Looking for a receiver as part of my Pawn shop testing station - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 09-02-2013, 07:50 PM - Thread Starter
Danediz's Avatar
I am looking for a good receiver to use at my testing station at my pawn shop. I plan on having an hdmi wall plate and a composite wall plate connecting to the receiver and having the hdmi out on the receiver goto my testing tv. My question is if receivers will take the composite input in and transcode? it to the hdmi out so that I can use one cord to my tv. I am using the receiver for testing speakers as well. Does anyone know if you can hook up any type of car audio to a receiver too?
Im looking in the yamaha brand and at a 300 dollar budget.
Danediz is offline
post #2 of 10 Old 09-04-2013, 07:53 AM - Thread Starter
Danediz's Avatar
I guess my question is which is the cheapest receiver that will allow me to hook up composite inputs and it will upconvert to hdmi using the hdmi out. I bought a Sony from walmart recently and when hooking up composite inputs you could not get the receiver to output the signal in hdmi.
Im afraid in order to get this feature ill need to spend 4-500 dollars.
Danediz is offline
post #3 of 10 Old 09-04-2013, 08:02 AM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5500
The lower level models (ie. < $500) generally don't do analog --> HDMI conversion so you will likely need to look at 1-2 year old models, like the 2011 Denon 1912 which is the lowest model of that year that can do the conversion ...
http://www.accessories4less.com/make-a-store/item/DENAVR1912/DENON-AVR-1912-7.1ch-Network-A/V-Home-Theater-Receiver-w/Airplay/1.html
jdsmoothie is offline
post #4 of 10 Old 09-04-2013, 09:00 PM - Thread Starter
Danediz's Avatar
Danediz is offline
post #5 of 10 Old 09-05-2013, 05:02 AM
jdsmoothie's Avatar
Liked: 5500
No mention of being able to do the composite ---> HDMI conversion you require, so then no. You'll have to upgrade to the next higher model for that feature, the 675.
post #6 of 10 Old 09-05-2013, 08:58 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
afrogt is online now
post #7 of 10 Old 09-05-2013, 09:34 AM - Thread Starter
Danediz's Avatar
Awesome thanks! Ill order that one today!
Danediz is offline
post #8 of 10 Old 09-09-2013, 08:17 AM - Thread Starter
Danediz's Avatar
Receiver works great for what i need! Thanks guys! One more question... How do i get the receiver to pass sound to the tv in case im testing a customers tv and want to make sure the sound on their tv works. I noticed on most receivers that they mute the sound going to the tv
Danediz is offline
post #9 of 10 Old 09-09-2013, 12:39 PM
wader2k's Avatar
That is a setting in the TV's menus.
wader2k is offline
post #10 of 10 Old 09-09-2013, 08:34 PM
BassBinDevil's Avatar
Typically upconversion is included with 7.1 and better AVRs.
As for car audio, you could feed line outputs from a head unit or processor to a line input on the receiver. If you want to power-up big power amps on the bench, you'll need a hefty power supply. Astron is one respectable brand.
BassBinDevil is offline
Denon Avr 1912 Receiver , Yamaha Rx V673 Receiver , Yamaha Rx V575 7 1 Channel Network Av Receiver
