NEW Yamaha Separates... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-20-2013, 10:13 PM - Thread Starter
M Code's Avatar
Quoted: 717 Post(s)
Liked: 419
Yamaha Goes Upscale With Two-Channel Introductions
Aug 20 2013
Yamaha’s A-S3000 stereo integrated amp retails for a suggested $7,999.
Buena Park, Calif. – Yamaha is going way upscale in its selection of two-channel stereo integrated amps and two-channel CD/SACD players.
September retail shipments are planned for Yamaha’s A-S3000 integrated amp and CD-S3000 CD/SACD at suggested retails of $7,999 and $6,999, respectively. The integrated amp is an addition to a lineup that consists of five other stereo integrated amps at suggested retails from $379 to $2,499. The CD/SACD player is an addition to a two-channel CD/SACD player lineup consisting of two models at $1,799 and $2,499. Yamaha hasn’t offered a stereo integrated amp at this price point in more than a decade, a spokesman said.
Both products feature a retro look, with the integrated amp adding dual analog level meters. Both are also said to emulate the cosmetics of musical instruments, thanks in part to piano-black side panels. The player features built-in 32-bit ESS Sabre32 Reference DAC to provide what the company called “unprecedented dynamic and expressive sound” from disc-based media. The player also features optical and coaxial digital inputs and USB DAC input to accept 192kHz/24-bit USB audio from a computer. The integrated amp features phono stage for moving-magnet and moving-coil phono cartridges. Output is rated at 2x100 watts into 8 ohms with 0.07 percent THD from 20Hz-20kHz. Into 4 ohms, output goes to 2x150 watts with 0.07 percent THD from 20Hz-20kHz. Both models incorporate anti-vibration and distortion-eliminating measures, including rigid construction and the shortest possible cabling routes, the company said. Both components feature 0.28-inch-thick aluminum front panels, and the integrated amp adds 0.24-inch aluminum top panel. The A-S3000 integrated amp is said to produce a “warm, tube-like sound” thanks to a floating and balanced design and MOSFETs and a large toroidal transformer mounted within an independent three-dimensional inner frame.
Just my $0.02... 👍😉
mikejedi123 likes this.
M Code is offline
post #2 of 2 Old 08-21-2013, 04:52 AM
derrickdj1's Avatar
Quoted: 877 Post(s)
Liked: 590
It sound like they are trying to relive the glory days of the 80 when Yamah amp were consider some of the best on the market like the M 80, M 85 amplifiers with the meter lights. It will be interesting to see if they can compete in the ultra high end market.
derrickdj1 is offline
