AMPs to match the Paradigm Monitor 11 series speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-01-2013, 07:03 PM - Thread Starter
sheikhayoub's Avatar
Based on experience, are the sensitivity of paradigm monitor 11 series speakers a good match for a 105 watt/per channel AVR or 125 watt/per channel AVR. I don't want to spend more than I need to since I don't typically need the other extra added features to the DENON X3000 over the X4000. Any opinions is appreciated.
sheikhayoub is offline
post #2 of 2 Old 09-01-2013, 07:42 PM
eljaycanuck's Avatar
Quoted: 1346 Post(s)
Liked: 1962
... are the sensitivity of paradigm monitor 11 series speakers a good match for a 105 watt/per channel AVR or 125 watt/per channel AVR[?]
Yes.
That said, not all AVRs are created equal, and an AVR that may perform well with a pair of Monitor 11s hooked up to it may not perform as well trying to drive 5, 7 or more speakers to loud volumes.
eljaycanuck is offline
Paradigm , Denon Avr X3000 7 2 Channel Home Theater Receiver , Denon Avr X4000 7 2 Channel Home Theater Receiver
