How do you "unlock" a Harman Kardon AV130? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-29-2013, 07:03 PM - Thread Starter
rjgorman's Avatar
I finally got a chance to buy a new looking Harman Kardon receiver. It's an AVR 130. I do have a problem though.
I am trying to route my television so that I can run the audio through the receiver. I manage to route "optical 1" to both "DVD" and "VID !" but the remote won't work. It works fine with the tuner, but when I go to either DVD or VID 1, the receiver shows "Unlock" for a minute then shows he correct information, but nothing on the remote works. Very strange. As I mentioned, it works fine with the tuner.
Any help would be greatly appreciated!!
Thanks you.
Ron
rjgorman is offline
post #2 of 4 Old 08-30-2013, 12:04 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
afrogt is offline
post #3 of 4 Old 09-12-2013, 07:54 AM - Thread Starter
rjgorman's Avatar
After doing the reset and the routing the inputs again, I still have the same problem. Thanks though!
rjgorman is offline
post #4 of 4 Old 09-12-2013, 09:20 AM
M Code's Avatar
Quoted: 716 Post(s)
Liked: 419
Unlock means that the AVR's digital audio processor has not LOCKED-IN to a digital signal.. Either the source player and/or AVR is not properly configured, or you have a bad cable...
Just my $0.05... 👍😉
M Code is offline
