Can Bose Passive Subwoofer, be connected to zone2 ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 09-03-2013, 04:39 PM - Thread Starter
rodgon's Avatar
HELLO,
I want to connect my old bose passive sub to My Yamaha A720 zone2, can it be connected ?
Receiver is designed for two speakers (zone2), Bosse Sub is designed for 5 speakers.
Does it work, connecting only those two speakers ?
Please advise
rodgon is offline
post #2 of 9 Old 09-03-2013, 05:15 PM
eljaycanuck's Avatar
Quoted: 1226 Post(s)
Liked: 1798
Using an AVR to power a passive sub (in addition to powering speakers) *could* work under certain limited conditions...but I wouldn't do it.
eljaycanuck is offline
post #3 of 9 Old 09-03-2013, 05:21 PM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5499
Nor would I. eek.gif Much safer to simply pick up a powered sub or better yet, if really just looking for Zone 2 speakers, then pick up a couple of speakers.
jdsmoothie is offline
post #4 of 9 Old 09-03-2013, 07:06 PM - Thread Starter
rodgon's Avatar
Is it possible to burn my AVR?
Why do you wouldnt do it !
rodgon is offline
post #5 of 9 Old 09-04-2013, 12:31 AM
Ross Ridge's Avatar
Liked: 81
Normally, using a passive subwoofer with a receiver isn't going to damage anything, this is how they're designed to be used. However, your passive subwoofer is designed to work with 5 speakers, not 2, so using it in the configuration your proposing could cause problems. If it were a stereo Bose system there wouldn't be a problem, but I wouldn't recommend using your 5 channel system in zone 2.
Ross Ridge is offline
post #6 of 9 Old 09-04-2013, 02:13 AM
jdsmoothie's Avatar
Liked: 5499
Because AVRs are not designed to power "passive" subs. What is the end goal, to simply power Zone 2 speakers?
post #7 of 9 Old 09-04-2013, 06:38 AM - Thread Starter
rodgon's Avatar
Just add bass to zone2,
Even my Yamaha A720 has two subs (7.2), the second sub deosnt work to zone2.
So, i guess i have to get a power plate
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-782
rodgon is offline
post #8 of 9 Old 09-04-2013, 08:49 AM
Ross Ridge's Avatar
Liked: 81
No, using that power plate with your Bose system is not a good idea. Your Bose subwoofer not designed to be used with a power plate and will not work properly with one. The power plate is designed to be connected directly to an appropriate speaker driver (the actual moving speaker inside the subwoofer). It's not meant to be connected to the 5 speaker crossover that your Bose subwoofer has in place before the driver.
Despite what others have told you in this thread, your Bose speaker system, the entire speaker system with all of it speakers, is designed to be connected to the 5 speaker terminals of surround sound AV receiver. When connected properly, with 5 speaker cables running from an AV receiver to the Bose subwoofer and the 5 speaker cables connecting the matching Bose speakers to subwoofer, the entire speaker system looks and behaves like 5 seperate full-range 8 ohm speakers. This is what an AV receiver is designed to handle.
Note that Bose speakers systems are very poorly regarded here. Regardless of the fact if used properly it will work without risk of damage to anything, it's sound quaility is never going to be good. Used improperly it's going to sound even worse, and you do risk damaging your equipment. You should really give up your idea of using it in your second zone. Get a new set of speakers, do not try to connect the Bose satellite speakers directly to your receiver, this is much more likely to cause serious damage, and get a powered subwoofer with speaker level input and outputs if you need more bass. You could also get a 2 speaker Bose system if you want, but this is probably not your best option in terms of sound quality.
post #9 of 9 Old 09-07-2013, 05:31 AM - Thread Starter
rodgon's Avatar
Thank you all !
rodgon is offline
