Newbie Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-01-2013, 06:06 PM - Thread Starter
SteeleJester's Avatar
Liked: 31
I'm a rookie to this whole home theater stuff and have a question that someone more knowledgeable should be able to answer quickly. So to the point. I have a vsx-822, it has a preout and Dolby prologiciiz (far as I understand). Can I run an amp to the preout and then run a couple speakers to the amp as front Heights?
SteeleJester is offline
post #2 of 8 Old 09-01-2013, 06:31 PM
jdsmoothie's Avatar
Quoted: 12110 Post(s)
Liked: 5511
The 822 Owner's manual back panel seems to indicate this would be possible ...
jdsmoothie is online now
post #3 of 8 Old 09-01-2013, 06:39 PM - Thread Starter
Liked: 31
And to supplement the original question: if front Heights were hooked up, would it be 5.1 with all fronts or 7.1 with fronts and surrounds?
post #4 of 8 Old 09-01-2013, 09:32 PM - Thread Starter
Liked: 31
Any other suggestions, recommendations, etc.?
post #5 of 8 Old 09-02-2013, 06:15 AM
jdsmoothie's Avatar
Liked: 5511
The 822 is a 5.1 AVR and therefore can power 5 speakers, FL/C/FR and "side" surrounds, SL/SR. If you connect an external 2CH amp, you can add 2 more speakers as "either" Front Height or Surround Back (based on an internal setting in the 822) to make it a 7.1 setup.
post #6 of 8 Old 09-02-2013, 06:26 AM - Thread Starter
Liked: 31
Thank you. I believed it was the case, just wanted to be sure. What would be a decent amp to run those 2 extra speakers?
post #7 of 8 Old 09-02-2013, 06:38 AM
jdsmoothie's Avatar
Liked: 5511
post #8 of 8 Old 09-02-2013, 06:41 AM - Thread Starter
Liked: 31
I would like to keep it in the $100 range (above suggestion would fit budget). I don't feel I need a lot of power.
