post #6 of 11 Old 08-21-2013, 04:41 AM
derrickdj1's Avatar
Quoted: 877 Post(s)
Liked: 590
Pioneer uses a global xo for the speakers. This is not a disadvantage. All major avr companies recommend bass management. Audyssey also recommend bass management with all speaker set to small. There is no objective data to support setting different xo's for the speakers in a HT is better than a global xo.
I may be wrong but, most pioneer elite avr's have a 2 year warranty. Mine has a 2 year warranty if it is purchased thru an authorized dealer.
derrickdj1 is offline
post #7 of 11 Old 08-21-2013, 05:01 AM
Bond 007's Avatar
Quoted: 2371 Post(s)
Liked: 1907
Either one will do a fine job especially if youre not concerned about the bells and whistles. The Yamaha is more reliable than Pioneer imo.
Licence to Kill
Bond 007 is offline
post #8 of 11 Old 08-22-2013, 06:31 PM - Thread Starter
1irishman's Avatar
I decided to get the YAMAHA and ordered it. Even though the opinions here pointed to the Pioneer, I decided the 1 year warranty and the 2012 versus 2010 production year was the safer alternative. I also like the styling of the Yamaha better. Thanks for all the help!!!!! I see it comes with a wireless adapter:
-IEEE 802.11b/g/n compatible
-Auto setup by WPS (Wi-Fi Protected Setup)
-Manual setup by PC
-2 LAN ports to support up to 2 network products
-Powered by the DC out USB connection on the back of the RX-V773WA
If anyone is not too tired to entertain my electronic stupidity, can you explain how or why I would need or use two wireless adapters in my house. How would the one that comes with the Yamaha be used...can I do without it??? Do I need it to run PANDORA
Thanks again in advance
post #9 of 11 Old 08-22-2013, 06:36 PM
Bond 007's Avatar
Liked: 1907
Read the manual when you get it. If you still have questions you can post them in the 773 thread.
Licence to Kill
Bond 007 is offline
post #10 of 11 Old 08-22-2013, 06:38 PM
Bond 007's Avatar
Liked: 1907
Bond 007 is offline
post #11 of 11 Old 08-22-2013, 07:21 PM - Thread Starter
1irishman's Avatar
Thanks Bond..you directed me to where I need to be now.
