Need help setting up RTI A9 with Emo XPA-2 subwoofer and yamaha RX565 reciever - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-04-2013, 08:47 AM - Thread Starter
abhicosner's Avatar
Hey Guys,
This is my first post on this forum, so apologies in advance if I sound dumb frown.gif.. I had a 7.1 home theater system set up in a dedicated media room which was running on Yamaha RX 565 all this while.. I found a great deal on RTI A9's and brought it to replace my fronts.. after conducting some research, I realized that the receiver isint powerful enough to get the best of the RTI - a9's, so I went ahead and purchased a Emotiva XPA-2 sub to power the a9's.. My question is - How can I set up the system to use the XPA-2 to power my A9's and the rest through the YAMAHA RX 565?
Thanks for your help in advance,
Abhi
abhicosner is offline
post #2 of 11 Old 09-04-2013, 08:56 AM
eljaycanuck's Avatar
Quoted: 1344 Post(s)
Liked: 1959
... How can I set up the system to use the XPA-2 to power my A9's and the rest through the YAMAHA RX 565?
I don't think you can: The RX-V565 doesn't have any pre-outputs other than for a subwoofer, and you need pre-outputs for the front L+R channels in order to send the front L+R audio signals to the XPA-2.
eljaycanuck is offline
post #3 of 11 Old 09-04-2013, 09:03 AM - Thread Starter
abhicosner's Avatar
ouch frown.gif.. So whats a good receiver that you would recommend that does not break the bank?
post #4 of 11 Old 09-04-2013, 09:13 AM
Liked: 1959
What's your budget? $550 will get you a new Onkyo TX-NR717 (an out-going model) at Amazon.com. If you're OK with factory re-furbs, $500 will get you a Denon AVR-3311 at Accessories4less.com. I don't think you can go much lower than that for an AVR with pre-outputs.
post #5 of 11 Old 09-04-2013, 09:54 AM - Thread Starter
abhicosner's Avatar
i was hoping to spend and would mind a refurb and as I am using a XPA 2 for the fronts, any regular reciever should be able to power the sub and the surround and the back right? unless I am missing something frown.gif
post #6 of 11 Old 09-04-2013, 10:11 AM
Liked: 1959
i was hoping to spend and would mind a refurb ...
- You omitted the dollar amount.
- Just to clarify: You would mind a refurb (you're not interested in one) or you wouldn't mind a refurb (you're OK with one)?
... and as I am using a XPA 2 for the fronts, any regular reciever should be able to power the sub and the surround and the back right?
Yes, all AVRs have at least one subwoofer output and can power at least 5.1 channels.
post #7 of 11 Old 09-04-2013, 11:06 AM - Thread Starter
abhicosner's Avatar
Apologies.. I would like to spend less than $500 if possible and wouldnt mind a refurb one
post #8 of 11 Old 09-04-2013, 11:18 AM
Liked: 1959
The Denon AVR-3311 factory re-furb at Accessories4less.com may be your best bet. It's $499.99 w/ free shipping.
post #9 of 11 Old 09-04-2013, 12:00 PM - Thread Starter
abhicosner's Avatar
Will a Denon AVR-3805 work too?
post #10 of 11 Old 09-04-2013, 12:11 PM
jdsmoothie's Avatar
Quoted: 14623 Post(s)
Liked: 6959
Why do you think you need the XPA-2? Are they distorting at the volume level used with the 565? If not, no need. smile.gif
eljaycanuck likes this.
jdsmoothie is online now
post #11 of 11 Old 09-04-2013, 12:27 PM
Liked: 1959
Sure. Just be aware that that's an older-model AVR with no HDMI inputs and probably a number of other features you won't find on newer or more-recent AVRs.
BTW, +1 to jdsmoothie's point. If your current AVR powers your speakers cleanly, return the XPA-2 (if it's not too late to do so) and just enjoy your set-up. smile.gif
Yamaha Rx V565bl 630 Watt 7 Channel Home Theater Receiver , Emotiva Xpa 2 Stereo Power Amplifier , Polk Audio Rti A9 Floorstanding Speaker , Polk Audio Rti A9 Floorstanding Speaker Single Black , Polk Audio Rti A9 High Performance Floorstanding Loudspeaker Each Black
