Yamaha RX-V3900 & Cerwin Vega E-715 - no bass! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-25-2013, 02:40 AM - Thread Starter
Sean Dayhew's Avatar
Hi guys,
I recently purchased a used RX-V3900 to replace my RX-V3200, I was very happy with my RX-V3200 and just wanted HDMI, internet radio and a few extra more modern conveniences with out a sacrifice of power.
I have connected Cerwin Vega E-715 speakers which when paired to the RX-V3200 would just about blow the windows out in my house. When connecting the RX-V3900 the sound pressure is gone, simply put my Cerwin vegas sound like little satellite speakers on this thing - they can go somewhat loud but there is next to no bass, I originally configured it with the yamaha mic, then reset as it looked to put a high pass filter on, I then manually configured them to large speakers, tried boosting the bass, then did several complete factory resets.
With the same music source i have run the amps side by side, both on processor direct, the difference is like chalk and cheese.
Is there something I am missing or have I acquired a dud?
Surely the more modern more powerful RX-V3900 should not be blown out of the water by its older lower spec'd RX-V3200..
Any input would be appreciated.
Sean Dayhew is offline
post #2 of 6 Old 08-25-2013, 02:52 AM
Bond 007's Avatar
Quoted: 2594 Post(s)
Liked: 2056
You are telling the receiver that there is no sub?
Licence to Kill
Bond 007 is online now
post #3 of 6 Old 08-25-2013, 02:58 AM
Bond 007's Avatar
Liked: 2056
Processor direct bypasses all of the settings. You may have a bad receiver. Do you have another set of speakers to try?
Licence to Kill
post #4 of 6 Old 08-25-2013, 10:37 AM
Chriscorv58's Avatar
Quoted: 122 Post(s)
Liked: 82
I posted a similar thread about an old h/k receiver and cerwin vega at-10 speakers. sounded rich and full before we switched to a denon 3312, now the speakers sound shallow and lifeless. seems like the newer amps just dont have the amperage backing them like the old receivers, the hk was only rated at 60 watts and boy it sounded way better than this 125watt
Sony 940c 75" Display, Marantz AV8801, HTPC, JTR 215RM Mains & JTR 210RM Center, DIY Surrounds, Crown Xti & Cdi Amps, Seaton Submersive HP+ Master and Slave.
Chriscorv58 is offline
post #5 of 6 Old 09-06-2013, 03:15 AM - Thread Starter
thanks for the suggestions, turns out in the speaker setup in subwoofer it had a bass out selection as subwoofer, subwoofer & fronts, fronts only. Even with a factory reset subwoofer only was selected... Set to fronts and sounding much better.
In my opinion my older "less powerful" RX-V3200 has the upper hand in sound quality and oomph...
post #6 of 6 Old 09-06-2013, 03:38 AM
braveheart123's Avatar
Quoted: 330 Post(s)
Liked: 287
My favourite AVR, still miss it. Try Pure Direct mode, it should wake up your vegas.
History is written by those who have hanged heroes ...
Main System: PSB X2T, PSB XC, PSB XB, Cambridge Audio Azur 751R, Rythmik FV15HP, PSB S500
braveheart123 is offline
Yamaha Rx V3900bl Receiver , Cerwin Vega E 715 15 Inch 3 Way Floorstanding Speaker Black Ash Single
