How to Connecting my PC to Yamaha RX-V673 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-30-2013, 07:12 AM - Thread Starter
singh83's Avatar
Hi,
I have a Dell vostro 200 that I am trying to connect to my Yamaha RX-V673. I have a graphics card that supports both sound and video. I used the HDMI port on the Graphics card and connected it to the receiver. I am able to see the Video on the TV but no audio. It shows up as speakers are not connected or detected.
I don't mind using any other cables other than the HDMI to make the connection.
My receiver does see the PC as when I go to the Screen selection, Server input and play music that way but not through the PC mode .
I hope i have given enough information here for someone to help.
singh83 is offline
post #2 of 7 Old 08-30-2013, 09:08 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Perhaps the graphics card isn't setup to pass HDMI audio?
Since you have not specified the graphics card no way anybody could help you configure it properly.
You can always use a stereo audio cable from the sound card to the receiver for audio if you don't mind 2 channel audio.
http://www.monoprice.com/Product/?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=1#largeimage
Afro GT
afrogt is offline
post #3 of 7 Old 08-30-2013, 11:47 AM - Thread Starter
singh83's Avatar
I am using the below graphics card with my Dell
VisionTek ATI Radeon HD 4350 512 MB DDR2 PCI Express Graphics Card 900270
singh83 is offline
post #4 of 7 Old 08-31-2013, 01:46 PM
trog69's Avatar
Quoted: 26 Post(s)
Liked: 42
That is strange. Have you tried going to the on-board sound? I use that, via HDMI. It shows as video, and also as SonyAmp, so it takes some playing with the audio controls in the, in my case, Realtek controls and connect the SonyAmp. There is no equalizer control using this, but I don't want that in the audio stream anyway, since it can be adjusted better using the receiver's options. I'd like to upgrade to a good sound card, but for now, it sounds phenomenal! A pair of KEF C-40s, with dual 8" drivers and a Polk Audio PSW505 sub, and the upgrade in sound quality is amazing!
Picking up a pair of B&W 601Se speakers tomorrow! Surround for gaming and music.
EDIT: Of course, in your case, the selection will be different; mebbe something like "YamahaAmp" or similar.
i7-6700k @4ghz/gtx 980ti SC+/Sandisk256gb SSD-Toshiba 2TB HDD/Asrock z170 Extreme 4 mobo/16gb 2133 ram/Sound via Pioneer Elite vsx-90/B&W 601se/KEF C-40(dual-8"driver mini-towers)/SVS PB-2000 sub/FiiO E17 Alpen DAC/Audio Technica M50 headphones(never used! heheh)/Crossover 2560x1440 monitor
trog69 is offline
post #5 of 7 Old 08-31-2013, 07:56 PM
trog69's Avatar
Quoted: 26 Post(s)
Liked: 42
I just now replaced the HDMI connection with a SPDIF connection, and it solved both the video side of things causing small yet noticeable issues on screen, and I am now able to control the equalization on the Realtek control panel, should I choose to do that.
So, I would recommend going with the optical connection rather than HDMI if you can do so. The sound quality is exactly the same, if not better. <---Most likely, exactly the same. hehe
trog69 is offline
post #6 of 7 Old 09-01-2013, 07:57 AM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
Just be aware that Optical (or coaxial digital) is limited to 2 channel PCM. If you want HI-def multi-channel you need HDMI.
trog69 likes this.
jdcrox is offline
post #7 of 7 Old 09-02-2013, 04:56 PM
trog69's Avatar
Quoted: 26 Post(s)
Liked: 42
Thanks. I didn't know that. Not a concern for my setup now, but I'd have gone nuts trying to figure out why the center channel wasn't playing. hehe.
These B&Ws have taken over my system! They also make rude comments to the KEFs. I see a fight brewing. I had to turn up the output on the sub to match the deeper bass from these little monsters.
EDIT: It seems that you can indeed get 7.1ch sound via SPDIF. It requires some workarounds, and the trouble is not worth it when a simple HDMI connection will solve the problem, but it's doable:
http://social.technet.microsoft.com/Forums/windows/en-US/d41fd52a-b6b1-42c4-8b5c-3d5ba6c21e64/spdif-output-is-2-channel-only<---Last comment.
trog69 is offline
Yamaha Rx V673 Receiver
