Denon X4000 or 4311? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-27-2013, 07:05 PM - Thread Starter
Cowboys's Avatar
Liked: 107
Guys,
What is the pros and cons of the X4000 v.s 4311? Which one would you buy? Thanks.
Cowboys is offline
post #2 of 5 Old 08-27-2013, 07:18 PM
jdsmoothie's Avatar
Quoted: 12140 Post(s)
Liked: 5529
The 4311CI is the next level up model with a more powerful power supply capable of driving 4-ohm speakers without additional amplification and predecessor to the current flagship 4520CI, and therefore better construction than the X4000 as well as capability to expand to 11.2; however, they both feature the same Audyssey MultEQ XT32 and Sub EQ HT and the X4000 has some newer features not present on the 4311CI (eg. Zone 2 HDMI, Instaprevue, DTS Neo:X, etc.). So it depends on which better meets your specific requirements.
jdsmoothie is offline
post #3 of 5 Old 08-27-2013, 07:49 PM - Thread Starter
Cowboys's Avatar
Liked: 107
Thanks JD. Always can rely on you. Do you have the x4000? If so, how do you like it?
Cowboys is offline
post #4 of 5 Old 08-28-2013, 04:52 AM
jdsmoothie's Avatar
Liked: 5529
Yes, the X4000 has some really nice features the best using the most advanced version of Audyssey MultEQ XT32. Call me for a quote. smile.gif
post #5 of 5 Old 08-28-2013, 06:49 AM
KidHorn's Avatar
Quoted: 1375 Post(s)
Liked: 883
I own a 4311 and wouldn't trade it for a new x4000. Like JD said, it's more comparable to a 4520 than a 4000. I use 11 channels and will never downgrade to less. neoX would be nice to try out, but I don't see it being much different than audyssey dsx. Just adds a few ambiance channels.
KidHorn is offline
Denon Avr 4311ci 9 2 Channel Network Multi Room Home Theater Receiver With Hdmi 1 4a , Denon Avr X4000 7 2 Channel Home Theater Receiver
