The "Official" Yamaha AVENTAGE RX-A730 & RX-A830 Thread - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #301 of 328 Old 11-11-2015, 02:20 PM
KJSteward's Avatar
Quoted: 205 Post(s)
Liked: 608
Originally Posted by tradewinds View Post
Does anyone know how to change the wallpaper/background on the A830?
I use this workaround.
My main music source is my PC, running Foobar2000. I use the SERVER function of the Yamaha to play the stream from Foobar.
Then I switch the video input (On Screen/Input/Server/Video Out) to HDMI2 (which is connected to my AppleTV). I use the screensaver from the AppleTV to replace the Yamaha offerings.
Spoiler!
KJSteward is offline
post #302 of 328 Old 11-17-2015, 08:03 AM
Liked: 0
I use 2CH stereo to listen to mp3's made from CDs using the Android App. I've ripped the mp3's at cd quality levels using ffmpeg in ubuntu. When streaming from the Android App you get the Yamaha RX-A830 to do the Digital to Analog Conversion and the sound is awesome. According to the front display in 2Ch stereo mode the subwoofer is on too. Plus you can hear it. My only compaint about Android is that it keeps duplicating my music and I don't normally listen to each song on the album twice. I'm on Android 4.2.1 and my tablet and phone aren't going to be updated to the versions required to stop this issue. So every time I go to play I have to open settings, media, delete all data, reboot, and then get a single song per album. Apparently Google didn't realize that not everybody wants to store their music in the cloud and download it every time they play it.
Instead of party mode, once you are streaming to Zone A, you may select the same digital source for Zone B, and get stereo in both rooms. I don't like party mode as I don't want my center speaker and rear speakers form playing back stereo sources. If I'm not using Zone B I do occasionally use the "Cellar Club" to listen to my jazz. But most of the time the original Stereo is what I want to hear.
Yamaha RX-A830, Qysonic Array Tower Mains, Boston Acoustic Center, Custom 12" 300W Sub, Infinity Rear.
ksanger is offline
post #303 of 328 Old 11-19-2015, 06:25 AM
chros73's Avatar
Quoted: 50 Post(s)
Liked: 24
You can try PowerAmp, it supports the normal playback from you internal/external sdcard, although I'm not sure you can stream with it.
chros73 is offline
post #304 of 328 Old 01-04-2016, 08:53 AM
Liked: 0
Decoder Off Issues with Directv
I've had my Yamaha RX-A830 for about 2 years now and have mostly been thrilled. My setup consists of 5 speakers in the living room + subwoofer, and another zone with two speakers (kitchen) + two speakers (pool). I have my Directv (HDMI 1), (PS3 HDMI 2), and Panasonic TV connected to the receiver all via HDMI. At some point in the past year, I started experiencing a cutting out of a few seconds of sound periodically while watching television. This corresponds with a "decoder off" message on the front of the receiver.
I've tried to research and correct the problem, but I'm not having any luck. The problem seems to be happening more frequently and sometimes it just stays in "decoder off" until I cycle the power on the receiver.
In the past we'd normally play DSP in 7.1 surround, but I'm thinking that I need to play in a different scene. Experimenting often results in no sound coming from my back speakers unless I'm in 7.1 mode or surround decode.
I've also tried turning off the Dolby Digital on the Directv settings, but the same issue occurs even though it's in PCM.
I'm at a complete loss as to how to fix the issue at this point. From what I'm reading in this thread it seems that I should be in STRAIGHT, so I'll try that next.
Any advice out there?
Kinron is offline
post #305 of 328 Old 01-04-2016, 09:32 AM
KJSteward's Avatar
Quoted: 205 Post(s)
Liked: 608
Only while watching television ? I would switch out the HDMI cable. With all those other sources it seems unlikely to be a fault with the receiver.
Spoiler!
post #306 of 328 Old 01-04-2016, 12:55 PM
Liked: 0
I've tried switching out the HDMI cable. Doesn't make a difference. Also, the only real "source" is the Directv box. I actually currently have the PS3 disconnected for troubleshooting purposes, and the television is an output. The issue does seem to be more pervasive when watching movies on demand, but it happens with regular tv programming as well. I ordered a digital optical cable based on some other threads I've seen, but then discovered the directv box only has digital audio not digital optical.
Incidentally, no issues occur if the receiver is bypassed. This leads me to believe there is something wonky with the decoding via the receiver.
Kinron is offline
post #307 of 328 Old 01-04-2016, 01:24 PM
jdrake020856's Avatar
RX-A830 and HDMI Version and Pass-Thru
On my RX-A830, I cannot find any published spec as to what version of HDMI is on the Receiver. I "assume" v1.4 but was hoping for v2.0.
The reason I ask ... As I look at the new Ultra HD material, the Receiver has UHD Pass-thru and UHD upscaling. What does Pass-thru really mean? If I were to plug a UHD Blu-Ray player into the HDMI input, would the UHD content pass-thru to the HDMI output and then into the UHD TV? Does the full signal get passed-thru?
If so, does HDMI v1.4 do this? What am I losing if HDMI v1.4 is present?
Or, just by luck, does the RX-A830 have HDMI v2.0?
jdrake020856 is offline
post #308 of 328 Old 01-04-2016, 02:07 PM
KJSteward's Avatar
Quoted: 205 Post(s)
Liked: 608
Switching audio to coaxial or optical would have been my next suggestion but you appear to have that covered.
Spoiler!
post #309 of 328 Old 01-05-2016, 02:57 AM
Evinyatar's Avatar
Liked: 0
Considering the manual specifies a max framerate of 30fps for 4k, I'm gonna say it's 1.4. What you're missing out on is 12-bit colour 60fps 4k video. And Atmos (but you probably already knew that). But if you can afford a TV that allows you to see the difference between 12-bit 60fps 4k and 10-bit 30fps 4k (or 60fps 12-bit 1080p), you can probably afford a new receiver too
Evinyatar is offline
post #310 of 328 Old 01-05-2016, 06:10 AM
chros73's Avatar
Quoted: 50 Post(s)
Liked: 24
I read somewhere that Sony had provided 2.0 spec through firmware update to their TVs and that could be interesting for us as well.
Btw, I got a new firmware around a month ago. Does anybody know what is new in it?
MSI GE60(i73630QM,16GB,IntelHD4000(v10.18.10.4276)+GeF orceGT650m(2GB,v355.98)+muxless,1920x1080@60Hz,Ple xtor M5M 256GB SSD,Win8.1x64+MPC-HCx64+LAV+MadVR)+Yamaha RX-830+LG 55LD650(1080p@24/25/30/60Hz)
chros73 is offline
post #311 of 328 Old 01-05-2016, 06:45 AM
Evinyatar's Avatar
Liked: 0
HDMI 2.0 has a much higher bandwidth than 1.4, so I doubt it's something that can be done with firmware alone if the hardware itself wasn't already prepared for it.
As for that firmware update, according to the download page it
1. Improves connectivity of network music streaming services
post #312 of 328 Old 01-06-2016, 04:47 AM
chros73's Avatar
Quoted: 50 Post(s)
Liked: 24
I referred to only passthrough (not upscaling). Is it the same case? (I tend to think that it should work.)
Thanks! (I haven't found any info about this on the UK site.)
chros73 is offline
post #313 of 328 Old 01-08-2016, 12:50 PM
Liked: 0
So I tried adding a digital optical cable between the Directv and the receiver... didn't seem to make any difference.
In fact the problem has gotten worse now in that the "decoding off" message on the front of the receiver appears more often and occasionally my speakers will provide some very annoying loud feedback. Incredibly disappointing as I've had to disconnect the receiver completely and connect my tv to the directv box. The sound is so horrible... but I'm not experiencing any issues now. Can't figure out why the receiver is having issues with the connection from the Directv box...
Kinron is offline
post #314 of 328 Old 01-17-2016, 11:57 PM
Kimjor's Avatar
Just installed the latest firmware update, to be honest don't feel any differently even with the Spotify / airplay we use daily.
Kimjor is offline
post #315 of 328 Old 02-22-2016, 04:23 AM
chros73's Avatar
Quoted: 50 Post(s)
Liked: 24
Has anyone managed to pass through 4:4:4 RGB with this receiver to any display? If yes, which refresh rate did/do you use?
I can't get 4:4:4 with my LG 55LD650 (FullHD display).
And I saw the description of newer Yamaha models, and there is a line like "supports 4K Ultra HD at 60p 4:4:4" ( http://usa.yamaha.com/news_events/au..._av_receivers/ ) , so maybe it's missing from these models completely? Or is it just a big news to 4k?
Probably it's something not trivial, since the on-screen menus, other info has to be "mixed" in full RGB then.
chros73 is offline
post #316 of 328 Old 02-25-2016, 04:53 AM
chros73's Avatar
Quoted: 50 Post(s)
Liked: 24
Yamaha RX-A830 can, at least with 50/60Hz (I couldn't try out any more).
Yesterday I borrowed a 24" FullHD LCD multimedia monitor with HDMI input from a friend of mine. I switched my TV with it at the end of the chain and I could see 4:4:4 without problem. So that means my TV is the problem.
chros73 is offline
post #317 of 328 Old 04-08-2016, 09:31 AM
Liked: 0
Post How to watch tv in main zone and play musi in 2zone yamaha rx-a830?
Dear All HII,
I will like to know how can i watch tv in the main zone and at the same time play music in the 2zone?
NASRI28 is offline
post #318 of 328 Old 05-30-2016, 08:50 AM
SeauxCrazy's Avatar
Hey all,
I've noticed this thread has died a while back but hoping to find an answer to my issues. I'm having issues with Pandora intermittently cutting out. Music will stop playing mid song, after a song, or any other part of a song. Freeze and sometimes switch songs. If after a song, minutes can pass before it starts up again. Any fixes out there for this?
730, cox internet (45mbps), Apple AirPort Extreme (newest version), hard wired from router to amp (no wifi on unit)
Never had this issue before, but the router is new. Wondering if there is some sort of setting for Apple router needed to make this thing work.
SeauxCrazy is offline
post #319 of 328 Old 07-27-2016, 11:09 AM
jasonsong's Avatar
Quoted: 488 Post(s)
Liked: 179
Originally Posted by SeauxCrazy View Post
Hey all,
Try the latest 1.70 firmware on the receiver.
jasonsong is offline
post #320 of 328 Old 12-15-2016, 10:17 AM
tradewinds's Avatar
Quoted: 16 Post(s)
Hi all, I understand this AVR has Burr Brown DACs. I have an extra one new still in the box that I would like to use to build a dedicated music server. I have been looking at Ras Pi, BeagleBone Black, etc. and even Volumio 2 x64 on a itx pc to be the source. I however would like to understand better this "Server" function this AVR has that can help with this setup. I would rather not invest in more Pis with HATs etc. if all I need to do is get a pure digital signal to this AVR for it to do its thing with the in-built BB DACs and hopefully be able to play all formats of HD music.
BTW - this is the same model AVR I currently use in my HT Room.
My Riser | My LED Star Ceiling | My HTPC Build
tradewinds is offline
post #321 of 328 Old 12-15-2016, 07:43 PM
bpatters69's Avatar
Yamaha RX-A730 and Pandora
Hello All,
I just networked my Yamaha RX-A730 via a wired ethernet connection. I know the reciever is connected because I can play internet radio and music from my PC. The reciever also shows an IP addres. For some reason, I cannot get Pandora to work. I either get an error saying that "access error" or "not connected to a network". I see where I can add an account but i get one of the two errors.
Any ideas?
I have never upgraded the firmware. I have had the unit for a 2 or 3 years.
Thanks, Bill
bpatters69 is offline
post #322 of 328 Old 12-18-2016, 07:49 AM
Liked: 0
Pandora Fix- FINALLY
I just updated the firmware to 1.96 and this fixed this issue. I could not update via the network- I had to manually update the firmware via USB. the Yamaha site download and instructions are good, so just follow the instructions and you should be back up and running. After messing around with all my connections, etc, I wish I had done this first... I don't know why it stopped, but like everyone else, I had a good network connection, but received no network error messages on the Pandora page even though I could get the net radio to work and every area said I was connected to the network.
BWal is offline
post #323 of 328 Old 12-18-2016, 07:50 AM
Liked: 0
I have the RX-V673
BWal is offline
post #324 of 328 Old 12-18-2016, 10:10 AM
afrogt's Avatar
Quoted: 1432 Post(s)
Liked: 982
Originally Posted by bpatters69 View Post
Hello All,
Any ideas?
Thanks, Bill
http://download.yamaha.com/search/de...asset_id=67845
Afro GT
afrogt is offline
post #325 of 328 Old 12-24-2016, 02:50 PM
bpatters69's Avatar
Originally Posted by afrogt View Post
Thanks. Yes, upgrading the Firmware is the fix.
post #326 of 328 Old 03-27-2017, 08:49 AM
malarrya's Avatar
I've had Firmware 1.80 on my Yamaha RX-V671 receiver since last summer and that's when the Pandora problems started to occur. At first I thought it was my network, which may be part of it, since I upgraded to an AC router using DD-WRT and the receiver is connected via wireless bridge. I couldn't for the life of me figure out why internet radio had no trouble connecting but Pandora was being such a pain.
malarrya is offline
post #327 of 328 Old 03-27-2017, 08:50 AM
malarrya's Avatar
Well I finally found a great solution to the issue so I thought I would add my 2 cents if anyone is still experiencing trouble with Pandora giving an access error. I followed these instructions and it started working instantly:
The original post can be found here: https://community.spotify.com/t5/Oth...AV/td-p/674368
Hope this helps someone!
malarrya is offline
post #328 of 328 Old 05-25-2017, 09:26 AM
gadrago's Avatar
I have the RX-V773 receiver with a wired Ethernet connection on firmware 1.98 since April 4, 2017. Pandora was working initially on this firmware release but quit working in recent weeks with the 'Access Error' and 'No network found' messages, even though vTuner continued to work. My receiver was already on a static IP address from the router end. As suggested elsewhere, I got Pandora access restored by going into the receiver Setup, Network, IP address section and disabling DHCP. I then manually entered the receiver's static IP address, the router's subnet mask and gateway address, and changed the primary and secondary DNS servers from '0.0.0.0' to the Google '8.8.8.8' and '8.8.4.4', respectively. Pandora access was immediately restored. The same fix may work successfully if experiencing difficulty connecting to Pandora with the RX-A730 and RX-V673.
gadrago is offline
Emotiva Umc 200 7 1 Home Theater Preamp Surround Processor , Energy 5 1 Take Classic Home Theater System , Energy Rc 30 Reference Connoisseur 3 Way Tower Speakers Pair Black Ash Veneer , Yamaha Rx A830 7 2 Channel Network Aventage Home Theater Receiver , Yamaha Rx V867 Receiver
