No sound from HDMI from Receiver to TV Speakers - Pioneer VSX-1022 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 08-30-2013, 01:16 PM - Thread Starter
afunnell's Avatar
I feel this has to be a setting issue on the receiver. I am running an HDMI IN from the Xfinity / comcast cable box to the Sat / Cable input on the receiver and then out to a Samsung TV directly through HDMI. I get picture but no sound through the TV which is what I require as I don't plan to use speakers. If I plug the cable box in through the same HDMI cord connected to the Samsung TV I get pic and sound through the TV no problem. I've gone through the main menu>HDMI options>ARC on /off I feel in every possible combination but still no sound. Any help greatly appreciated!
afunnell is offline
post #2 of 22 Old 08-30-2013, 02:23 PM
duc135's Avatar
Quoted: 154 Post(s)
Liked: 219
ARC is audio RETURN channel. That is for bringing audio FROM the TV back to the receiver. That option will not affect your issue. What you need to look for is an option in the receiver to output HDMI to the amp or passthrough to your TV. I know there's the option in Denon receivers. If not, see if there if your receiver supports complete HDMI passthrough without having to turn on your receiver.
duc135 is online now
post #3 of 22 Old 08-30-2013, 02:34 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Why have a A/V receiver at all if you don't want to connect any speakers? You could just connect all the devices directly to the TV if you have enough inputs. An HDMI video switcher would have been much cheaper if your TV didn't have enough inputs.
Since you're only using it as a video switcher do the following steps.
Look on pg 36 of your manual. If you don't have one you can download it here.
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-1022-K_OperatingInstructions062612.pdf
Follow the pictures on this page
1. Hit Receiver button on the remote
2. select the audio parameter button
3. toggle down until you get to HDMI
4. Change the setting to THRU, its probably on AMP right now.
When THRU is selected no sound is output by the receiver. Sound will be output to the TV.
Then go to page 52 and set CONTROL to OFF and ARC to OFF since you're not using those functions anyway.
duc135 and afunnell like this.
Afro GT
afrogt is online now
post #4 of 22 Old 08-30-2013, 06:23 PM - Thread Starter
afunnell's Avatar
Thanks for your multiple replies / help with this AfroGT! Fix about works great. I didn't know HDMI Switches like what you just pointed out even existed. I will probably run some speakers at some point and got a good enough price on the receiver I'll probably just stick with it.
afunnell is offline
post #5 of 22 Old 09-22-2013, 01:00 PM
toddstew's Avatar
I am getting a buzzing sound from my center speaker, that seems to be coming from this receiver. Any idea on fixes? Thanks.
toddstew is offline
post #6 of 22 Old 09-22-2013, 06:23 PM
afrogt's Avatar
Liked: 755
Check your wiring on the back of the speaker and on the back of the receiver.
Try a different speaker in the center position. If that one doesn't buzz your other speaker is probably bad.
Afro GT
post #7 of 22 Old 09-24-2013, 03:33 PM
toddstew's Avatar
Thanks for the suggestion. After disconnecting the speaker wires to the center speaker, the buzzing moved to a different speaker. After trying a different center speaker, the buzzing was still there. So, it must be the receiver, which I am taking to the service center. thx
toddstew is offline
post #8 of 22 Old 10-06-2013, 02:26 PM
jer181's Avatar
Quoted: 64 Post(s)
I am having the opposite problem. Can't get sound to run through my receiver from my TV. I have a pioneer sc67. Any suggestions?
jer181 is offline
post #9 of 22 Old 10-07-2013, 12:58 AM
afrogt's Avatar
Liked: 755
What TV do you have? Have you tried connecting optical out from TV to receiver?
Afro GT
post #10 of 22 Old 10-08-2013, 09:39 AM
jer181's Avatar
Quoted: 64 Post(s)
I have an older Samsung TV. I have not tried the optical out. Does that limit the quality of the sound? or is it comparible to the HDMI out? Its oodd, becuase everything else that I hook up works fine. (MHL,HDMI from my computer,Tuner, PS3)
jer181 is offline
post #11 of 22 Old 10-08-2013, 01:09 PM
jer181's Avatar
Quoted: 64 Post(s)
I think the problem might lay in the fact that my digital cable box is hooked up through my TV via RCA as its not high def. The receiver wouldn't be able to convert the signal... think there will be an analog setting on the receiver so I can get sound going through my speakers?
jer181 is offline
post #12 of 22 Old 10-08-2013, 03:16 PM
duc135's Avatar
Quoted: 154 Post(s)
Liked: 219
Unless your TV has ARC then you will not be able to get sound from your TV to your receiver via HDMI. If your TV does support ARC, you have to make sure you are plugging into the HDMI port that has that feature. Not all TVs support ARC and when they do, usually only one of the HDMI ports have it. If your TV does not support ARC then you will need to use either the digital out or RCA out to connect to your receiver.
post #13 of 22 Old 10-18-2013, 06:54 PM
jer181's Avatar
Quoted: 64 Post(s)
So you are saying I can use RCA's (blue/green/red) or I can use an optical cable from my receiver to my TV plus the other cable that goes with the optical one? and I should have sound from my TV through my receiver?
jer181 is offline
post #14 of 22 Old 10-18-2013, 07:23 PM
duc135's Avatar
Quoted: 154 Post(s)
Liked: 219
Blue, Green, Red are component RCA cables used to pass video. Does your receiver not support HDMI? Not sure what you mean by "the other cable that goes with the optical one". Here are your options:
1. If both your receiver and your TV support ARC, all you will need is a single HDMI cable and configure both devices to pass the audio back to the receiver. Note: This will only pass 2CH audio.
2. If either your receiver or your TV does not support ARC, but is connected via HDMI then you will need to pass audio via a second cable. You will have to use whatever cable type your TV supports. It will either be optical, digital coax or composite (red and white RCA) cables. In rare occasions I have seen TVs with 1/8" stereo jacks. In this case you will need a 1/8" to RCA adapter to connect to your receiver. For the optical and digital coax you may possibly get 5.1 channel output if your TV supports it. If not, it will be like the composite and stereo outputs. You will only get 2CH audio.
3. If you are connecting your receiver to your TV via any other connection other than HDMI then you will looking at the same audio connections as #2.
post #15 of 22 Old 01-04-2014, 08:31 PM
1nightin's Avatar
Gday,
Ive been trying to find an applicable thread and this seems to be the best...
Can anyone suggest why I cannot get audio to a second TV using HDMI? The TV receives good quality video. I'm using a 100ft HDMI cable but would have thought if there was a signal strength issue, the video would have been more suscesptable to loss? I've tried running the cable into a second receiver but I have video signal issues, so presently it runs straight into the HDMI port on the TV.
The main system works fine, though I am using system speakers for TV audio. The main TV uses HDMI 1 (control) and the second TV is using the OUT 2 HDMI
I have a SC-LX85 (which I think is equivalent to the US model SC77, asst a glance it has similar specs )
any suggestions welcome...
1nightin is offline
post #16 of 22 Old 11-16-2014, 06:29 PM
DrWizard's Avatar
HDMI Audio stopped working on 1123K
I've had my new Pioneer VSX-1123K all set up and working great for two months.
Then, the other day, the Audio stopped working for HDMI. I've read thru the manual, and tried several things, to no avail.
Symptoms / Troubleshooting:
* I have 3 HDMI sources hooked up to the receiver, A DirecTV satellite receiver box, a Home Theater PC, and a standalone Blu-Ray player.
* I have 1 normal output, a Viewsonic PJD7820HD Projector. But I also tried a Vizio LCD TV.
* Video works for all 3 sources. I get no sound for any of the 3 video sources. Sound plays fine for the FM Tuner, Internet Radio, and Pandora.
* My guess was ARC - Audio Return Channel. Went into the Receiver Setup -> System Setup -> HDMI - ARC and made sure it was turned on (it was).
* Turned up the volume on the projector, it's normally turned all the way down. No sound from the projector.
* Went into the Receiver setup, and turned ARC off. Still no sound from the projector.
* At this point wasn't sure if might be the ARC in the Receiver or the Projector, so I hooked up Vizio TV instead. No sound from the TV.
* Went into the Receiver setup, turned ARC back on, and left setup. Still no sound.
* Hooked the Satellite receiver directly to the TV. Have Sound!
* Tried going thru the Pioneer again, no sound with or without ARC turned on/off.
* Hooked the Home Theater PC directly up to the projector. Have Sound! (Well, crappy sound from the Projector's little speaker)
* Routed thru the Pioneer again, still can't get sound.
* Went to Audio Parameters -> HDMI and changed setting from AMP to THROUGH. Now the sound works on the TV/Projector, but still not from the Pioneer receiver.
* Tried the TV on Output #2 , but
After reading much of the Pioneer manual 2 or 3 times, I don't see anything else other than the ARC setting that should cause this problem. Is there something else I should check?
Yes, I could hook up the Satellite receiver, HTPC, and/or Blu-Ray with optical or coax digital cables, but I have 3 devices and only 2 digital sound inputs.
Plus, I shouldn't have to do that, and the Pioneer receiver is only two months old. Using ARC is so much simpler and convenient.
Plus, it was working, and suddenly stopped working.
The receiver is all digital, so it seems weird that just this one thing is not working, which makes me suspect it might just be a setting somewhere got accidentally changed. (Digital stuff generally tends to work completely, or not work at all.)
Anyone have any ideas?
DrWizard is offline
post #17 of 22 Old 11-16-2014, 06:40 PM
afrogt's Avatar
Liked: 755
Try doing a processor reset and then start over with your setup.
Afro GT
post #18 of 22 Old 11-17-2014, 09:32 PM
DrWizard's Avatar
OK, that did it! I had already tried doing that using the AV-Navigator software but it wouldn't write or change any settings even though it had a connection.
Looked up Reset in the PDF manual, and went thru that procedure, and my sound came back!
Still though, anyone have any idea what setting may have been screwed up? I tried every setting I even remotely thought might affect it.
DrWizard is offline
post #19 of 22 Old 02-25-2015, 03:38 PM
Liked: 3
Same "no sound" issue with my Pioneer VSX - 1022
I had the same issue with my Pioneer VSX - 1022K AVR. First the audio became intermittent, meaning it would sometimes work and sometimes not. Pausing my cable DVR then hitting play would bring the audio back, so would changing channels. Then audio stopped working on the BluRay player. Changing the HDMI to Thru and the audio would pass ok to the TV set. ARC was turned off. Even the optical input for the player stopped so I think this is a Decoder problem, not HDMI per se and obviously not a total failure in hardware. Suddenly today (weeks later) it works again on the HDMI inputs (both DVR and BR player) with no changes in anything except restarting (full reboot) my X1 DVR . I had changed the optical input from the BR player to the DVR and that worked ok before the restart. Again everything points to a audio decoder issue.
I don't find anything in my manual about resetting a processor, how is that done? I don't expect my luck to hold out.
Babble is offline
post #20 of 22 Old 02-25-2015, 04:04 PM
Liked: 3
After posting, I did find a procedure to reset the main unit, is that what you did?
Babble is offline
post #21 of 22 Old 07-29-2015, 12:44 PM
Liked: 0
Do this for only a few channels (like GAME and SAT)
I'm trying to do the same thing as afunnell but I only want to use this setting for GAME and SAT is that possible or do i have to change it by hand every time i select a different source?
hofsink.nick is offline
post #22 of 22 Old 11-13-2015, 10:47 AM
Liked: 0
The reset did not work for me.
Randeep Sharma is offline
Pioneer Vsx 1022 K 560w 7 Channel A V Receiver , Pioneer Vsx 1022 K 7 1 Channel A V Receiver With Ab Video Scaler For Ipad R Iphone R Ipod R
