pioneer vsx-1122 not connecting to my network - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-02-2013, 06:17 PM - Thread Starter
SN16's Avatar
Hi I have a problem with my vsx-1122 receiver connecting to my network. it was connected and working with no problems and then one day dont know when it wasnt connected and now it wont connect . i restarted the router and the receiver many times . I know the internet wire has a connection and works because i hooked it up to something else and it worked . when i go to network set up screen and try to open the first menu or the I.P. address it opens a screen that says network setup appying setting and doesnt do anything or go anywhere i've left it on that screen for a long time and didnt do nothing. To get out of that screen i press the home button on the remote. i tried to downloaded a update on a usb memory card so i can try and update the receiver but it wont even read the memory card and in the setup for the update software on the receiver i cant select the update software. no i didnt try to update the receiver a stop it during the update . working one day and not the next dont know why . i dont want to reset the router to factory cause then i have to go and put in all the IP addresses and passwords on everything
[/SIZE]
SN16 is offline
post #2 of 8 Old 12-09-2013, 10:54 PM
Gpeck14's Avatar
Did you get this fixed? Im having the exact same problem. please let me know.... thanks
Gpeck14 is offline
post #3 of 8 Old 12-10-2013, 07:33 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
99% of the time that these issues arise, the fix is within the router and not the receiver. I would reset the router. There should only be one password and you should be using HDCP rather than using dedicated IP addresses. You probably have an IP conflict somewhere.
FMW is offline
post #4 of 8 Old 02-16-2014, 06:48 PM
netretread's Avatar
Any update on you problem? I have the same issue. Network connectivity has been spotty, but hasn't been working for a few days now. It must be something funky going on with the network electronics in the receiver. I can't even get it to show a link on the switch it is plugged into. I have the receiver set so it should be accessible when it is powered off (standby).
netretread is offline
post #5 of 8 Old 05-07-2014, 12:10 PM
eboyce's Avatar
I'm having the same problem here.  Was working fine for over a year, but now it gets stuck on "Starting HMG" and also won't show a link on the router I have it plugged into.  Also hangs on "Network Setup--Applying Settings"  I've tried switching out network cables.  Dead network port?
eboyce is offline
post #6 of 8 Old 04-14-2016, 11:35 AM
matt21484's Avatar
Holy Necro, but I'm having the exact same problem. Anybody get this fixed?
matt21484 is offline
post #7 of 8 Old 04-14-2016, 08:03 PM
Liked: 1
I'm having the same problem with my SC 1522-K. About three years into ownership the network connection is undependable which makes using the iPad app impossible.
unclepp is offline
post #8 of 8 Old 04-16-2016, 11:05 AM
matt21484's Avatar
So I actually got mine fixed yesterday, I had to reboot all of my networking equipment. Unplug everything that manages the flow of traffic and then unplug the receiver. Reboot in this order (waiting 30 seconds between each) Modem first > router > switch 1 > switch 2 > etc. > Receiver. After powering everything back on, AirPlay worked right from the get go for me.
My personal opinion on what happened is that the receiver grabs an IP address and then doesn't let go even though that particular address lease may have been released on the router side.
Pioneer Vsx 1122 K , Pioneer Vsx 1122 K 630w 7 Channel A V Receiver Network Ready Pandora Ipod Iphone
