NAD T748 "listening Mode Setup" help needed! - AVS Forum
post #1 of 4 Old 08-27-2013, 05:38 PM - Thread Starter
stuntflyer's Avatar
I'm trying to set the NAD's "Listening Mode" to "DIRECT".
From the manual. . .
DIRECT
The analog or digital sources are automatically played in their native formats. All the source’s audio channels are reproduced directly. This mode recreates the original sound most faithfully thereby producing outstandingly high quality audio. Note that the source must be at playback mode for “Direct” to become available as a listening mode option In order to automatically playback your source in their native format, implement the following settings.
1. Go to “Listening Mode Setup” under “Setup Menu”. At the “Listening Modes” menu, set all Dolby Digital, DTS, PCM and Analog settings to “None”. With this setup, your source will be played back directly at its native format.
When I go to “Listening Mode Setup” under the “Setup Menu” I can not change the listening modes to "None". I can only change the "Surround" option to "None".
Also I don't know how to do this or for that matter even what it means. . ."Note that the source must be at playback mode for Direct to become available as a listening mode option"
stuntflyer is offline
post #2 of 4 Old 04-03-2014, 06:01 AM
Adarsh BG Singh's Avatar
Hi,
I am experiencing the same problem.
Did you manage to get it working?
Adarsh BG Singh is offline
post #3 of 4 Old 04-03-2014, 07:36 AM
commsysman's Avatar
Quoted: 113 Post(s)
Liked: 250
Listening Mode should be set to "stereo" for 2-channel listening, or "direct" for 5.1 .
Set surround to "none".
commsysman is offline
post #4 of 4 Old 04-06-2014, 02:03 PM
Hi commsysman,
I have set surround to none as you see in the picture however direct mode still doesn't come up as an option.
Please Help.
User Tag List
